Any way to match text layer to hatch below?
The challenge is:
I have multiple single text over multiple hatches, I need to match each text layer to the hatch under it.
Then, is there a way to create boundaries of multiple hatches (now on different layers) while each hatch boundary is on the equivalent hatch layer?
dbhunia
Post sample drawing ....... with pointing out your points...
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
This should clears it.
Thank you anyways.
dbhunia
Try this..........Use CHHL.....
(defun c:CHHL (/ lst l1 ss Data DataT N N1)
(setvar 'cmdecho 0)
(princ "\nSelect Hatch...")
(setq selectionset (ssget '((0 . "HATCH"))))
(setq osm (getvar 'osmode))
(setvar 'osmode 0)
(repeat (setq N (sslength selectionset))
	(setq Data (ssname selectionset (setq N (- N 1))))
	(setq lst (Poly_Cor_Extr 10 (entget Data)))
	(setq l1 (remove-at lst (- (length lst) 1)))
	(setq l1 (remove-at l1 0))
	(setq ss (ssget "_CP" l1 '((0 . "TEXT"))))
	   (repeat (setq N1 (sslength ss))
		(setq DataT (ssname ss (setq N1 (- N1 1))))
		(entmod (subst (assoc 8 (entget DataT)) (assoc 8 (entget Data)) (entget Data)))
	(command "_pline")
	(while (= (getvar "cmdactive") 1 )
	(repeat (setq x (length l1))
		(command (nth (setq x (- x 1)) l1))
	(command "C")
	(entmod (subst (assoc 8 (entget Data)) (assoc 8 (entget (entlast))) (entget (entlast))))
(setvar 'osmode osm)
(setvar 'cmdecho 1)
(princ)
(defun Poly_Cor_Extr (key cor / val cor_list)
   (foreach val cor
	(if (eq key (car val)) (setq cor_list (cons (cdr val) cor_list)))
(reverse cor_list)
(defun remove-at (lst pos / head)
  (repeat pos
     (setq head (cons (car lst) head)
           lst (cdr lst)
(append (reverse head) (cdr lst))
Debashis Bhunia
Anyway to make this lisp ignore hatches that have no text above them? instead of stopping and throwing an error.
Thanks again, it was very helpful.
dbhunia
Try this...
(setvar 'cmdecho 0)
(setvar 'osmode 0)
	(if (/= nil (setq ss (ssget "_CP" l1 '((0 . "TEXT")))))
	    (progn
	   	(command "_pline")
	   	(command "C")
(setvar 'cmdecho 1)
(princ)
   (foreach val cor
(reverse cor_list)
  (repeat pos
           lst (cdr lst)
Debashis Bhunia
