All in one layer
All in one layer
All in one layer
Dear members..
Can anybody help me to make a lisp
which is help me to make some objects in one layer
Requiements are
* All dimensions to be change in to onle layer (layer name ---  Dim, layer colour number 1)
*All leaders  to be change in to onle layer (layer name ---  Leader,layer colour number 1 )
*All text to be change in to onle layer (layer name ---  Text ,layer colour number 3)
Thanks In advance for ur any reply....
hmsilva
 Perhaps something like this
(vl-load-com)
(defun c:demo (/ adoc lay layers laylst locklst x)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq layers (vla-Get-Layers adoc))
  (vlax-for lay layers
    (if (= (vla-get-lock lay) :vlax-true)
      (progn
        (setq locklst (cons (vla-get-name lay) locklst))
        (vla-put-lock lay :vlax-false)
  (setq laylst '(("Dim" 1) ("Leader" 1) ("Text" 3)))
  (mapcar '(lambda (x)
             (setq lay (vla-add layers (car x)))
             (vla-put-color lay (cadr x))
          laylst
  (vlax-for layt (vla-get-layouts adoc)
    (vlax-for blk (vla-get-block layt)
      (cond ((wcmatch (vla-get-objectname blk) "*Dimension*")
             (vla-put-layer blk "Dim")
            ((wcmatch (vla-get-objectname blk) "*Leader")
             (vla-put-layer blk "Leader")
            ((wcmatch (vla-get-objectname blk) "*Text")
             (vla-put-layer blk "Text")
  (if locklst
      (if (vl-position (vla-get-name lay) locklst)
        (vla-put-lock lay :vlax-true)
  (princ)
Hope that helps
Henrique
Hi,,Hmsilva
Thanks for your code..
It is working perfectly..Smiley Very Happy
Tdkhtr
hmsilva
You're welcome, Tdkhtr
Glad you got a solution!
Henrique
I recommend the Layer Director" lisp by Lee Mac
http://www.lee-mac.com/layerdirector.html
It is georgious.
Lee_Mac
It is georgious.
Thank you damian! Smiley Happy
Damian....
Thanks for your reply...I tried Lee-mac's lisp ...GREAT!!
(Tkanks Lee-mac)
