Autocad how get text to excel use visual lisp
I Find this code but no I need,
like this,how to Improve this code?
lines to excel too!
Autocad text to excel
Dear sir,
Would you like to help me.
How to modify the the command from listing lsp at below, cause every time I select the text always come up with new workbook xls. I want to change to be come still in the same workbook.
thank you
(defun c:ttx (/ ss xlApp xlCells row col i)
(vl-load-com)
(if (setq ss (ssget '((0 . "*TEXT"))))
(progn
(setq xlApp (vlax-get-or-create-object "Excel.Application")
xlCells (vlax-get-property
(vlax-get-property
(vlax-get-property
(vlax-invoke-method
(vlax-get-property xlApp "Workbooks")
"Add") "Sheets") "Item" 1) "Cells") row 0 col 1)
(vla-put-visible xlApp :vlax-true)
(foreach y
(mapcar '(lambda (x / iPt)
(setq iPt (vlax-get x 'InsertionPoint))
(list (vla-get-TextString x)
(rtos (car iPt) 2 2)
(rtos (cadr iPt) 2 2)
(rtos (caddr iPt) 2 2)))
(mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
(if (> row 65536) (setq col 5))
(setq i -1 row (1+ row))
(mapcar
(function
(lambda (x)
(vlax-put-property xlCells "Item" row
(+ col (setq i (1+ i))) x))) y))))
(mapcar 'vlax-release-object (list xlApp xlCells))
(princ))
Sea-Haven
It needs a rewrite a reorder of the sequence of events the If ssget needs to be after the excel is opened, if you run again needs a check for is excel already open.
Try this not tested.
(vl-load-com)
(vlax-get-property
(vlax-get-property
(vlax-invoke-method
(progn
(foreach y
(mapcar
(function
(lambda (x)
(princ))
