area capacity table
area capacity table
djohnson
Message 1 of 12
area capacity table
djohnson
I was wondering if anyone could take this lisp routine and clean it up and bring it into lisp standards of today.  this thing was cobbled together back in the early 90's and its a mess.  it is used for calculating the capacity of a reservoir.
it has the user select closed polylines (contours) in ascending order - lowest elevation to highest (can we have it so you just select all the polylines at once)
it only recognizes heavyweight polylines. (dont know how to make it work with lightweight)
then it builds a table with the incremental capacity of the reservoir. (the table has double linework).
the error handling is not very good either (text rotation and snaps can screw it up)
i started looking at it and my head was swimming in five minutes.
this thing is a mess and way beyond my abilities
ive attached the lisp routine and an example drawing
Replies (11)
Message 2 of 12
john.uhden
Wow.  That looks older than my oldest work (and that's old).
I see you are using the average end area method instead of the truncated prism method...
Inc. Vol. =  (A1 + A2 + (A1*A2)^0.5) / 3
I could create a list of lists that contain all the values as strings and then someone else here could create the table function (because I have only 2002 at home, which doesn't have tables).  Plus, we could make it to take a selection set of heavies and/or lights and sort them by ascending elevation, plus they can have bulged segments.  Does any of your containment shapes come to a point at the bottom, or do they all have a lowest polyline, meaning a flat bottom?  Are all your polylines closed?  What's the purpose of writing a file (other than to read what you just wrote?
John F. Uhden
Message 3 of 12
djohnson
John
Lol. This is very old and I do think it has a bunch of stuff that's not needed.
Im not looking for an acad table, the one that it generates is fine. Which is just text and linework.
The containment shapes will vary, so, yes, most of the time they would come to a point, the drawing is just to test things out.
The selection set with heavy or light polylines would help the process out a lot. Not sure what you mean by bulged segments.
All polylines need to be closed for it to calculate the capacity correctly.
Not sure why it creates and reads from the file verses just storing it. It has me scatching my head a lot.
Hope that helps.
Thanks for looking at it
Dave
Message 4 of 12
john.uhden
Thanks for enjoying my initial comment.  I find life to be dull without sufficient humor.
In newer releases of AutoCAD (not my 2002), tables are very convenient not only to populate programmatically, but to adjust their size and position and even edit.  One of my very old programs created  a table-looking collection of lines and text which by today's standards is archaic (though I just used it recently for a real project).  By bulged segments I mean polyline segments that are curved, actually arced.  It really doesn't matter because AutoCAD can report their area without any calculations.
BTW, the truncated prism method is more conservative, which I prefer.  I would always use it to compute detention basin volumes for hydrograph routings.  I wrote my own software for computing all that stuff long before hydrologic/hydraulic packages came along.
John F. Uhden
Message 5 of 12
djohnson
I don’t think I would make it through the day without humor (sometimes I take it too far though)
The reason for the average end area is, that is how the state has historically done it and thats how they check our work,  so we need to stick with that method.
that's what i thought you meant, but wasn't sure. Currently we cannot have arcs in our polylines with that routine so that would be a nice feature as well.
the use of tables is not a bad idea but I would want it to look very similar to the table that the routine kicks out now just because its what everyone is used to seeing and i have no idea how to do that.  I can do a little lisp but have not kept up with it like i should
Message 6 of 12
john.uhden
How about if you use the TABLE command to see what the results look like?  Otherwise I won't be able to play with little project until at least Sunday.
John F. Uhden
Message 7 of 12
djohnson
i am actually modifying this dang routine now to report barrels instead of ac-ft. maybe once i get it done i will be able to look at the autocad table, but i wont finish till next week since im wrapping up the day right now.
they really ask to much from a rookie like me.  LOL
Message 8 of 12
john.uhden
@djohnson wrote, "they really ask too much from a rookie like me.  LOL"
Maybe so, but if they never ask then you never get a chance to respond.
John F. Uhden
Message 9 of 12
joselggalan
Try this new version:
How to use:
Command: ACAP2
1. Select impoundment contours.
     The program will only select polylines closed (2DPolyline and LWPolyline)
2. Pick normal water line.
3. Pick point to locate table.
4. Text Height for a table.
Attached Lisp File and DWG Testing
Here the code:
(vl-load-com)
;;********************************** C:ACAP2 **************************************;;
;; Jose L. García G. -  30/09/17                                                   ;;
;; For forums.autodesk.com (djohnson and john.uhden)                               ;;
;; Description: Calulates area of polylines in acres, determins elevation,         ;;
;;              computes area-capacity table & creates object table in dwg.        ;;
(defun C:ACAP2 ( / *acad* *adoc* ActSpace filter sty_Tbl_Name *tableStyles* LstDatos PtTable NormalWaterLine
                   RowHeight ColWidth oCol *TableIns* nRow nCol Tot_ACCUM elevNWL NWL_ACCUM
		   ;|functions|; MakeTableStyle jlgg-rtos GetDatosPols
 	;;____________________________________________________________;;
 	;; Collects and sorts data of polylines
	(defun GetDatosPols ( / filter ss lstPols ACCUM LASTAREAR LASTELEV cnt TotDat)
	 ;;Select closed polylines:
	 (prompt "\nSelect impoundment contours: ")
	 (setq filter '((0 . "*POLYLINE")(-4 . "<OR") (70 . 1)(70 . 129)(-4 . "OR>")))
	 (setq ss (vl-catch-all-apply 'ssget (list filter)))
	 (cond
	  ((vl-catch-all-error-p ss))
	  ((not ss)(prompt "\nNot select polylines.."))
	  (t
	   (setq lstPols  (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
	   (setq lstPols (mapcar (function vlax-ename->vla-object) lstPols))
	   (setq lstPols
	    (mapcar
	     (function (lambda (oPol) (cons (vla-get-Elevation oPol) oPol)))
	     lstPols
	   (setq lstPols
	    (vl-sort
	     lstPols
	     (function (lambda (pr1 pr2)(< (car pr1)(car pr2))))
	   (setq ACCUM 0.0)
	   (setq LASTAREAR 0.0)
	   (setq LASTELEV 0.0)
	   (setq cnt 0)
	   (mapcar
	    (function
	     (lambda (Elev-Pol / elev oPol area AreaR AvgArea Incr tmpLst1)
	      (setq oPol  (cdr Elev-Pol))
	      (setq elev  (car Elev-Pol))
	      (setq tmpLst1 (cons (cons "ELEV" elev) tmpLst1))
	      (setq area  (vla-get-Area oPol))
	      (setq tmpLst1 (cons (cons "AREA" area) tmpLst1))
	      (setq AreaR (/ area 43560.0))
	      (setq tmpLst1 (cons (cons "AREAR" AreaR) tmpLst1))
	      (cond
	       ((> cnt 0)
		(setq AvgArea (/ (+ LASTAREAR AreaR) 2.0))
		(setq tmpLst1 (cons (cons "AVGAREA" AvgArea) tmpLst1))
		(setq Incr (* (- elev LASTELEV) AvgArea))
		(setq tmpLst1 (cons (cons "INCR" Incr) tmpLst1))
		(setq ACCUM (+ ACCUM Incr))
	       (T (setq cnt 1))
	      (setq tmpLst1 (cons (cons "ACCUM" ACCUM) tmpLst1))
	      (setq TotDat (append TotDat (list (reverse tmpLst1))))
	      (setq LASTAREAR AreaR)
	      (setq LASTELEV elev)
	    lstPols
	   );c.mapcar
	 );c.cond
	 TotDat
	);c.defun
 	;; rtos estable
	(defun jlgg-rtos ( real units prec / dimzin result )
	 (if (not prec)(setq prec (getvar "luprec")))
	 (if (not units)(setq units (getvar "lunits")))
	 (setq dimzin (getvar 'dimzin))
	 (setvar 'dimzin 0)
	 (setq result (vl-catch-all-apply (function rtos) (list real units prec)))
	 (setvar 'dimzin dimzin)
	 (if (not (vl-catch-all-error-p result))
	  result
 	;; Make Table Style
	(defun MakeTableStyle (Alt_Txt NameStyTbl
			       *acad* *adoc* *TextStyles* *tableStyles* *tblTtxt* StyleTxt
			       dimscale$ TitleHTxt HeaderHTxt DataHTxt cellmarginV cellmarginH
			       TitleSuppressed HeaderSuppressed oStyTable oCol
	 (setq StyleTxt "TABLE_CAPACITY")
	 (vl-cmdf "_.style" StyleTxt "ROMANS" "0" "1" "0" "" "" "")
	 (setq *acad*(vlax-get-acad-object)
	       *adoc*	    (vla-get-activedocument *acad*)
	       *TextStyles* (vla-get-TextStyles     *adoc*)
	 ;;Datos de Estilo de Tabla
	 (setq dimscale$ 1.0);;(/ 1.0 (* 1000 (/ 1.0 Esc_Plot))))
	 (setq TitleHTxt   (* (* Alt_Txt 1.75) dimscale$)
	       HeaderHTxt  (* Alt_Txt dimscale$)
	       DataHTxt    (* Alt_Txt dimscale$)
	       cellmarginV (* Alt_Txt 0.5 dimscale$)
	       cellmarginH (* Alt_Txt 0.75 dimscale$)
	       TitleSuppressed nil
	       HeaderSuppressed nil
	 (setq *tableStyles* (vla-item (vla-get-dictionaries *adoc*) "acad_tablestyle"))
	 ;;Estylo de Tabla y diccionario de Tabla:
	 (setq oStyTable (vla-addObject *tableStyles* NameStyTbl "AcDbTableStyle"))
	 (cond
	  ((vl-catch-all-error-p oStyTable)
	   (prompt (strcat "\nCould not create Table style: [" NameStyTbl "]."))
	   (setq oStyTable nil)
	  (T
	   ;;propiedades de texto
	   (vla-SetTextHeight oStyTable acTitleRow TitleHTxt)
	   (vla-SetTextHeight oStyTable acHeaderRow HeaderHTxt)
	   (vla-SetTextHeight oStyTable acDataRow  DataHTxt)
	   (vla-SetTextStyle  oStyTable acHeaderRow StyleTxt)
	   (vla-SetTextStyle  oStyTable acTitleRow StyleTxt)
	   (vla-SetTextStyle  oStyTable acDataRow StyleTxt)
	   (vla-SetAlignment  oStyTable acDataRow acBottomRight)
	   (vla-SetAlignment  oStyTable (+ acTitleRow acHeaderRow) acMiddleCenter)
	   (vla-put-Vertcellmargin oStyTable cellmarginV)
	   (vla-put-Horzcellmargin oStyTable cellmarginH)
	   (vla-put-TitleSuppressed  oStyTable (if TitleSuppressed  :vlax-false :vlax-true))
	   (vla-put-HeaderSuppressed oStyTable (if HeaderSuppressed :vlax-false :vlax-true))
	   ;;fondos y color
	   (setq oCol (vla-getinterfaceobject
		       (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
	   ;;Titulo:
	   (vla-put-ColorMethod oCol acColorMethodByRGB)
	   (vla-SetRGB oCol 163 163 163)
	   (vla-SetBackgroundColor oStyTable acTitleRow oCol)
	   (vla-SetRGB oCol 255 255 255)
	   (vla-SetColor oStyTable acTitleRow oCol)
	   ;;Encabezados
	   (vla-SetRGB oCol 222 222 222)
	   (vla-SetBackgroundColor oStyTable acHeaderRow oCol)
	   (vla-SetRGB oCol 28 28 28)
	   (vla-SetColor oStyTable acHeaderRow oCol)
	   ;;Datos
	   (vla-SetBackgroundColorNone oStyTable acDataRow :vlax-true)
	   (vla-put-ColorMethod oCol acColorMethodByACI)
	   (vla-put-ColorIndex oCol 7)
	   (vla-SetColor oStyTable acDataRow oCol)
	 );c.cond
	 oStyTable
 ;;--------------------------- MAIN PROGRAM -------------------------------
 (or *Alt_Txt_Table* (setq *Alt_Txt_Table* 3.0))
 (setq *acad* (vlax-get-acad-object)
       ActSpace (vlax-get-property *adoc* (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
 (cond
  ((not (setq LstDatos (GetDatosPols))))
  ((and (not (prompt "\nPick normal water line: "))
	 (setq NormalWaterLine (vl-catch-all-apply 'ssget (list "_:S:E" Filter))))
  ((not NormalWaterLine)(prompt "\nNo select normal water line."))
    (setq PtTable (vl-catch-all-apply 'getpoint (list "\nPick point to locate table: ")))
  ((not PtTable)(prompt "\nNo point has been indicated."))
  ((and (not (initget (+ 2 4)))
	 (setq Tmp (vl-catch-all-apply 'getdist
		    (list (strcat "\nText Height: <" (jlgg-rtos *Alt_Txt_Table* nil nil) ">: "))))
  (T
   (if Tmp (setq *Alt_Txt_Table* Tmp))
   (setq NormalWaterLine (ssname NormalWaterLine 0)
	 NormalWaterLine (vlax-ename->vla-object NormalWaterLine))
   (setq elevNWL (vla-get-elevation NormalWaterLine))
   (setq sty_Tbl_Name (strcat "TBL_HTxt_" (jlgg-rtos *Alt_Txt_Table* 2 2)))
			 (vla-get-activedocument (vlax-get-acad-object))) "acad_tablestyle"))
   (if (vl-catch-all-error-p
	(setq oStyTable (vl-catch-all-apply 'vla-item (list *tableStyles* sty_Tbl_Name)))
    (setq oStyTable (MakeTableStyle *Alt_Txt_Table* sty_Tbl_Name))
   (cond
    ((not oStyTable))
    (T ;;Create table:
     (vla-startundomark *adoc*)
     (setq RowHeight (* *Alt_Txt_Table* 3.0))
     (setq ColWidth (* *Alt_Txt_Table* 10.0))
     ;;Insert Table
     (setq *TableIns* (vla-addTable ActSpace (vlax-3d-point PtTable) 4 7  RowHeight ColWidth))
     (vla-put-regeneratetablesuppressed *TableIns* :vlax-true)
     (vla-put-StyleName *TableIns* sty_Tbl_Name)
     ;;Title:
     (vla-setText *TableIns* 0 0 "AREA CAPACITY TABLE")
     ;;Headers:
     (vla-MergeCells *TableIns* 1 2 0 0)
     (vla-setText *TableIns* 1 0  "CAPACITY")
     (vla-MergeCells *TableIns* 1 2 1 1)
     (vla-setText *TableIns* 1 1 "ELEVATION\n\n(ft)")
     (vla-MergeCells *TableIns* 1 2 2 2)
     (vla-setText *TableIns* 1 2 "AREA\n\n(ac)")
     (vla-MergeCells *TableIns* 1 2 3 3)
     (vla-setText *TableIns* 1 3 "AVG.\nAREA\n(ac)")
     (vla-SetCellStyle *TableIns* 2 4 "_HEADER");"_DATA"
     (vla-SetCellStyle *TableIns* 2 5 "_HEADER")
     (vla-MergeCells *TableIns* 1 1 4 5)
     (vla-setText *TableIns* 1 4 "CAPACITY (ac-ft)")
     (vla-setText *TableIns* 2 4 "INCR.")
     (vla-setText *TableIns* 2 5 "ACCUM.")
     (vla-MergeCells *TableIns* 1 2 6 6)
     (vla-setText *TableIns* 1 6  "INDUSTRIAL\nPOLLUTION\nCONTROL")
     ;;Datos:
     (setq nRow 3 nCol 1)
     (vla-insertrows *TableIns* nRow RowHeight (1- (length LstDatos)))
     (mapcar
      (function
       (lambda (lData / nCol ELEV AREA AREAR AVGAREA INCR ACCUM)
	;;lData = (("ELEV" . 6806.0) ("AREA" . 77248.7) ("AREAR" . 1.77339)
	;;         ("AVGAREA" . 1.71588) ("INCR" . 3.43176) ("ACCUM" . 3.43176))
	(setq nCol 1)
	(mapcar (function (lambda (pair) (set (read (car pair))(cdr pair)))) lData)
	(if (equal elevNWL ELEV 1.0e-04)
	 (setq nRowNWL nRow
	       NWL_ACCUM ACCUM)
	(vla-setCellValue *TableIns* nRow nCol ELEV)
	(vla-SetCellDataType *TableIns* nRow nCol acDouble acUnitless)
	(vla-SetCellFormat *TableIns* nRow nCol "%lu2%pr1")
	(vla-setCellValue *TableIns* nRow (+ nCol 1) AREAR)
	(vla-SetCellDataType *TableIns* nRow (+ nCol 1) acDouble acUnitless)
	(vla-SetCellFormat *TableIns* nRow (+ nCol 1) "%lu2%pr2")
	(if AVGAREA
	 (progn
	  (vla-setCellValue *TableIns* nRow (+ nCol 2) AVGAREA)
	  (vla-SetCellDataType *TableIns* nRow (+ nCol 2) acDouble acUnitless)
	  (vla-SetCellFormat *TableIns* nRow (+ nCol 2) "%lu2%pr2")
	(if INCR
	 (progn
	  (vla-setCellValue *TableIns* nRow (+ nCol 3) INCR)
	  (vla-SetCellDataType *TableIns* nRow (+ nCol 3) acDouble acUnitless)
	  (vla-SetCellFormat *TableIns* nRow (+ nCol 3) "%lu2%pr2")
	(vla-setCellValue *TableIns* nRow (+ nCol 4) ACCUM)
	(vla-SetCellDataType *TableIns* nRow (+ nCol 4) acDouble acUnitless)
	(vla-SetCellFormat *TableIns* nRow (+ nCol 4) "%lu2%pr2")
	(setq Tot_ACCUM ACCUM)
	(setq nRow (1+ nRow))
      LstDatos
     );c.mapcar
     (setq nRowTot (1- nRow))
     (vla-SetRGB oCol 255 117 117)
     ;(vla-setText *TableIns* nRowNWL 0 "<--->")
     (vla-SetCellGridVisibility *TableIns* nRowNWL 0 (+ acBottomMask acTopMask) :vlax-false)
     (vla-setcellalignment *TableIns* nRowNWL 0 acMiddleCenter)
     (vla-SetCellBackgroundColor *TableIns* nRowNWL 0 oCol)
     ;(vla-setText *TableIns* nRowNWL 6 "<--->")
     (vla-SetCellGridVisibility *TableIns* nRowNWL 6 (+ acBottomMask acTopMask) :vlax-false)
     (vla-setcellalignment *TableIns* nRowNWL 6 acMiddleCenter)
     (vla-SetCellBackgroundColor *TableIns* nRowNWL 6 oCol)
     (cond
      ((not (vl-catch-all-error-p
	     (vl-catch-all-apply 'vla-MergeCells (list *TableIns* 3 (1- nRowNWL) 0 0))))
       (vla-put-ColorIndex oCol 1)
       (vla-setText *TableIns* 3 0  (strcat "INACTIVE\n" (jlgg-rtos NWL_ACCUM 2 2) " ac-ft"))
       (vla-SetCellTextHeight *TableIns* 3 0 (* *Alt_Txt_Table* 0.75))
       (vla-setcellalignment *TableIns* 3 0 acMiddleCenter)
       (vla-SetCellContentColor *TableIns* 3 0 oCol)
       (vla-MergeCells *TableIns* 3 (1- nRowNWL) 6 6)
       (vla-setText *TableIns* 3 6
	(strcat "SEDIMENT\nSTORAGE\n" (jlgg-rtos NWL_ACCUM 2 2) " ac-ft")
       (vla-SetCellTextHeight *TableIns* 3 6 (* *Alt_Txt_Table* 0.75))
       (vla-setcellalignment *TableIns* 3 6 acMiddleCenter)
       (vla-SetCellContentColor *TableIns* 3 6 oCol)
     (cond
	     (vl-catch-all-apply 'vla-MergeCells (list *TableIns* (1+ nRowNWL) nRowTot 0 0))))
       (vla-put-ColorIndex oCol 3)
       (vla-setText *TableIns* (1+ nRowNWL) 0
	(strcat "ACTIVE\n" (jlgg-rtos (- Tot_ACCUM NWL_ACCUM) 2 2) " ac-ft")
       (vla-SetCellTextHeight *TableIns* (1+ nRowNWL) 0 (* *Alt_Txt_Table* 0.75))
       (vla-setcellalignment *TableIns* (1+ nRowNWL) 0 acMiddleCenter)
       (vla-SetCellContentColor *TableIns* (1+ nRowNWL) 0 oCol)
       (vla-MergeCells *TableIns* (1+ nRowNWL) nRowTot 6 6)
       (vla-setText *TableIns* (1+ nRowNWL) 6
	(strcat "DUST\nABATEMENT\n" (jlgg-rtos (- Tot_ACCUM NWL_ACCUM) 2 2) " ac-ft")
       (vla-SetCellTextHeight *TableIns* (1+ nRowNWL) 6 (* *Alt_Txt_Table* 0.75))
       (vla-setcellalignment *TableIns* (1+ nRowNWL) 6 acMiddleCenter)
       (vla-SetCellContentColor *TableIns* (1+ nRowNWL) 6 oCol)
     (vla-put-regeneratetablesuppressed *TableIns* :vlax-false)
     (vla-endundomark *adoc*)
    );Create table.
   );c.cond
 );c.cond
 (princ)
);c.defun
regards
Message 10 of 12
john.uhden
Wow!  That's a lot of code, but the result is great!
Looks a a little "newer" than the original.
John F. Uhden
Message 11 of 12
djohnson
wow.  this does look  good.  I will dive into it and try to make some changes to it, like adding the total capacity at the bottom along with some line and color changes.
this really gives me a head start.
thanks
Dave
Message 12 of 12
djohnson
ha.  that's true,  and it makes me look at and stumble though code.  just about got the other modifications done to that routine.  now i will have to do it to the one Jose did.
thanks for the help.
Dave
