Attribute/blocks
Attribute/blocks
Attribute/blocks
I have an attribute/block which I use to draw a lighting line. This lighting line is build up with a certain length which is multiplied each time to reach the required length. I have an attribute which I can extend to the required length and this attribute displays the length of each and every attribute after being extended.
What I want to add to this attribute is a name, for example, L1, L2,L3, ... And I wonder is there is a possibility to make this an automatic proces so the attribute itself will be giving names to the following lighting lines after this have been added to a drawing. Secondly, a lighting line had LED units which I want to add to this attribute, these LED units have a certain length. After these two feature have been added to the attribute I want this data to be extracted into a table.
So, to sum it up,
I want an attribute with the following features:
1. Attribute is able to extend to a certain length (already possible)
2. Attribute is able to automatically name the lighting lines starting by for example L1,...
3. Adding LED modules automatically to this lighting line, LED modules have a certain length
3. Being able to extract this data into a table.
I hope my explanation is clear enough. Hope you can help me with a solution.
Thank you everyone in advance!
JTBWorld
You need help by a programmer for this. There is a customization forum or if you can pay for it contact us at JTB World.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Sea-Haven
My and others crystal ball is broken so can not see what you want, post dwg.
Then if it gets to hard you may have to pay someone or wait till they have time to do something for you.
