Arranging multiple polylines inside a polyline
Purus_Cdds
Purus_Cdds
I have few polylines in a drawing. I want them to be arranged to the standard sheet size available in the market.
Please check the image below.
I want to know the good way to handle this. I created bounding box for each piece but it is not working in some area as i marked in the image below, How to check if there is enough space for next piece? if there is no enough space move to next sheet.
Thank you,
marko_ribar
Here are couple of links for you to study...
(perhaps you must log on to view all pictures and have access to download attachments...)
http://www.theswamp.org/index.php?topic=52260.0
http://www.theswamp.org/index.php?topic=51825.0
http://www.theswamp.org/index.php?topic=12296.0
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Purus_Cdds
Thank you so much!
I tried the code. Circle is not fitting inside the polygon even though there is space. I will try to update the code to match my requirement. if I am stuck, will come back here.
Also, The  boundary rectangle needs to be created until no nesting polygon. will try that as well.
It is a great help.
Many Thanks.
Sea-Haven
Google nesting Autocad
Its like crystal balls hard to find a good one.
