Attach material to layer by script or lisp or...?
With matbrowseropen and materialattach I can attach a material to a layer manually.
Is it possible to do this by script or lisp? that would be great!
cadffm
MATERIAL is one option of the LAYER command, so you can use command LAYER to set loaded materials to a layer.
(command "_.-LAYER" "_make" "TESTlayer" "_material" "Global" "TESTlayer" "")
Start -LAYER by hand and follow the commandline promts..
Sebastian
Mat coumad
Sea-Haven
Remove the make part for layers that exist, note though "make" is forgiving nad will be ignored if exists.
