Attdef Not Usable From Entmake
mgorecki
mgorecki
I have the following code that creates a block (lwpolyline and attribute).  It seems to work just fine, in that the block gets created and inserted.  The problem is that the block gets inserted, but it doesn't ask for attribute information.  When I enter the attdef command and pick the block, I get, "Select block reference:  That block has no editable attributes."
Any ideas as to why the block attribute is not working?
(entmake (list '(0 . "BLOCK")
      '(100 . "AcDbEntity")
      '(67 . 0)
      '(8 . "0")
      '(100 . "AcDbBlockReference")
      (cons 2 blockName)
      '(10 0 0 0)
      '(70 . 0)
     (entmake
      (apply
       (function append)
       (cons (list '(0 . "LWPOLYLINE")
                   '(67 . 0)
                   '(410 . "Model")
                   (cons 8 objLayer)
                   '(100 . "AcDbPolyline")
                   (cons 90 (length newPointList)) ; Vertices
                   '(70 . 0)
                   '(70 . 1) ; Closed
             (mapcar (function list)
                     (mapcar (function (lambda (a) (cons 10 a))) newPointList)
                     (mapcar (function (lambda (b) (cons 42 b))) objBulgeList)
     (entmake
      (list '(0 . "ATTDEF")
            '(100 . "AcDbText")
            (cons 8 objLayer)
            '(10 0.0 0.0 0.0)
            (cons 40 attTextHgt)
            '(1 . "")
            '(100 . "AcDbAttributeDefinition")
            '(3 . "Enter Pad Number")
            '(2 . "PAD_NUM")
            '(70 . 0)
     (entmake (list '(0 . "ENDBLK")
      '(100 . "AcDbBlockEnd")
      '(8 . "0")
Mark
Ranjit_Singh
This works for me
               '(100 . "AcDbBlockBegin")
               '(8 . "0")
               '(10 0.0 0.0 0.0)
               (cons 2 blockName)
               '(70 . 2)))
(entmake (apply (function append)
                            '(67 . 0)
                            '(410 . "Model")
                            (cons 8 objLayer)
                            '(70 . 0)
                            '(70 . 1) ; Closed
                              (mapcar (function (lambda (b) (cons 42 b))) objBulgeList)))))
(entmake (list '(0 . "ATTDEF")
               '(100 . "AcDbText")
               (cons 8 objLayer)
               '(10 0.0 0.0 0.0)
               '(1 . "")
               '(2 . "PAD_NUM")
               '(70 . 0)))
               '(100 . "AcDbBlockEnd")))
mgorecki
Hello Ranjit,
Thank you for your help.  I see that I had '(70 . 0) for my block.  I changed it to '(70 . 2) and that seems to work.
Best regards,
Mark
Ranjit_Singh
Youa re welcome. Glad it worked for you.
