Area Adjust "ArqAdjustArea"
lee_cheniere
Message 1 of 14
lee_cheniere
Looking for an lisp/addin that will adjust a closed polyline to and defined sq. footage.
Used one call ArqAdjustArea by Woopaloo but is is no long available in the app store...
Link to video of this old app
Replies (13)
Message 2 of 14
Sea-Haven
lee-mac.com has a good area lisp and it uses fields so if adjust pline area adjusts.
Message 3 of 14
lee_cheniere
Yeah I browsed all his LSP files and none do what that LSP could do, unfortunately, I guess it will be lost forever.
That was such a great LSP should have backed it up dagggggggg it.
Message 4 of 14
ВeekeeCZ
You can try to contact the developer by email from HERE
Message 5 of 14
lee_cheniere
I have no REPLY... 😞
Message 6 of 14
ronjonp
Give this a try:
(defun c:scaletoarea (/ _getarea a a2 ll o s ur)
  ;; RJP » 2020-06-30
  (defun _getarea (e / a)
    (if	(vl-catch-all-error-p (setq a (vl-catch-all-apply 'vlax-curve-getarea (list e))))
      0
      a
  (if (and (setq s (ssget ":L")) (setq a (getreal "\nEnter desired area: ")))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
      (if (> (setq a2 (_getarea e)) 0)
	(progn (vla-getboundingbox (setq o (vlax-ename->vla-object e)) 'll 'ur)
	       (setq ll (mapcar '+ (vlax-safearray->list ll) (vlax-safearray->list ur)))
	       (vlax-invoke o 'scaleentity (mapcar '/ ll '(2 2 2)) (sqrt (/ a a2)))
  (princ)
Message 7 of 14
lee_cheniere
Beggars can't be choosers. that works pretty well.
Still going to miss the ability to pick what edge to move to get the desired shape.
Thanks...
Message 8 of 14
ronjonp
Thanks...
Glad you can use it. 🙂
Just watched the video .. that would be quite a bit more complicated to code.
Message 9 of 14
TomBeauford
This works pretty well: https://www.cadtutor.net/forum/topic/70140-lisp-to-scale-by-moving-only-one-side/page/2/?tab=comment...
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 10 of 14
Sea-Haven
In land development software there are a number of lot creation tools. Like move side, swing line, frontage, all resulting in matching required area. I know these used to be in Civilcad software many years ago. Not sure if CIV3D has some. Has been asked before. The link is very close for moving 1 side.
Message 11 of 14
nasir_sons
I have it but not compatible with latest AutoCAD versions, need to update...
Message 12 of 14
Sea-Haven
That leads to a msi installer I dont ever run those from forums like here same with VLX code as you have no idea what it does. Do you have a unpacked version.
Message 13 of 14
nasir_sons
Thank for reply, yes i have but it say the file type is not supported here...
Message 14 of 14
genbel
Observer
Observer
buongiorno, gentilmente mi puoi dire qualcosa su arqadjustArea: sei riuscito ad avere una versione decompressa?
l'installazione del msi mi da solo un file.fas
