ATTRIBUTES TO DIMENSION LISP
shil143
shil143
I need Dimension between two attributes, From Selecting  Attributes. Please Refer Attached Drawing
imadHabash
i didn't think that you need dimensions between the attribute ( rectangles ) itself , you may mean the circles . if that what you asking for then you can do it by set Center Osnap on , then after preparing proper Dim style you can use dimaligned command . see below image . also you can not make dimensions by selecting and depending on this attributes .
Imad Habash
shil143
Hi Imadh,
i have more than 15000 attributes like this ....i need to do in easy way just select two attributes and get dimension as a text...........i know about dim align,..................
