alphanumeric sort in sequence
beachgirl6172
Message 1 of 25
beachgirl6172
Hi all, is there any lisp for alphanumeric sort in sequence by selection?
example : A21(5), A59(8), A73(29)...renumbering A1(5), A2(59), A3(29)?
Thank you.
Replies (24)
Message 3 of 25
komondormrex
hey there,
check this
(defun c:anum_seq_sort (/ text_sset index text_list)
	(if (setq text_sset (ssget '((0 . "text"))))
		(progn
			(setq index 0)
			(foreach text (vl-sort (mapcar 'vlax-ename->vla-object
										   (vl-remove-if 'listp (mapcar 'cadr (ssnamex text_sset)))
								   '(lambda (text_1 text_2) (> (cadr (vlax-get text_1 'insertionpoint))
															   (cadr (vlax-get text_2 'insertionpoint))
						  (vla-put-textstring
						  	text
							(strcat (vl-list->string
						  				(vl-remove-if
											'(lambda (asc) (member asc '(48 49 50 51 52 53 54 55 56 57)))
						  					 (vl-string->list (vl-princ-to-string
																(car (setq text_list
																		(read
																			(strcat "("
																					 (vla-get-textstring text)
								   (itoa (setq index (1+ index)))
								   (vl-princ-to-string (cadr text_list))
	(princ)
Message 4 of 25
beachgirl6172
if i need to start with another number? cannot define what number i want..
Message 5 of 25
beachgirl6172
thank you. thank you. i already try it before, there's not what i want.
Message 6 of 25
paullimapa
Questions
1. Is there always going to be a single alphabet in front? A and never AA
2. Up to how many digits would you have after the alphabet like 2 A99 or even 3 A999
3. Same questions go to the number within the parentheses (99) or (999)
Paul Li
IT Specialist
@The Office
Message 7 of 25
beachgirl6172
Answer :
1)yes. there's always single alphabet in front.
2) the biggest number maybe until 4 digit after the alphabet (A1 - A9999)
3) the number within the parentheses (1-999)
on this case i only need renumbering the alphanumeric but maintain the number within parentheses.
Message 8 of 25
komondormrex
then this one
(defun c:anum_seq_sort (/ text_sset text_list index)
		(progn
			(if (null index_saved) (setq index_saved 1))
			(initget 6)
			(if (null (setq index (getint (strcat "\nStart numbering with <" (itoa index_saved) ">: "))))
				(setq index index_saved)
						  (vla-put-textstring
						  	text
						  				(vl-remove-if
																		(read
																			(strcat "("
								   (itoa index)
			(setq index_saved index)
	(princ)
Message 9 of 25
beachgirl6172
I appreciate your help very much.. 😀🙏
Message 10 of 25
komondormrex
you are much welcome)
Message 11 of 25
beachgirl6172
this is the result i get....
I'm sorry to trouble you.
Message 12 of 25
komondormrex
wow these texts are vertical. will return with correction.
Message 13 of 25
beachgirl6172
sorry for my poor explanation.
actually my drawing like this.....
Message 14 of 25
komondormrex
this one implements fence selecting of texts (not on locked layers), thus enumerating will be done along fence pline drawn on active, not locked layer.
(defun make_points (coordinates_raw_list / point_list)
  	(if coordinates_raw_list
		(setq point_list (cons
							   (list (car coordinates_raw_list) (cadr coordinates_raw_list))
							   (make_points (cddr coordinates_raw_list))
  	point_list
(defun draw_fence (/ vertex fence vertices_list)
	(while (and (setq vertex (vl-catch-all-apply 'getpoint (if vertex (list vertex "\nPick next fence vertex: ")
																	  (list "\nPick 1st fence vertex: ")
				(null (vl-catch-all-error-p vertex))
		   (if (< 2 (length (setq vertices_list (append vertices_list (list (car vertex) (cadr vertex))))))
			   (if (null fence)
					(setq fence (vla-addlightweightpolyline (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
															(vlax-safearray-fill (vlax-make-safearray vlax-vbdouble
																									  (cons 1 (length vertices_list)))
																									  vertices_list
					(vlax-put fence 'coordinates vertices_list)
	(if (vl-catch-all-error-p vertex) (vla-erase fence) fence)
(defun c:anum_seq_sort (/ fence text_gap_selection text_sset text_list index)
	(if (setq fence (draw_fence))
		(progn
			(setq text_gap_selection (getvar 'textgapselection))
			(setvar 'textgapselection 1)
			(initget 6)
			(or (setq index (getint (strcat "\nStart numbering with <" (itoa index_saved) ">: ")))
			(foreach text (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr
																					(ssnamex (ssget "_f"
																									(make_points (vlax-get fence 'coordinates))
																								   '((0 . "text")))
						  (vla-put-textstring
						  	text
						  				(vl-remove-if
											'(lambda (asc) (member asc '(45 48 49 50 51 52 53 54 55 56 57)))
																		(read
																			(strcat "("
								   (itoa index)
								   (vl-princ-to-string (if (cadr text_list) (cadr text_list) ""))
			(vla-erase fence)
	(setvar 'textgapselection text_gap_selection)
	(princ)
updated
Message 15 of 25
beachgirl6172
i'm not sure whether i done correctly
attached herewith video for your reference
some of the number are not in order
but anyway many thanks for your helping.
Message 16 of 25
beachgirl6172
herewith the picture 😉
Message 17 of 25
komondormrex
i see
Message 18 of 25
komondormrex
check update in message 14.
Message 19 of 25
beachgirl6172
hi, @komondormrex
i get this error command
Message 20 of 25
beachgirl6172
the fence selection always start with number 1? can i define the number?
