Are Field msq
Are Field msq
jyan2000
Are Field msq
jyan2000
Hi to Form ,
I found a lisp which is giving area filed  from LeeMac. Is it possible to add / change value to msq ("S:
m² " ) and also primitive ( "L : m")
Best Regards
Victor.
Moshe-A
@jyan2000 hi,
check this fix
Moshe
jyan2000
Thank you very much for rapid reply.. my request almost there, however I need little adjustment as in attached image.
Best Regards
Victor
Moshe-A
@jyan2000 ,
fixed.
A close pline doesn't have a perimeter property and i am not absolutely sure but a field as far as i know can address only one property at a time (hope i'm not wrong 🤔)
Moshe
jyan2000
Thank you again. The Command works perfect for Area field.. I've seen this ;
%<\AcObjProp.16.2 Object(%<\_ObjId 1836156358224>%).Area \f "%lu6%qf1%ps[S: , m²]%ct8[0.0001]">%
%<\AcObjProp.16.2 Object(%<\_ObjId 1836156386896>%).Length \f "%lu2%pr2%ps[L: , m]%ct8[0.01]">%
Under field expression. So I understand Area field give Length and Area as well.. If u could help me to Solve this issue Big thanx to u.
Regards.
Victor
Moshe-A
Yes you are right
fixed
jyan2000
Thats it.. Thank u very much .. That was what I was looking.. U saved my life..
Best regars ..
Victor
