Allowing numbers to be input with specific characters
saitoib
Message 1 of 8
saitoib
Hi all
I found that I can limit the input elements with initget
As another case, is it possible to eyeball a real number and a limited character, say T, and allow input?
I want to allow input only for numbers 0 and 1.5 and T.
Thank you very much for your help.
Saitoib
Replies (7)
Message 2 of 8
dbroad
(initget 1 "1 1.5 T")
(setq val (getkword "\nEnter value [1/1.5/T] : ")) ;will return answer in string form.
(setq val2 (cdr (assoc val '(("1" . 1)("1.5" . 1.5) ("T" . "T")))));This form converts numbers and keeps T as a string.
(setq val3 (read val));This form converts strings to numbers or to symbols.
EDIT:  Note that the 1 in the initget list and the prompt should've been 0, but you could use the same system for any set of numbers, strings, or symbols.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
Kent1Cooper
Another way, which will return numbers directly for 0.0 and 1.5 and also allow T as text:
(while (not (member whatever '(0 1.5 "T")))
  (initget "T"); allows "T" as input even to (getreal) function
  (setq whatever (getreal "\nEnter 0, 1.5 or T only: "))
It will keep asking again if a number other than 0 or 1.5 or text other than "T" is entered, but no conversion is needed afterward for allowed inputs [unless you want 0 as an integer instead of 0.0].
Kent Cooper, AIA
Message 4 of 8
CodeDing
@saitoib ,
In addition to what these other great forum members have to say, it might be useful for you to know where the resources are to research this information yourself also:
(initget ...)
https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-9ED8841B-5C1D-4B3F-9F3B-84A4408A6BBF
(getkword ...)
https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-9F940144-0D7B-4DA1-BF50-BBF8FB8DFF21
(getreal ...)
https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-503BBE86-9B22-456A-8883-1B5F5832B7E0
Hope that helps!
Best
~DD
Message 5 of 8
saitoib
I'm sorry, I didn't explain myself very well.
I want to allow input of any and all numbers and "T"
Saitoib
Message 6 of 8
Kent1Cooper
Then all you need is this:
  (setq whatever (getreal "\nEnter number or T only: "))
Kent Cooper, AIA
Message 7 of 8
saitoib
@Kent1Cooper
Okay.
So this was the original use of initget.
I learned a lot.
Thank you very much.
Saitoib
Message 8 of 8
dbroad
Based on your OP, limiting the input to 0, 1.5 or T, you selected an answer that didn't meet your original conditions.  Both post 2 and post 3 met those conditions but not the post marked as the solution.  You don't need to mark other solutions. I just thought I'd point that out for other future readers of the thread.
