rrename.vlx does not work, at least for me. (AutoCAD 2020)
I tried to:
find: (.+)(MAC|MED|EIC|ED|MEB|MSC|ECA)
replace: $2-$1$2
PD: please tell me if I'm doing something bad
https://www.cadforum.cz/cadforum_en/rename-on-steroids-complex-renaming-of-autocad-objects-tip9265
Solved by ronjonp. Go to Solution.
Solved by Ajilal.Vijayan. Go to Solution.
Here is my free tool to rename all types of Blocks.
https://autolispprograms.wordpress.com/rename-a-block/
Can you give example of text, which you want to apply this regex expression ?
Looks like the find expression needs to be changed.
yes.
here are a group of layer names, I have more than 1000 layer that need be renamed, all of those are recycled, so those have the same structure, I know a bit of regex thanks to "notepad++" but I can not work "rrename.vlx"
EQ_10$0$1.0 JTM EQ$0$JTM_ED EQ_10$0$1.0 JTM EQ$0$JTM_EIC EQ_10$0$1.0 JTM EQ$0$JTM_JTM LEYENDA EQ$0$MAD EQ_10$0$1.0 JTM EQ$0$JTM_JTM-ECA EQ_10$0$1.0 JTM EQ$0$JTM_JTM_10_JTM_10 EQ_10$0$1.0 JTM EQ$0$JTM_MAC EQ_10$0$1.0 JTM EQ$0$JTM_MAD EQ_10$0$1.0 JTM EQ$0$JTM_MEB EQ_10$0$1.0 JTM EQ$0$JTM_MOB ADM COMPRADO EQ_10$0$1.0 JTM EQ$0$JTM_MODIFICACIONES OCCIDENTE EQ_10$0$1.0 JTM EQ$0$JTM_MSC EQ_10-MSC
I need to match any layer that ends with mac, med, eic, ed, msc, eca.
replace: $2-$1$2
I need swap between $1 and $2
In notepad++ I should use \1 and \2, so maybe this VLX use another regex class?
final result should be:
. . . MSC-EQ_10-
@_Tharwat wrote:Here is my free tool to rename all types of Blocks.
thanks for sharing your app, but I need to rename layers.
anyway, thanks for your help
try this expression
find : (.{0,5})(.+)(MAC|MED|EIC|ED|MEB|MSC|ECA)
replace : $3-$1-
Need oldname , newname in a text file with a "," separator then very easy.
Alan,Alan-new
t,t-new
XYZ,POINTS
This may be helpful change file path.
(defun c:test ( / fo doc lay) (setq fo (open "d:\\acadtemp\\layers.txt" "w")) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lays (vla-get-Layers doc) (princ "\n") (princ (setq lay (vla-get-name lays) )) (write-line (strcat lay ",-") fo) ) (close fo) ) (c:test)
@Ajilal.Vijayan wrote:try this expression
replace : $3-$1-
thanks for your help friend.
I tried your suggestion, but I had no results.
I understand that "(.{0,5})(.+)(MAC|MED|EIC|ED|MEB|MSC|ECA)" its equivalent to "(.+)(MAC|MED|EIC|ED|MEB|MSC|ECA)" , so probably "rrename.vlx" need to update to autocad 2020, or we are doing something bad.
here is the command prompt:
Command: (LOAD "C:/Users/jtm2019hyo/Google Drive/@Programing/@CAD/LSP-VLX/RENAME/REGEX/RRename - rename layouts, blocks, layers or linetypes using regular expressions (VLX Lisp for AutoCAD)/RRename.VLX") RRename command loaded. (C)2014, CAD Studio - www.cadstudio.cz ______ CAD, PLM, GIS/FM custom application development ________ nil Command: RRENAME Rename [Blocks/Layers/lineTypes/layOuts] <layOuts>: *Cancel* Rename [Blocks/Layers/lineTypes/layOuts] <layOuts>: Use () and $1 for regular expressions, # as counter Source substring or regex to find (e.g. '(.+)'): (.{0,5})(.+)(MAC|MED|EIC|ED|MEB|MSC|ECA) Target substring or regex to replace (e.g. '$1_NEW'): $3-$1- Performed 0 rRenames Command:
@Sea-Haven wrote:Need oldname , newname in a text file with a "," separator then very easy.
Alan,Alan-new
t,t-new
XYZ,POINTS
I tried to use that lisp but just export layer names to the text file. ("d:\\acadtemp\\layers.txt")
maybe I'm doing something bad?
So should this layer:
"EQ_10$0$1.0 JTM EQ$0$JTM_JTM-ECA"
Be renamed to this?
"MSC-EQ_10-JTM_JTM-ECA"
I could not follow your example above.
It seems that you are trying to rename the layouts.
But the example you provided are for layers like below.
How is your layouts named currently ?
Maybe the current layouts names not matching the regex expression.
@ronjonp wrote:So should this layer:
"EQ_10$0$1.0 JTM EQ$0$JTM_JTM-ECA"Be renamed to this?
No friend, I did not. but maybe I'm doing something bad.
here is the command prompt : (Performed 0 rRenames)
Give a simple before and after example of what you want accomplished .. and a stated above by @Ajilal.Vijayan are you renaming layouts or layers ??
@Ajilal.Vijayan wrote:It seems that you are trying to rename the layouts.
Boys, I do not how to say this....
I did not notice that I was using LAYOUT options. now I used LAYER options and I renamed my layers. (LOL)
here my "Performed 40 rRenames" command prompt :
Command: (LOAD "C:/Users/jtm2019hyo/Google Drive/@Programing/@CAD/LSP-VLX/RENAME/REGEX/RRename - rename layouts, blocks, layers or linetypes using regular expressions (VLX Lisp for AutoCAD)/RRename.VLX") RRename command loaded. (C)2014, CAD Studio - www.cadstudio.cz ______ CAD, PLM, GIS/FM custom application development ________ nil Command: RRENAME Rename [Blocks/Layers/lineTypes/layOuts] <layOuts>: L Use () and $1 for regular expressions, # as counter Source substring or regex to find (e.g. '(.+)'): (.+)(MAC|MED|EIC|ED|MEB|MSC|ECA) Target substring or regex to replace (e.g. '$1_NEW'): $2-$1 ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_E-VEREDA->ED-ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_E-VERA ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_CIRCUITO MEDIA TENSION->ED-ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_CIRCUITO MIA TENSION ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_pedro->ed-ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM_10_pro ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM EQ-10 COMPACT$0$CIRCUITO MEDIA TENSION->ED-ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM EQ-10 COMPACT$0$CIRCUITO MIA TENSION ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM EQ-10 COMPACT$0$ED->ED-ARQUITECTURA EST.HYO$0$ARQ_10$0$ARQ_JTM EQ-10 COMPACT$0$ ARQUITECTURA EST.HYO$0$ARQ_11$0$ARQ_JTM_11_E-VEREDA->ED-ARQUITECTURA EST.HYO$0$ARQ_11$0$ARQ_JTM_11_E-VERA EM_01$0$0.1 JTM EM$0$TOMAC-TABLERO->MAC-EM_01$0$0.1 JTM EM$0$TO-TABLERO EM_02$0$0.1 JTM EM$0$TOMAC-TABLERO->MAC-EM_02$0$0.1 JTM EM$0$TO-TABLERO EM_03$0$0.1 JTM EM$0$TOMAC-TABLERO->MAC-EM_03$0$0.1 JTM EM$0$TO-TABLERO EM_10$0$1.0 JTM EM$0$EIC->EIC-EM_10$0$1.0 JTM EM$0$ EM_10$0$1.0 JTM EM$0$D-salida electromecanicas->eca-EM_10$0$1.0 JTM EM$0$D-salida electromnicas EM_11$0$1.1 JTM EM$0$D-salida electromecanicas->eca-EM_11$0$1.1 JTM EM$0$D-salida electromnicas EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$CIRCUITO MEDIA TENSION->ED-EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$CIRCUITO MIA TENSION EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$07415_TRABAJO_MT1$0$2_MEDIA_TENSION->ED-EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$07415_TRABAJO_MT1$0$2_MIA_TENSION EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$EIC->EIC-EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$ EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$$0$CIRCUITO MEDIA TENSION->ED-EM_10_SE_GE$0$1.0 JTM S.E. Y G.E$0$$0$CIRCUITO MIA TENSION EM_20$0$2.0 JTM EM$0$EIC->EIC-EM_20$0$2.0 JTM EM$0$ EM_20$0$2.0 JTM EM$0$MAC->MAC-EM_20$0$2.0 JTM EM$0$ EM_20$0$2.0 JTM EM$0$D-salida electromecanicas->eca-EM_20$0$2.0 JTM EM$0$D-salida electromnicas EQ_10$0$1.0 JTM EQ$0$JTM_MAC->MAC-EQ_10$0$1.0 JTM EQ$0$JTM_ EQ_10$0$1.0 JTM EQ$0$JTM_MSC->MSC-EQ_10$0$1.0 JTM EQ$0$JTM_ EQ_10$0$1.0 JTM EQ$0$JTM_EIC->EIC-EQ_10$0$1.0 JTM EQ$0$JTM_ EQ_10$0$1.0 JTM EQ$0$JTM_MEB->MEB-EQ_10$0$1.0 JTM EQ$0$JTM_ EQ_10$0$1.0 JTM EQ$0$JTM_ED->ED-EQ_10$0$1.0 JTM EQ$0$JTM_ EQ_10$0$1.0 JTM EQ$0$JTM_$0$ED->ED-EQ_10$0$1.0 JTM EQ$0$JTM_$0$ EQ_10$0$1.0 JTM EQ$0$JTM_JTM-ECA->ECA-EQ_10$0$1.0 JTM EQ$0$JTM_JTM- EQ_11$0$1.1 JTM EQ$0$JTM_MAC->MAC-EQ_11$0$1.1 JTM EQ$0$JTM_ EQ_11$0$1.1 JTM EQ$0$JTM_MSC->MSC-EQ_11$0$1.1 JTM EQ$0$JTM_ EQ_11$0$1.1 JTM EQ$0$JTM_EIC->EIC-EQ_11$0$1.1 JTM EQ$0$JTM_ EQ_11$0$1.1 JTM EQ$0$JTM_MEB->MEB-EQ_11$0$1.1 JTM EQ$0$JTM_ EQ_11$0$1.1 JTM EQ$0$JTM_JTM-ECA->ECA-EQ_11$0$1.1 JTM EQ$0$JTM_JTM- EQ_20$0$2.0 JTM EQ$0$JTM_EIC->EIC-EQ_20$0$2.0 JTM EQ$0$JTM_ EQ_20$0$2.0 JTM EQ$0$JTM_MSC->MSC-EQ_20$0$2.0 JTM EQ$0$JTM_ EQ_20$0$2.0 JTM EQ$0$JTM_MAC->MAC-EQ_20$0$2.0 JTM EQ$0$JTM_ EQ_20$0$2.0 JTM EQ$0$JTM_MEB->MEB-EQ_20$0$2.0 JTM EQ$0$JTM_ EQ_30$0$3.0 JTM EQ$0$JTM_MSC->MSC-EQ_30$0$3.0 JTM EQ$0$JTM_ EQ_30$0$3.0 JTM EQ$0$JTM_MAC->MAC-EQ_30$0$3.0 JTM EQ$0$JTM_ EQ_40$0$4.0 JTM EQ$0$JTM_MSC->MSC-EQ_40$0$4.0 JTM EQ$0$JTM_ EQ_10-MSC->MSC-EQ_10- JTM-MAC->MAC-JTM- Performed 40 rRenames Command:
