ATTOUT with coordinates by LISP
I would like to use ATTOUT or something similar to export all the attributes of a set of dynamic blocks, but with the addition of x,y coordinates for each block.  I would like it to run on a selected set of blocks similar to ATTOUT.
Thanks for any help!
Edwin.Saez
@Anonymous,
You could do it with DATAEXTRACTION.
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
I was hoping to do it with LISP, but I don't really get how to extract the information from Dynamic Blocks using LISP, or if I can use the results of the ATTOUT command in a lisp script that goes and gets the x,y coordinates based on the block names (i.e. *U123).
