API to apply terminal data
james.mcmillanNYR6A
james.mcmillanNYR6A
Writing a lisp to insert terminals.
Is there an API to apply the terminal xdata (levels, connections etc)? I figure this would be the equivalent of wd_get_pinlist / wd_pinlist_attach. Anything to save me writing the xdata?
sorry if this is very obvious I've been looking for ages
Sea-Haven
Need a lot more info not all of us do electrical but are capable of writing a solution. Need a dwg at least.
james.mcmillanNYR6A
Thanks for the response, I'm half capable of writing a solution myself but feel like I shouldn't have to...
When assigning catalogue information to a terminal through either insert component dialogue or TSE, electrical will automatically update the xdata from the database Levels (LTOTAL)/ Leveldescription (L01LABEL/L02LABEL) / Wires per connection (L01WIREPERC/L02WIREPERC) fields
I'm inserting the terminal using wd_insym2 and updating the the tagstrip and catalogue info using wd_modattrval
If I were inserting a component I could use the wd_pinlist_attach api to attach the pinlist xdata, and thought there should be something similar for terminals.
I thought this might be the right place to ask but will also try in the electrical forum. I could attach a drawing, but it would only have a standard schematic terminal on it. If I assigned the catalogue info using the dialogue then the xdata would already be present.
james.mcmillanNYR6A
