attach field to attribute final value
Message 1 of 1
I have a block with an attribute & a text field that changes by the final value of this attribute. In this block there is also an inner block. I want to move the text field into the inner block instead of sitting in the outer one but I can't find a way to attach the field to the final value of the outer block attribute.
I can only attach the field to the attribute definition value bit it doesn't work when I cange this value from the drawing only from the block editor.. any ideas?? thanks!
Replies (0)
