@Anonymous wrote:
That is for Lanscape pline. Only need radius bulge to even-odd 0 or 5. Example: 7863 --> 7865, 7862->7860
So now it occurs to me -- It would be far simpler to round the text content of the Dimensions to the nearest multiple of .0005 [or of .05 in the original image], rather than change the Polyline routings. There are lots of number-rounding routines on these Forums, and imposing the rounded result on the Dimensions is easy. Would that serve the purpose as well?
Yes, if you do something to alter the shape of the Polyline, the Dimensions' text content wouldn't update automatically. But with the forced-bulge-factor approach, an altered associative Dimension's updated radius value isn't [except by very rare coincidence] going to be to the right rounding, anyway. So that "drawback" isn't really a disadvantage -- in either case you'd need to run some routine again, either to re-alter the shape of the Polyline, or to re-override the text content of the Dimension.
Kent Cooper, AIA
