AppendInner(Outer)Loop throws an exception when passing in an object (an array of member type object)
1605027848
1605027848
     First of all, I would be very grateful if you can reply to my question!
     I am Using COM API to Programming!
     Now, I am Append a Hatch, this is my code:
Protected Sub DealHatch(ByRef HoleHatch As Object,
                            strHatchName As String,
                            Optional objCicle As Object = Nothing,
                            Optional dBottomEndPoint As Double() = Nothing,
                            Optional dUpperEndPoint As Double() = Nothing
        If TypeName(HoleHatch) <> "Nothing" Then
            If Left(strHatchName, 1) = "半" Then
                Dim dArcCenterPoint() As Double = {dUpperEndPoint(0), (dUpperEndPoint(1) + dBottomEndPoint(1)) / 2, 0}
                Dim dArcRadius As Double = (dUpperEndPoint(1) - dBottomEndPoint(1)) / 2
                Dim objLine As Object = AcModelSpace.AddLine(dUpperEndPoint, dBottomEndPoint)
                Dim objArc As Object = AcModelSpace.AddArc(dArcCenterPoint, dArcRadius, Math.PI / 2, 3 * Math.PI / 2)
                'The commented code can run correctly
                'Dim OuterLoop As Object = New AcadEntity() {objLine, objArc}
                'HoleHatch.AppendOuterLoop(OuterLoop)
                'HoleHatch.AppendInnerLoop(objCicle)
                'But the following code cannot run correctly, it throws an exception
                'The only difference is that the array member types of OuterLoop are different.
                Dim OuterLoop As Object = New Object() {objLine, objArc}
                HoleHatch.AppendOuterLoop(OuterLoop) 'Throw an exception. "Object Array Invalid!"
                'The combination of objLine and objArc is the semicircle of objCicle
                HoleHatch.Evaluate()
                AcDocument.Regen(True)
            Else
    End Sub
       You will find that I define all AutoCAD data types as Object, because of the compatibility of the CAD version(this is the only way I can think of). But it is because of this Object that my program is stuck in this place.
       So where is the problem? I thought for a long time, and of course I checked the content in the forum, but I didn’t find such a problem.
       Thank you very much for answering my question!
I'm very sorry, I uploaded the wrong forum category. This is a problem encountered in .NET development, not a problem encountered in Lisp development.
