Arrayrect Macro
Arrayrect Macro
davidschnegg7
Arrayrect Macro
davidschnegg7
I was trying to create a macro tool button for the rectangular array command.
My Goal:
Hit the macro tool button
Select an object to array
Default of 4 columns with a spacing of 4 inches
Default of 1 row
End command.
I can then manipulate the amount columns afterwards with the grips. And tweak the spacing in the ribbon if necessary.
So far I create a macro and tried this:
^C^C_arrayrect;col;4;4;r;1;1;;
It's only initiating the macro command, but not entering the column numbers I want.
I obviously don't know what I'm doing.
ВeekeeCZ
Try this? \ is for user input.
^C^C_arrayrect;\;@1,1;@1,1;col;4;4;r;1;1;;;
The command prompts run from a macro are slightly different than if run from the command line:
Select objects:
Type = Rectangular Associative = Yes
Specify opposite corner for number of items or [Base point/Angle/Count] <Count>: @1,1
Specify opposite corner to space items or [Spacing] <Spacing>: @1,1
Select grip to edit array or [ASsociative/Base point/Rows/Columns/Levels/eXit]<eXit>: col
Enter the number of columns or [Expression] <1>: 4
Specify the distance between columns or [Total/Expression] <1.879>: 4
Select grip to edit array or [ASsociative/Base point/Rows/Columns/Levels/eXit]<eXit>: r
Enter the number of rows or [Expression] <2>: 1
Specify the distance between rows or [Total/Expression] <1.000>: 1
Specify the incrementing elevation between rows or [Expresson] <0.000>:
davidschnegg7
Thank you so much!  It works perfectly now.
I appreciate the explanation for how you create the code.
pendean
Community Legend
Community Legend
davidschnegg7
Thank you for that link.  I was looking for that information today when I was tinkering.
pendean
Community Legend
Community Legend
You're welcome. here is a tip from an old-timer like me: avoid using spaces for <enter> if you are ever tempted, a semi-colon is easier to see and count when you need to fix an errant macro 🙂
Sea-Haven
Have you thought about a lisp can have a front end dcl where you enter all the values, so pick object/s and fill in info. The dcl can have default values preset.
