AutoCAD JavaScript API not working
Message 1 of 25
I tried now for quite some days to load a JavaScript into AutoCAD 2016, by following this Tutorial: https://df-prod.autocad360.com/jsapi/v3/GettingStart/index.html?url=files/tutorial_palette_wrkflw.ht...
However, I'm able to load the html file into AutoCAD, but I cannot get any function run. The documentation on that is extremely poor, which makes it very rough for beginners to drop in. I had to change the javascript source file into src="http://app.autocad360.com/jsapi/v2/Autodesk.AutoCAD.js"
at least to be able to execute any of the commands.
But nevertheless in this example the data of the added points are not passed back from the AutoCAC Window to the html. There is actually no interaction possible.
Does anyone have an idea how I could proceed?
Many thanks in advance
Replies (24)
Message 21 of 25
d3nis.code
Observer
Observer
Any news on this? When new API is coming? is almost 2 years now since  this is not working
Message 22 of 25
lena.talkhina
Hello @Anonymous !
The latest version of the documentation that applies to v3 can be found here:
https://help.autodesk.com/view/OARX/2021/ENU/?guid=adsk_jsdev_autocad_javascript_api_about
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 23 of 25
sirmavid
Community Visitor
Community Visitor
Thanks for the useful answer, i was also searching for the same. get-vidmate.com instagram saver
Message 24 of 25
d3nis.code
Observer
Observer
Is there any news on this. Did Autodesk gave up on JavaScript API?
Message 25 of 25
CodeDing
@d3nis.code ,
They have made better strides to improve the API. See documentation here:
https://help.autodesk.com/view/OARX/2022/ENU/?guid=adsk_jsdev_autocad_javascript_api_about
I haven't used the API in a while, but I believe it's in good condition.
Best,
~DD
