Allow exploding outside the block editor
Message 1 of 11
i need to change the properties  (allow exploding "yes" "no") of block outside the block editor
Replies (10)
Message 2 of 11
_gile
You can change the Explodable ActiveX property of the block definition:
(setq doc (vla-get-Activedocument (vlax-get-acad-object)))
(vla-put-Explodable (vla-Item (vla-get-Blocks doc) blockName) :vlax-true)
Gilles Chanteau
GileCAD
GitHub
Message 3 of 11
_gile
Another way using entmod (this one should also work with MAC)
(setq dxf (entget (cdr (assoc 330 (entget (tblobjname "block" blockName))))))
(entmod (subst '(280 . 1) (assoc 280 dxf) dxf))
Gilles Chanteau
GileCAD
GitHub
Message 4 of 11
IT IS WINDOWS
HOW IT WILL WORK
NO IDEA
ITS NOT LISP
Message 5 of 11
_gile
Both snippets I posted are LISP and both will work on Window.
Just replace 'blockName' with the block name.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 11
_gile
I thought you were asking for help to write a routine by yourself.
Looks like you're hoping for a ready-made program instead.
(defun c:SETEXP (/ name blk btr expl opt)
  (while
    (not
      (and
        (setq name (getstring "\nEnter the block name: "))
        (setq blk (tblobjname "block" name))
     (prompt (strcat "\nBlock '" name "' not found"))
  (setq btr  (entget (cdr (assoc 330 (entget blk))))
        expl (cdr (assoc 280 btr))
  (initget "Yes No")
  (if (setq opt (getkword
                  (strcat "\nSet explodable [Yes/No] <"
                          (if (= 0 expl)
                            "No"
                            "Yes"
    (if (= opt "Yes")
      (if (= 0 expl)
        (entmod (subst '(280 . 1) (assoc 280 btr) btr))
      (if (= 1 expl)
        (entmod (subst '(280 . 0) (assoc 280 btr) btr))
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 7 of 11
waw
its really i am asking
can you modify it-like select multiple block instead of asking the block name
Message 8 of 11
_gile
(defun c:SETEXP (/ distinct setExplodable ss opt i lst)
  (defun distinct (l)
    (if l
      (cons (car l) (distinct (vl-remove (car l) l)))
  (defun setExplodable (name opt / btr)
    (setq btr (entget (cdr (assoc 330 (entget (tblobjname "block" name))))))
    (entmod (subst (cons 280 opt) (assoc 280 btr) btr))
  (if (setq ss (ssget '((0 . "INSERT"))))
    (progn
      (initget 1 "Yes No")
      (setq opt (if (= (getkword "\nSet explodable [Yes/No]: ") "Yes")
                  1
                  0
      (repeat (setq i (sslength ss))
        (setq lst (cons (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))) lst))
      (foreach n (distinct lst)
        (setExplodable n opt)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 9 of 11
Excellent, thank you!
Message 10 of 11
jzweygardt
That is brilliant! Thanks so much. This is going to help me A LOT. 🙂
Message 11 of 11
jzweygardt
Just curious, what would it take to modify this so it automatically selects all the blocks and makes them explodeable?
