Associate user input string to specific variable
Rob_Durham
Rob_Durham
Hi there,
I have defined a value to each date of the year
for example
(Setq 21/06/16 (441294067.896324))
(Setq 22/06/16 (443874734.960046))
The lisp routine prompts the user to enter a date in the format (dd/mm/yy)
(setq date (getstring "Enter date (dd/mm/yy) "))
How do I associate the string entered by the user to the specific value associated with that particular date in my list of variables?
For example the user enters: 21/06/16, how do I get it to use the value 441294067.896324 for use in other commands?
ВeekeeCZ
I would suggest something like this...
(defun c:test nil
  (setq dtelst '(("21/06/16" . 441294067.896324)
		 ("22/06/16" . 443874734.960046))
	dte (getstring "\nSet date: "))
  (cdr (assoc dte dtelst))
Or your way using variables...
> (setq 21/06/16 441294067.896324)
4.41294e+008
> (eval (read (getstring)))
> 21/06/16
4.41294e+008
Rob_Durham
Your first method worked perfectly.
Thank you
scot-65
Did you notice the variable created by BeeKee
did not begin with a number?
And the dotted-pair is quoted (meaning it is a STRING)
when the first character is a number?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
