AutoCAD API
AutoCAD API
Message 1 of 15
AutoCAD API
Does AutoCAD API have a viewer that I can link my application to?
Replies (14)
Message 2 of 15
lando7189
Yes.  Check in to acctrl.dll.
Message 3 of 15
Forgive my ignorance Lando7189, but what is "acctrl.dll."?
Rasheeda
Message 4 of 15
lando7189
It is the 'DWG TrueView' control that you can drop onto a form to view dwg files.  You would need to call it from an application developed in VB.NET as it can't be called from VBA within AutoCAD.
Message 5 of 15
Is it difficult to add the API to an application and then call the "DWG TrueView"?
What is involved in this? ie Does it take alot of hours?
thanks
Rasheeda
Message 6 of 15
lando7189
Rasheeda,
Here is an example of how to use it within Visual Studio (The example is for AutoCAD 2009 & VS2005 using C#, but it demonstrates the basic idea of how it works).
http://through-the-interface.typepad.com/through_the_interface/2008/03/embedding-autoc.html
It also requires DWG True View being installed on the machine the program is running.
Message 7 of 15
So, would I embed the DWG True View within my software application that is on the web?
Message 8 of 15
lando7189
DWG True View must be installed on the local machine, but the web page should then work.
Message 9 of 15
Therefore it would have to be embedded into the software on a server (ie server license)?
thanks
Message 10 of 15
lando7189
No -- the dll would be referenced only.  The server wouldn't need it, just the local pc calling the webpage.
Message 11 of 15
So, would I need to develop a viewer for my software using the AutoCAD api, or has this been done already?
I want to be able to view .pdfs and dwgs within my software?
thanks
Message 12 of 15
lando7189
The acctrl.dll contains the viewer control.  You just reference it, add the control, and add it to a form.  The example i listed earlier shows an example.
Message 13 of 15
my clients wouldn't be able to download a dwg viewer onto their pc, because of restrictions. Hence I wanted to incorporated into the web based software?
Is this doable?
Message 14 of 15
dgorsman
What you are after, I think (viewing DWG files online, as you would a movie or image) isn't currently doable at least not very easily.  There are a few prototype systems out there but they are quite complex.  You may want to consider a non-scripted solution such as A360 which includes viewers for many different file types.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 15 of 15
