alternative of _BOUNDARY in the mode of pick point
АлексЮстасу
Advisor Advisor
Message 1 of 71
АлексЮстасу
I search an alternative to the command _BOUNDARY in the mode of pick point, for finding out minimum contours from intersecting elements (polylines, 3D polylines, lines, circles, ellipses, arcs,  splines, multilines, regions):
1. not depending on the sizes of elements on the screen;
2. not depending on that, whether all possible elements of border are visible on the screen;
3. not thinking very long or infinitely;
4. not simplifying the found contours.
I found one variant - program BNDR only, but she does not develop, and actually inaccessible.
I made video. At first it is shown how BNDR works, and then _BOUNDARY.
https://youtu.be/aG01-R1nrQE - for model example.
https://youtu.be/iBE86OtIOog - for real data.
I hope that is other alternatives of BOUNDARY, that can be developed.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Replies (70)
Message 2 of 71
marko_ribar
I have a little request/qestion :
Where can we get BNDR plugin for ACAD shown in your examples and is it free?
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 71
АлексЮстасу
I search an alternative to the command _BOUNDARY in the mode of pick point.
In my opinion, the solution of this task in AutoCAD is unsatisfactory.
BNDR - an example of the fact that the complete decision is possible. ObjectARX.
Unfortunately I didn't manage so far neither to buy the BNDR codes, nor to agree with the author about finishing.
Message 4 of 71
АлексЮстасу
Do you have any suggestions, do you know of any other solutions?
Message 5 of 71
marko_ribar
No I am afraid that I don't have any other solution... Actually seeing those videos you posted I realized that my work based on command -BOUNDARY is maybe cumbersome, so I thought I should at least bring this to attention... I had to revive this topic, it was already been forgotten... Now it's at least at the top of messages so maybe someone will look it and maybe found some atlternative...
Thanks for your initial post and take care,
regards, M.R.
Message 6 of 71
АлексЮстасу
Yes, thanks for support of a question!
BOUNDARY exists years 15, probably.
I try to find alternative of years 5-6.
Almost all programmers say to me that it very much, very much, very complex challenge.
One programmer of it didn't know, and quickly wrote - BNDR. And wrote in passing - as auxiliary for other task. 🙂
But it is impossible to use it actually.
One more programmer promises to write, but won't begin in any way.
So the task is actually not solved. Directly "Fermat's theorem"!
By the way, almost all "clones" solve the problem BOUNDARY easily!
And it is especially interesting what thinks of this Autodesk...
Message 7 of 71
marko_ribar
Alex, I don't think BOUNDARY command was written using Vanilla/Visual Lisp only... I made some attempts in LISP and although it's poor implementation, I'll post it here in ALISP forum... I am also interested to see if someone will reply and have some opinion... My method is using RAY entity and I don't think that was used in real BOUNDARY algorithm... And yes it's not good at all, but with some simple case it may solve, but only in simple situation with some ordinary entities surrounding picked internal point... What to say - I realized that I can't do it easy so you're right it's challenge for some more advanced programming...
(defun c:bndr ( / *error* unit *adoc* pea pck ss p i1 c1 i2 c2 ip ipl trl s el sx ii pl tt ttt trr trx trxx )
  (vl-load-com)
  (defun *error* ( m )
    (if pea
      (setvar 'peditaccept pea)
    (if pck
      (setvar 'pickbox pck)
    (vla-endundomark *adoc*)
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
    (if (not (equal v '(0.0 0.0 0.0) 1e-6))
      (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v)
  (vla-startundomark (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
  (setq pea (getvar 'peditaccept))
  (setvar 'peditaccept 1)
  (setq pck (getvar 'pickbox))
  (prompt "\nSelect boundary curve entities...")
  (setq ss (ssget "_:L" '((0 . "*POLYLINE,LINE,SPLINE,ARC,CIRCLE,ELLIPSE"))))
  (while (not ss)
    (prompt "\nSource curve boundary sel. set empty... Please reselect boundary curves on unlocked layer(s) again...")
  (initget 1)
  (setq p (getpoint "\nPick or specify internal point : "))
  (setvar 'pickbox 4)
  (repeat (setq i1 (sslength ss))
    (setq c1 (ssname ss (setq i1 (1- i1))))
    (ssdel c1 ss)
    (repeat (setq i2 (sslength ss))
      (setq c2 (ssname ss (setq i2 (1- i2))))
      (setq ip (vlax-invoke (vlax-ename->vla-object c1) 'intersectwith (vlax-ename->vla-object c2) acextendnone))
      (if ip
        (repeat (/ (length ip) 3)
          (setq ipl (cons (list (car ip) (cadr ip) (caddr ip)) ipl))
          (setq ip (cdddr ip))
    (setq ipl (vl-sort ipl '(lambda ( a b ) (< (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)))))
    (mapcar
     '(lambda ( a b / ray ipp ippl v )
        (setq v (unit (mapcar '- (vlax-curve-getpointatparam c1 (/ (+ (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)) 2.0)) p)))
        (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 p) (cons 11 v))))
        (setq ipp (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object c1) acextendnone))
          (setq ipp (append (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object c2) acextendnone) ipp))
        (if ipp
          (repeat (/ (length ipp) 3)
            (setq ippl (cons (list (car ipp) (cadr ipp) (caddr ipp)) ippl))
            (setq ipp (cdddr ipp))
        (if (vlax-curve-getparamatpoint c1 (car (setq ippl (vl-sort ippl '(lambda ( a b ) (< (vlax-curve-getparamatpoint ray a) (vlax-curve-getparamatpoint ray b)))))))
          (progn
            (if (not (vl-position (list a c1 b) trl))
              (setq trl (cons (list a c1 b) trl))
            (if (cadr ippl)
              (foreach ipp (cdr ippl)
                (setq pl (cons ipp pl))
          (if
            (and
              (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (car ippl) (car ippl))) 0) a)
              (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (car ippl) (car ippl))) 0) b)
              (not (vl-position (list a (ssname (ssdel ray (ssget "_C" (car ippl) (car ippl))) 0) b) trl))
            (setq trl (cons (list a (ssname (ssdel ray (ssget "_C" (car ippl) (car ippl))) 0) b) trl))
        (entdel ray)
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach p pl
    (vl-some '(lambda ( x ) (if (< (vlax-curve-getparamatpoint (cadr x) (car x)) (vlax-curve-getparamatpoint (cadr x) p) (vlax-curve-getparamatpoint (cadr x) (caddr x))) (setq tr x) (setq tr nil))) trl)
    (if tr
      (setq trl (vl-remove tr trl))
    (setq tr nil)
  (foreach tr trl
    (setq trx (vl-remove-if-not '(lambda ( x ) (eq (cadr tr) (cadr x))) trl))
    (if (> (length trx) 1)
      (progn
        (foreach tt trx
          (setq trl (vl-remove tt trl))
        (setq trr trx)
        (while (setq tt (car trx))
          (setq ttt (cadr trx))
          (if (equal (last tt) (car ttt) 1e-6)
            (setq trxx (cons (list (car tt) (cadr tt) (caddr ttt)) trxx))
          (setq trx (cdr trx))
        (setq trxx (reverse trxx))
        (setq trr (vl-remove-if '(lambda ( x ) (vl-some '(lambda ( y ) (or (equal (caddr y) (car x) 1e-6) (equal (car y) (caddr x) 1e-6))) trr)) trr))
        (foreach tt trxx
          (setq trr (cons tt trr))
        (foreach tt trr
          (setq trl (cons tt trl))
  (foreach tr trl
    (repeat (1- (length (vl-remove-if-not '(lambda ( x ) (eq (cadr tr) (cadr x))) trl)))
      (setq trl (subst (list (car tr) (vlax-vla-object->ename (vla-copy (vlax-ename->vla-object (cadr tr)))) (caddr tr) t) tr trl))
  (foreach tr trl
    (if (eq (last tr) t)
      (entdel (cadr tr))
  (setq s (ssadd))
  (foreach tr (vl-remove-if '(lambda ( x ) (eq (last x) t)) trl)
    (setq el (entlast))
    (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001)))))) 0 1) "")
    (cond
      ( (and
          (vlax-curve-getparamatpoint (entlast) (caddr tr))
          (not
            (or
              (equal (vlax-curve-getstartpoint (entlast)) (car tr) 1e-6)
              (equal (vlax-curve-getendpoint (entlast)) (car tr) 1e-6)
        (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (< (vlax-curve-getparamatpoint (entlast) (caddr tr)) (vlax-curve-getparamatpoint (entlast) (car tr))) (vlax-curve-getendparam (entlast)) (vlax-curve-getstartparam (entlast))))) 0 1) "")
      ( (and
          (vlax-curve-getparamatpoint (cadr tr) (caddr tr))
          (not
            (or
              (equal (vlax-curve-getstartpoint (cadr tr)) (car tr) 1e-6)
              (equal (vlax-curve-getendpoint (cadr tr)) (car tr) 1e-6)
        (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (< (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (vlax-curve-getparamatpoint (cadr tr) (car tr))) (vlax-curve-getendparam (cadr tr)) (vlax-curve-getstartparam (cadr tr))))) 0 1) "")
    (if (not (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))))
      (progn
        (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.001)))))) 0 1) "")
        (if (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr)))
          (ssadd (entlast) s)
          (if (not (eq el (entlast)))
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
        (if (not (eq (cadr tr) (entlast)))
          (entdel (cadr tr))
        (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.001)))))) 0 1) "")
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (if (not (vlax-erased-p (cadr tr)))
                (ssadd (cadr tr) s)
                (progn
                  (setq sx (ssget "_C" (car tr) (car tr)))
                  (repeat (setq ii (sslength sx))
                    (if
                      (or
                        (and
                          (equal (vlax-curve-getstartpoint (ssname sx (setq ii (1- ii)))) (car tr) 1e-6)
                          (equal (vlax-curve-getendpoint (ssname sx ii)) (caddr tr) 1e-6)
                        (and
                          (equal (vlax-curve-getstartpoint (ssname sx ii)) (caddr tr) 1e-6)
                          (equal (vlax-curve-getendpoint (ssname sx ii)) (car tr) 1e-6)
                      (ssadd (ssname sx ii) s)
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
  (foreach tr (vl-remove-if-not '(lambda ( x ) (eq (last x) t)) trl)
    (entdel (cadr tr))
    (setq el (cadr tr))
    (cond
      ( (and
          (not
            (or
      ( (and
          (not
            (or
      (progn
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
  ;;; (command "_.JOIN" (ssname s 0) s "") - JOIN command variant looks better but CAD can't do it good...
  (command "_.PEDIT" "_M" s "" "_J" "_J" "_E" 0.0)
  (while (< 0 (getvar 'cmdactive))
    (command "")
  ;;; PEDIT JOIN command for generating LWPOLYLINE as result, more stupid version, but CAD can handle it better...
  (command "_.COPYBASE" "_non" '(0.0 0.0 0.0) (if (not (vlax-erased-p (ssname s 0))) (ssname s 0) (entlast)) "")
  (command "_.UNDO" "_B")
  (command "_.PASTECLIP" "_non" '(0.0 0.0 0.0))
  (sssetfirst nil (ssadd (entlast)))
  (*error* nil)
HTH, M.R.
Regards...
Message 8 of 71
marko_ribar
Nothing special, just little more reliable with not crossing curves... I can't edit post so I am posting my little revision :
    (setq el (entlast))
    (if
      (not
        (or
    (cond
      ( (and
          (not
            (or
      ( (and
          (not
            (or
      (progn
        (if
          (not
            (or
              (equal (vlax-curve-getstartpoint (cadr tr)) (caddr tr) 1e-6)
              (equal (vlax-curve-getendpoint (cadr tr)) (caddr tr) 1e-6)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
              (equal (vlax-curve-getstartpoint (entlast)) (caddr tr) 1e-6)
              (equal (vlax-curve-getendpoint (entlast)) (caddr tr) 1e-6)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
    (entdel (cadr tr))
    (setq el (cadr tr))
    (if
      (not
        (or
    (cond
      ( (and
          (not
            (or
      ( (and
          (not
            (or
      (progn
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
M.R.
Message 9 of 71
marko_ribar
Not so important if you're in WCS, but here is revision for eralier part of routine... Forgot to place (trans p 1 0) where it was needed instead of just p...
    (mapcar
        (setq v (unit (mapcar '- (vlax-curve-getpointatparam c1 (/ (+ (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)) 2.0)) (trans p 1 0))))
        (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 (trans p 1 0)) (cons 11 v))))
        (if ipp
          (progn
            (if (cadr ippl)
          (if
            (and
              (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) a)
              (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b)
              (not (vl-position (list a (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b) trl))
            (setq trl (cons (list a (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b) trl))
        (entdel ray)
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach p pl
    (vl-some '(lambda ( x ) (if (< (vlax-curve-getparamatpoint (cadr x) (car x)) (vlax-curve-getparamatpoint (cadr x) (trans p 1 0)) (vlax-curve-getparamatpoint (cadr x) (caddr x))) (setq tr x) (setq tr nil))) trl)
    (if tr
    (setq tr nil)
M.R.
Message 10 of 71
marko_ribar
Sorry again last part... Forgot (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1)))...
    (setq el (entlast))
    (if
      (not
        (or
    (cond
      ( (and
          (not
            (or
      ( (and
          (not
            (or
      (progn
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
    (entdel (cadr tr))
    (setq el (cadr tr))
    (if
      (not
        (or
    (cond
      ( (and
          (not
            (or
      ( (and
          (not
            (or
      (progn
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
Message 11 of 71
marko_ribar
I've made few more changes, so now I'll post the code entirely...
(defun c:bndr ( / *error* unit *adoc* pea pck ss p i1 c1 i2 c2 ip ipl trl s el sx ii pl tt ttt trr trx trxx cx k )
  (vl-load-com)
    (if pea
    (if pck
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
  (while (not ss)
  (initget 1)
  (setvar 'pickbox 4)
    (ssdel c1 ss)
      (if ip
    (mapcar
        (if ipp
          (progn
            (if (cadr ippl)
          (if
            (and
        (entdel ray)
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach p pl
    (if tr
    (setq tr nil)
  (foreach tr trl
      (progn
        (foreach tt trx
        (setq trr trx)
        (foreach tt trxx
        (foreach tt trr
  (foreach tr trl
  (foreach tr trl
      (entdel (cadr tr))
  (setq s (ssadd))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq cx (entget (cadr tr)))
        (setq k 0)
        (while (equal cx (entget (cadr tr)) 1e-6)
          (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.1)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001))))))) 0 1) "")
    (cond
      ( (and
          (not
            (or
        (progn
          (setq cx (entget (entlast)))
          (while (equal cx (entget (entlast)) 1e-6)
            (prompt "\nBug trimming...")
      ( (and
          (not
            (or
        (progn
      (progn
        (if
          (not
            (or
          (progn
            (setq k 0)
              (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.001))))))) 0 1) "")
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
              (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.001))))))) 0 1) "")
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
    (entdel (cadr tr))
    (setq el (cadr tr))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
      ( (and
          (not
            (or
        (progn
      ( (and
          (not
            (or
        (progn
      (progn
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
      (progn
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
  (if (vl-some '(lambda ( x ) (wcmatch (cdr (assoc 0 (entget x))) "SPLINE,ELLIPSE")) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
    (progn
        (command "")
  (*error* nil)
M.R.
Message 12 of 71
marko_ribar
Again, can't edit post... So even more modifications... Here is my latest version :
(defun c:bndr ( / *error* unit *adoc* pea pck ss p i1 c1 i2 c2 ip ipl trl s el sx ii pl tt ttt trr trx trxx cx k e i ray ipp ippl )
  (vl-load-com)
    (if pea
    (if pck
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
  (while (not ss)
  (initget 1)
  (setvar 'pickbox 4)
    (ssdel c1 ss)
      (if ip
    (mapcar
        (if ipp
          (progn
            (if (cadr ippl)
          (if
            (and
        (entdel ray)
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach p pl
    (if tr
    (setq tr nil)
  (foreach tr trl
      (progn
        (foreach tt trx
        (setq trr trx)
        (foreach tt trxx
        (foreach tt trr
  (foreach tr trl
  (foreach tr trl
      (entdel (cadr tr))
  (setq s (ssadd))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
      ( (and (not (eq el (entlast))) (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))))
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
      ( (and (not (eq el (entlast))) (not (and (vlax-curve-getparamatpoint (cadr tr) (car tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr)))))
        (entdel (cadr tr))
        (setq e (car (vl-remove-if-not '(lambda ( x ) (vlax-curve-getparamatpoint x (caddr tr))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex sx))))))
        (if
          (not
            (or
              (equal (vlax-curve-getstartpoint e) (caddr tr) 1e-6)
              (equal (vlax-curve-getendpoint e) (caddr tr) 1e-6)
          (progn
            (setq cx (entget e))
            (if (< (vlax-curve-getparamatpoint e (car tr)) (vlax-curve-getparamatpoint e (caddr tr)))
              (progn
                (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "")
                (setq k 0)
                (while (equal cx (entget e) 1e-6)
                  (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "")
              (progn
                (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.1) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.01) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.001) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "")
                (setq k 0)
                  (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.01)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.001)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "")
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
    (entdel (cadr tr))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
        (entdel (cadr tr))
        (if
          (not
            (or
          (progn
              (progn
                (setq k 0)
              (progn
                (setq k 0)
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
    (progn
        (command "")
  (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 (trans p 1 0)) (cons 11 (getvar 'ucsxdir)))))
  (repeat (setq i (sslength (setq ss (ssget "_A"))))
    (setq e (ssname ss (setq i (1- i))))
    (setq ipp (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object e) acextendnone))
    (setq ippl (append ipp ippl))
  (setq ipp nil)
  (repeat (/ (length ippl) 3)
    (setq ipp (cons (list (car ippl) (cadr ippl) (caddr ippl)) ipp))
    (setq ippl (cdddr ippl))
  (setq ippl (vl-sort ipp '(lambda ( a b ) (< (vlax-curve-getparamatpoint ray a) (vlax-curve-getparamatpoint ray b)))))
  (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (if (vlax-curve-getparamatpoint ent (car ippl))
      (setq e ent)
  (entdel ray)
  (command "_.COPYBASE" "_non" '(0.0 0.0 0.0) e "")
  (*error* nil)
HTH, M.R.
Message 13 of 71
marko_ribar
Latest version :
(defun c:bndr ( / *error* unit bbucs *adoc* pea pck ss p bb dx dy kx ky pp pl pll li i1 c1 i2 c2 ip ipl trl s el sx ii cx k e i ray ipp ippl )
  (vl-load-com)
    (if pea
    (if pck
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
  (defun bbucs ( ss / UCS2WCSMatrix WCS2UCSMatrix n ent minpt maxpt minptlst maxptlst minptbbx minptbby minptbbz minptbb maxptbbx maxptbby maxptbbz maxptbb )
    (vl-load-com)
    ;; Doug C. Broad, Jr.
    ;; can be used with vla-transformby to
    ;; transform objects from the UCS to the WCS
    (defun UCS2WCSMatrix ()
      (vlax-tmatrix
        (append
          (mapcar
           '(lambda (vector origin)
            (append (trans vector 1 0 t) (list origin))
          (list '(1 0 0) '(0 1 0) '(0 0 1))
          (trans '(0 0 0) 0 1)
          (list '(0 0 0 1))
    ;; transform objects from the WCS to the UCS
    (defun WCS2UCSMatrix ()
      (vlax-tmatrix
        (append
          (mapcar
            (append (trans vector 0 1 t) (list origin))
          (trans '(0 0 0) 1 0)
          (list '(0 0 0 1))
    (if ss
      (progn
        (repeat (setq n (sslength ss))
          (setq ent (ssname ss (setq n (1- n))))
          (vla-TransformBy (vlax-ename->vla-object ent) (UCS2WCSMatrix))
          (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
          (vla-TransformBy (vlax-ename->vla-object ent) (WCS2UCSMatrix))
          (setq minpt (vlax-safearray->list minpoint))
          (setq maxpt (vlax-safearray->list maxpoint))
          (setq minptlst (cons minpt minptlst))
          (setq maxptlst (cons maxpt maxptlst))
        (setq minptbbx (caar (vl-sort minptlst '(lambda (a b) (< (car a) (car b))))))
        (setq minptbby (cadar (vl-sort minptlst '(lambda (a b) (< (cadr a) (cadr b))))))
        (setq minptbbz (caddar (vl-sort minptlst '(lambda (a b) (< (caddr a) (caddr b))))))
        (setq maxptbbx (caar (vl-sort maxptlst '(lambda (a b) (> (car a) (car b))))))
        (setq maxptbby (cadar (vl-sort maxptlst '(lambda (a b) (> (cadr a) (cadr b))))))
        (setq maxptbbz (caddar (vl-sort maxptlst '(lambda (a b) (> (caddr a) (caddr b))))))
        (setq minptbb (list minptbbx minptbby minptbbz))
        (setq maxptbb (list maxptbbx maxptbby maxptbbz))
    (list minptbb maxptbb)
  (while (not ss)
  (initget 1)
  (setvar 'pickbox 4)
  (setq bb (bbucs ss))
  (setq dx (/ (abs (- (car (cadr bb)) (car (car bb)))) 20.0))
  (setq dy (/ (abs (- (cadr (cadr bb)) (cadr (car bb)))) 20.0))
  (setq ky 0)
  (repeat 19
    (setq ky (1+ ky))
    (setq kx 0)
    (repeat 19
      (setq kx (1+ kx))
      (setq pp (list (+ (car (car bb)) (* kx dx)) (+ (cadr (car bb)) (* ky dy)) 0.0))
      (setq pl (cons pp pl))
  (foreach pp pl
    (setq li (entmakex (list '(0 . "LINE") (cons 10 (trans p 1 0)) (cons 11 (trans pp 1 0)))))
    (setq ippl nil)
    (repeat (setq i (sslength ss))
      (setq ipp (vlax-invoke (vlax-ename->vla-object li) 'intersectwith (vlax-ename->vla-object e) acextendnone))
    (if (or (null ippl) (= 0 (rem (length ippl) 6)))
      (setq pll (cons pp pll))
    (entdel li)
  (setq pll (vl-remove-if-not '(lambda ( x ) (< (distance p x) (* 2.0 (min dx dy)))) pll))
  (foreach pp pll
    (entmake (list '(0 . "POINT") (cons 10 (trans pp 1 0))))
    (ssdel c1 ss)
      (if ip
    (mapcar
     '(lambda ( a b / f ray ipp ippl v )
        (foreach pp pll
          (setq ippl nil)
          (setq v (unit (mapcar '- (vlax-curve-getpointatparam c1 (/ (+ (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)) 2.0)) (trans pp 1 0))))
          (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 (trans pp 1 0)) (cons 11 v))))
          (if ipp
            (progn
              (setq f (cons t f))
            (if
              (and
            (setq f (cons nil f))
          (entdel ray)
        (if (and (eval (cons 'or f)) (null (eval (cons 'and f))))
          (setq trl (cdr trl))
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach tr trl
  (foreach tr trl
      (entdel (cadr tr))
  (setq s (ssadd))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
        (entdel (cadr tr))
        (if
          (not
            (or
          (progn
              (progn
                (setq k 0)
              (progn
                (setq k 0)
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
    (entdel (cadr tr))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
        (entdel (cadr tr))
        (if
          (not
            (or
          (progn
              (progn
                (setq k 0)
              (progn
                (setq k 0)
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
  (if (vl-some '(lambda ( x ) (if (wcmatch (cdr (assoc 0 (entget x))) "SPLINE,ELLIPSE") (setq e x))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
    (command "_.JOIN" e s "")
    (progn
        (command "")
  (ssdel ray ss)
  (setq ipp nil)
      (setq e ent)
  (entdel ray)
  (*error* nil)
M.R.
Message 14 of 71
marko_ribar
Latest imprvement...
(defun c:bndr ( / *error* unit bbucs *adoc* pea pck ss p bb dx dy kx ky pp ipp1 ipp2 ippl1 ippl2 rec pl pll li1 li2 i1 c1 i2 c2 ip ipl trl s el sx ii cx k e i ray ipp ippl )
  (vl-load-com)
    (if pea
    (if pck
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
    (vl-load-com)
      (vlax-tmatrix
        (append
          (mapcar
          (list '(0 0 0 1))
      (vlax-tmatrix
        (append
          (mapcar
          (list '(0 0 0 1))
    (if ss
      (progn
  (while (not ss)
  (initget 1)
  (setvar 'pickbox 1)
  (setq dx (/ (abs (- (car (cadr bb)) (car (car bb)))) 10.0))
  (setq dy (/ (abs (- (cadr (cadr bb)) (cadr (car bb)))) 10.0))
  (setq ky 0)
  (repeat 9
    (setq ky (1+ ky))
    (setq kx 0)
    (repeat 9
      (setq kx (1+ kx))
  (setq rec
    (entmakex
      (list
        '(0 . "LWPOLYLINE")
        '(100 . "AcDbPolyline")
        '(90 . 4)
        '(70 . 1)
        (cons 38 (caddr (trans (car bb) 1 (trans '(0.0 0.0 1.0) 1 0 t))))
        (cons 10 (car bb))
        (cons 10 (list (car (cadr bb)) (cadr (car bb))))
        (cons 10 (cadr bb))
        (cons 10 (list (car (car bb)) (cadr (cadr bb))))
        (cons 210 (trans '(0.0 0.0 1.0) 1 0 t))
  (foreach pp pl
    (setq li1 (entmakex (list '(0 . "LINE") (cons 10 (trans p 1 0)) (cons 11 (trans pp 1 0)))))
    (setq li2 (entmakex (list '(0 . "LINE") (cons 10 (trans pp 1 0)) (cons 11 (vlax-curve-getclosestpointto rec (trans pp 1 0))))))
    (setq ippl1 nil ippl2 nil)
      (setq ipp1 (vlax-invoke (vlax-ename->vla-object li1) 'intersectwith (vlax-ename->vla-object e) acextendnone))
      (setq ippl1 (append ipp1 ippl1))
      (setq ipp2 (vlax-invoke (vlax-ename->vla-object li2) 'intersectwith (vlax-ename->vla-object e) acextendnone))
      (setq ippl2 (append ipp2 ippl2))
    (if (and (or (null ippl1) (= 0 (rem (length ippl1) 6))) (not (null ippl2)))
    (entdel li1)
    (entdel li2)
  (entdel rec)
  (foreach pp pll
(setq pll (vl-remove-if-not '(lambda ( x ) (< (distance p x) (* 3.0 (min dx dy)))) pll)) (repeat (setq i1 (sslength ss)) (setq c1 (ssname ss (setq i1 (1- i1)))) (ssdel c1 ss) (repeat (setq i2 (sslength ss)) (setq c2 (ssname ss (setq i2 (1- i2)))) (setq ip (vlax-invoke (vlax-ename->vla-object c1) 'intersectwith (vlax-ename->vla-object c2) acextendnone)) (if ip (repeat (/ (length ip) 3) (setq ipl (cons (list (car ip) (cadr ip) (caddr ip)) ipl)) (setq ip (cdddr ip)) ) ) ) (setq ipl (vl-sort ipl '(lambda ( a b ) (< (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b))))) (mapcar '(lambda ( a b / ray ipp ippl v ) (foreach pp pll (setq ippl nil) (setq v (unit (mapcar '- (vlax-curve-getpointatparam c1 (/ (+ (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)) 2.0)) (trans pp 1 0)))) (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 (trans pp 1 0)) (cons 11 v)))) (setq ipp (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object c1) acextendnone)) (repeat (setq i2 (sslength ss)) (setq c2 (ssname ss (setq i2 (1- i2)))) (setq ipp (append (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object c2) acextendnone) ipp)) ) (if ipp (repeat (/ (length ipp) 3) (setq ippl (cons (list (car ipp) (cadr ipp) (caddr ipp)) ippl)) (setq ipp (cdddr ipp)) ) ) (if (equal (vlax-curve-getpointatparam c1 (/ (+ (vlax-curve-getparamatpoint c1 a) (vlax-curve-getparamatpoint c1 b)) 2.0)) (car (setq ippl (vl-sort ippl '(lambda ( a b ) (< (vlax-curve-getparamatpoint ray a) (vlax-curve-getparamatpoint ray b)))))) 1e-6) (if (not (vl-position (list a c1 b) trl)) (setq trl (cons (list a c1 b) trl)) ) (if (and (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) a) (vlax-curve-getparamatpoint (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b) (not (vl-position (list a (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b) trl)) ) (setq trl (cons (list a (ssname (ssdel ray (ssget "_C" (trans (car ippl) 0 1) (trans (car ippl) 0 1))) 0) b) trl)) ) ) (entdel ray) ) ) ipl (cdr ipl) ) (setq ipl nil) (ssadd c1 ss) ) (foreach tr trl (repeat (1- (length (vl-remove-if-not '(lambda ( x ) (eq (cadr tr) (cadr x))) trl))) (setq trl (subst (list (car tr) (vlax-vla-object->ename (vla-copy (vlax-ename->vla-object (cadr tr)))) (caddr tr) t) tr trl)) ) ) (foreach tr trl (if (eq (last tr) t) (entdel (cadr tr)) ) ) (setq s (ssadd)) (foreach tr (vl-remove-if '(lambda ( x ) (eq (last x) t)) trl) (setq el (entlast)) (if (not (or (equal (vlax-curve-getstartpoint (cadr tr)) (car tr) 1e-6) (equal (vlax-curve-getendpoint (cadr tr)) (car tr) 1e-6) ) ) (progn (setq cx (entget (cadr tr))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (cadr tr)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.1)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001))))))) 0 1) "") ) ) ) (cond ( (and (not (eq el (entlast))) (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr)))) (if (not (eq (cadr tr) (entlast))) (entdel (cadr tr)) ) (if (not (or (equal (vlax-curve-getstartpoint (entlast)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (entlast)) (caddr tr) 1e-6) ) ) (progn (setq cx (entget (entlast))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (entlast)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) (if (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (ssadd (entlast) s) (if (not (eq el (entlast))) (progn (entdel (entlast)) (if (not (vlax-erased-p (cadr tr))) (ssadd (cadr tr) s) (progn (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (repeat (setq ii (sslength sx)) (if (or (and (equal (vlax-curve-getstartpoint (ssname sx (setq ii (1- ii)))) (car tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (caddr tr) 1e-6) ) (and (equal (vlax-curve-getstartpoint (ssname sx ii)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (car tr) 1e-6) ) ) (ssadd (ssname sx ii) s) ) ) ) ) ) (if (not (vlax-erased-p (cadr tr))) (ssadd (cadr tr) s) (progn (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (repeat (setq ii (sslength sx)) (if (or (and (equal (vlax-curve-getstartpoint (ssname sx (setq ii (1- ii)))) (car tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (caddr tr) 1e-6) ) (and (equal (vlax-curve-getstartpoint (ssname sx ii)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (car tr) 1e-6) ) ) (ssadd (ssname sx ii) s) ) ) ) ) ) ) ) ( (and (not (eq el (entlast))) (not (and (vlax-curve-getparamatpoint (cadr tr) (car tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))))) (entdel (cadr tr)) (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (setq e (car (vl-remove-if-not '(lambda ( x ) (vlax-curve-getparamatpoint x (caddr tr))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex sx)))))) (if (not (or (equal (vlax-curve-getstartpoint e) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint e) (caddr tr) 1e-6) ) ) (progn (setq cx (entget e)) (if (< (vlax-curve-getparamatpoint e (car tr)) (vlax-curve-getparamatpoint e (caddr tr))) (progn (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget e) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) (progn (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.1) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.01) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.001) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget e) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.01)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.001)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) ) ) (ssadd e s) ) ( t (if (not (or (equal (vlax-curve-getstartpoint (cadr tr)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (cadr tr)) (caddr tr) 1e-6) ) ) (progn (setq cx (entget (cadr tr))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (cadr tr)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) (if (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (ssadd (entlast) s) (if (not (eq el (entlast))) (progn (entdel (entlast)) (ssadd (cadr tr) s) ) (ssadd (cadr tr) s) ) ) ) ) ) (foreach tr (vl-remove-if-not '(lambda ( x ) (eq (last x) t)) trl) (entdel (cadr tr)) (setq el (entlast)) (if (not (or (equal (vlax-curve-getstartpoint (cadr tr)) (car tr) 1e-6) (equal (vlax-curve-getendpoint (cadr tr)) (car tr) 1e-6) ) ) (progn (setq cx (entget (cadr tr))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.1) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.01) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (cadr tr)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.1)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.01)) (if (> (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001)) (- (vlax-curve-getparamatpoint (cadr tr) (car tr)) (* k 0.001))))))) 0 1) "") ) ) ) (cond ( (and (not (eq el (entlast))) (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr)))) (if (not (eq (cadr tr) (entlast))) (entdel (cadr tr)) ) (if (not (or (equal (vlax-curve-getstartpoint (entlast)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (entlast)) (caddr tr) 1e-6) ) ) (progn (setq cx (entget (entlast))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (entlast)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (entlast) (vlax-curve-getpointatparam (entlast) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (entlast)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (entlast) (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) (if (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (ssadd (entlast) s) (if (not (eq el (entlast))) (progn (entdel (entlast)) (if (not (vlax-erased-p (cadr tr))) (ssadd (cadr tr) s) (progn (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (repeat (setq ii (sslength sx)) (if (or (and (equal (vlax-curve-getstartpoint (ssname sx (setq ii (1- ii)))) (car tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (caddr tr) 1e-6) ) (and (equal (vlax-curve-getstartpoint (ssname sx ii)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (car tr) 1e-6) ) ) (ssadd (ssname sx ii) s) ) ) ) ) ) (if (not (vlax-erased-p (cadr tr))) (ssadd (cadr tr) s) (progn (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (repeat (setq ii (sslength sx)) (if (or (and (equal (vlax-curve-getstartpoint (ssname sx (setq ii (1- ii)))) (car tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (caddr tr) 1e-6) ) (and (equal (vlax-curve-getstartpoint (ssname sx ii)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (ssname sx ii)) (car tr) 1e-6) ) ) (ssadd (ssname sx ii) s) ) ) ) ) ) ) ) ( (and (not (eq el (entlast))) (not (and (vlax-curve-getparamatpoint (cadr tr) (car tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))))) (entdel (cadr tr)) (setq sx (ssget "_C" (trans (car tr) 0 1) (trans (car tr) 0 1))) (setq e (car (vl-remove-if-not '(lambda ( x ) (vlax-curve-getparamatpoint x (caddr tr))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex sx)))))) (if (not (or (equal (vlax-curve-getstartpoint e) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint e) (caddr tr) 1e-6) ) ) (progn (setq cx (entget e)) (if (< (vlax-curve-getparamatpoint e (car tr)) (vlax-curve-getparamatpoint e (caddr tr))) (progn (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget e) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam e) (vlax-curve-getparamatpoint e (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) (progn (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.1) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.1) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.01) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.01) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) 0.001) (- (vlax-curve-getparamatpoint e (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget e) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto e (vlax-curve-getpointatparam e (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* (setq k (1+ k)) 0.1)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.01)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getparamatpoint e (caddr tr)) (vlax-curve-getstartparam e)) (* k 0.001)) (- (vlax-curve-getparamatpoint e (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) ) ) (ssadd e s) ) ( t (if (not (or (equal (vlax-curve-getstartpoint (cadr tr)) (caddr tr) 1e-6) (equal (vlax-curve-getendpoint (cadr tr)) (caddr tr) 1e-6) ) ) (progn (setq cx (entget (cadr tr))) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.1) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.1) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.01) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.01) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) 0.001) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) 0.001)))))) 0 1) "") (setq k 0) (while (equal cx (entget (cadr tr)) 1e-6) (command "_.TRIM" "" "_nea" (trans (vlax-curve-getclosestpointto (cadr tr) (vlax-curve-getpointatparam (cadr tr) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* (setq k (1+ k)) 0.1)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.1)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.01)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.01)) (if (> (- (vlax-curve-getendparam (cadr tr)) (vlax-curve-getparamatpoint (cadr tr) (caddr tr))) (* k 0.001)) (+ (vlax-curve-getparamatpoint (cadr tr) (caddr tr)) (* k 0.001))))))) 0 1) "") ) ) ) (if (and (vlax-curve-getparamatpoint (entlast) (car tr)) (vlax-curve-getparamatpoint (entlast) (caddr tr))) (ssadd (entlast) s) (if (not (eq el (entlast))) (progn (entdel (entlast)) (ssadd (cadr tr) s) ) (ssadd (cadr tr) s) ) ) ) ) ) (if (vl-some '(lambda ( x ) (if (wcmatch (cdr (assoc 0 (entget x))) "SPLINE,ELLIPSE") (setq e x))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))) (command "_.JOIN" e s "") (progn (command "_.PEDIT" "_M" s "" "_J" "_J" "_E" 0.0) (while (< 0 (getvar 'cmdactive)) (command "") ) ) ) (setq ray (entmakex (list '(0 . "RAY") '(100 . "AcDbEntity") '(100 . "AcDbRay") (cons 10 (trans p 1 0)) (cons 11 (getvar 'ucsxdir))))) (setq ss (ssget "_A")) (ssdel ray ss) (repeat (setq i (sslength ss)) (setq e (ssname ss (setq i (1- i)))) (setq ipp (vlax-invoke (vlax-ename->vla-object ray) 'intersectwith (vlax-ename->vla-object e) acextendnone)) (setq ippl (append ipp ippl)) ) (setq ipp nil) (repeat (/ (length ippl) 3) (setq ipp (cons (list (car ippl) (cadr ippl) (caddr ippl)) ipp)) (setq ippl (cdddr ippl)) ) (setq ippl (vl-sort ipp '(lambda ( a b ) (< (vlax-curve-getparamatpoint ray a) (vlax-curve-getparamatpoint ray b))))) (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (if (vlax-curve-getparamatpoint ent (car ippl)) (setq e ent) ) ) (entdel ray) (command "_.COPYBASE" "_non" '(0.0 0.0 0.0) e "") (command "_.UNDO" "_B") (command "_.PASTECLIP" "_non" '(0.0 0.0 0.0)) (sssetfirst nil (ssadd (entlast))) (*error* nil) )
Regards, M.R.
Message 15 of 71
marko_ribar
And now final touch... I think this is as much as good as LISP can offer, but it could be slow... And to mention, you must have it visible on screen, so no real BNDR like yours... At least the code is readable, so maybe someone can learn from it or use it somehow... I think I could get at least kudo for effort I showed... M.R.
  (vl-load-com)
    (if pea
    (if pck
    (if m
      (prompt m)
    (princ)
  (defun unit ( v )
    (vl-load-com)
      (vlax-tmatrix
        (append
          (mapcar
          (list '(0 0 0 1))
      (vlax-tmatrix
        (append
          (mapcar
          (list '(0 0 0 1))
    (if ss
      (progn
  (while (not ss)
  (initget 1)
  (setvar 'pickbox 1)
  (setq bb (subst (list (car (car bb)) (cadr (car bb)) 0.0) (car bb) bb))
  (setq bb (subst (list (car (cadr bb)) (cadr (cadr bb)) 0.0) (cadr bb) bb))
  (setq ky 0)
  (repeat 9
    (setq ky (1+ ky))
    (setq kx 0)
    (repeat 9
      (setq kx (1+ kx))
      (if (and (/= kx 1) (/= ky 1) (/= kx 9) (/= ky 9))
  (setq rec
    (entmakex
      (list
        '(0 . "LWPOLYLINE")
        '(90 . 4)
        '(70 . 1)
        (cons 10 (car bb))
        (cons 10 (cadr bb))
  (foreach pp pl
    (entdel li1)
    (entdel li2)
  (entdel rec)
  (foreach pp pll
    (ssdel c1 ss)
      (if ip
    (mapcar
        (foreach pp pll
          (setq ippl nil)
          (if ipp
          (entdel ray)
      ipl
      (cdr ipl)
    (setq ipl nil)
    (ssadd c1 ss)
  (foreach tr trl
  (foreach tr trl
      (entdel (cadr tr))
  (setq s (ssadd))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
        (entdel (cadr tr))
        (if
          (not
            (or
          (progn
              (progn
                (setq k 0)
              (progn
                (setq k 0)
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
    (entdel (cadr tr))
    (setq el (entlast))
    (if
      (not
        (or
      (progn
        (setq k 0)
    (cond
          (entdel (cadr tr))
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
                (ssadd (cadr tr) s)
                (progn
                    (if
                      (or
                        (and
                        (and
              (ssadd (cadr tr) s)
              (progn
                  (if
                    (or
                      (and
                      (and
        (entdel (cadr tr))
        (if
          (not
            (or
          (progn
              (progn
                (setq k 0)
              (progn
                (setq k 0)
        (ssadd e s)
      ( t
        (if
          (not
            (or
          (progn
            (setq k 0)
          (ssadd (entlast) s)
            (progn
              (entdel (entlast))
              (ssadd (cadr tr) s)
            (ssadd (cadr tr) s)
    (progn
        (command "")
  (ssdel ray ss)
  (setq ipp nil)
      (setq e ent)
  (entdel ray)
  (*error* nil)
Message 16 of 71
marko_ribar
Sorry...
This
  (setq rec
    (entmakex
      (list
        '(0 . "LWPOLYLINE")
        '(90 . 4)
        '(70 . 1)
        (cons 10 (car bb))
        (cons 10 (cadr bb))
Should be
  (setq rec
    (entmakex
      (list
        '(0 . "LWPOLYLINE")
        '(90 . 4)
        '(70 . 1)
        (cons 10 (trans (car bb) 1 (trans '(0.0 0.0 1.0) 1 0 t)))
        (cons 10 (trans (list (car (cadr bb)) (cadr (car bb))) 1 (trans '(0.0 0.0 1.0) 1 0 t)))
        (cons 10 (trans (cadr bb) 1 (trans '(0.0 0.0 1.0) 1 0 t)))
        (cons 10 (trans (list (car (car bb)) (cadr (cadr bb))) 1 (trans '(0.0 0.0 1.0) 1 0 t)))
Now where is that kudo?
M.R.
Message 17 of 71
ВeekeeCZ
Watching silently from a distance... It's certainly impressive! Very hope that the OP finds this useful!
Message 18 of 71
marko_ribar
Thanks for the kudo BeekeeCZ... I am wondering how many bedges you must have to become Expert Elite??? If you need some I can help you in that manner...
Message 19 of 71
ВeekeeCZ
I have no idea! Still have a lot to learn! Thanks for the offer 😉 but... please don't.
Message 20 of 71
dgorsman
EE membership is a matter of being nominated for consideration to the EE committee.  For more information, see here: http://www.autodesk.com/expert-elite/about
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
