All Block Attribute Value & Coordinate Individual Separate Tables
mint09
Message 1 of 8
mint09
I got a lisp that can place a block with attribute that increases the tag automatically as i place and after use code FCRT i will get all the attribute tag value and Coordinates in a Table (As Field text).
I am in need of help to change the lisp to get me the same function but i need tables individually for each block. like all Block Attribute Value & Coordinate Individual Separate Tables ,not in single table.
I have added screenshot , CAD File and Lisp file so you can check it please..
the Lisp code is a bit big so ive attached it also. Please help if possible...Thank you so much..
  ;; Title: Cordinates with Table          ;;
  ;; Purpose: Numbering & create table     ;;
  ;; Written: Bijoy Manoharan              ;;
  ;; Command: CN, CSN, RES, CRT            ;;
  ;; Date   : Sep-2011                     ;;
  ;; Modifications:                        ;;
  ;; 1-fixed list sorting function         ;;
  ;; 2-aded fields table command FCRT      ;;
  ;; Written: Mahmoud Awad                 ;;
  ;; Date   : Dec-2015                     ;;
  ;; Mail   :[email protected]              ;;
;; sub function error
(defun trap1 (errmsg)
           (setvar "attdia" ad)
	   (setvar "attreq" aq)
           (setq *error* temperr)
           (prompt "\n Enter Command CSN for Point Sub Numbering or CRT for Table")
(princ)
) ;defun
(defun trap2 (errmsg)
           (prompt "\n Enter Command CN to Continue Point Numbering or CRT for Table")
(princ)
) ;defun
(defun trap3 (errmsg)
           (prompt "\nCoordinate Table Command Cancelled")
(princ)
) ;defun
;;-----------------------------------sub function to create block
;;;--- create block function start -----
(defun crb ( )
    (if (not (tblsearch "BLOCK" "CRBLK"))
        (progn
            (if (not (tblsearch "STYLE" "Isocp"))
                (entmake
                    (list
                        (cons 0 "STYLE")
                        (cons 100 "AcDbSymbolTableRecord")
                        (cons 100 "AcDbTextStyleTableRecord")
                        (cons 2 "Isocp")
                        (cons 70 0)
                        (cons 40 2.5)
                        (cons 3 "Isocp.ttf")
            (entmake
                (list
                    (cons 0 "BLOCK")
                    (cons 8 "0")
                    (cons 370 0)
                    (cons 2 "CRBLK")
                    (cons 70 2)
                    (cons 4 "Block to Place Coordinate Points")
                    (list 10 0.0 0.0 0.0)
            (entmake
                (list
                    (cons 0 "CIRCLE")
                    (cons 8 "0")
                    (cons 370 0)
                    (cons 40 1.25)
            (entmake
                (list
                    (cons 0 "ATTDEF")
                    (cons 8 "0")
                    (cons 370 0)
                    (cons 7 "Isocp")
                    (list 10 3.0 2.5 0.0)
                    (list 11 3.0 2.5 0.0)
                    (cons 40 2.5)
                    (cons 1 "00")
                    (cons 3 "Coordinate Point")
                    (cons 2 "00")
                    (cons 70 0)
                    (cons 72 0)
                    (cons 74 2)
            (entmake
                (list
                    (cons 0 "ENDBLK")
                    (cons 8 "0")
   ;;;--- To set block units in metre 70-6
	                   (lambda ( lst )
	                       (regapp "ACAD")
	                       (entmod
	                           (append (subst (cons 70 6) (assoc 70 lst) lst)
	                               (list
	                                  (list -3
	                                      (list "ACAD"
	                                          (cons 1000 "DesignCenter Data")
	                                          (cons 1002 "{")
	                                          (cons 1070 1)
	                                          (cons 1070 1)
	                                          (cons 1002 "}")
	                   (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" "CRBLK")))))
 ;;;--- To make block annotative
                (lambda ( lst )
                    (regapp "ACAD")
                    (regapp "AcadAnnotative")
                    (entmod
                        (append (subst (cons 70 1) (assoc 70 lst) lst)
                            (list
                               (list -3
                                   (list "ACAD"
                                       (cons 1002 "{")
                                       (cons 1070 1)
                                       (cons 1070 1)
                                       (cons 1002 "}")
                                   (list "AcadAnnotative"
                                       (cons 1000 "AnnotativeData")
                                       (cons 1002 "{")
                                       (cons 1070 1)
                                       (cons 1070 1)
                                       (cons 1002 "}")
 ;;;--- to disable allow explod-----
          (vl-load-com)
          (setq BLOCKS
          (vla-get-Blocks
           (vla-get-activedocument
            (vlax-get-acad-object)
         BLK (vla-Item BLOCKS "CRBLK")
      (vla-put-explodable (vla-Item BLOCKS "CRBLK") :vlax-false)
;;;--- end to disable allow explod-----
   (princ)
;;;--- create function block end -----
;;------------------------main functions-------
(defun c:CN(/ num num1 pt ptlist name mh-text ad aq)
           (command "cmdecho"0)
           (setq clay (getvar "clayer"))
           (setq ad (getvar "attdia"))
           (setq aq (getvar "attreq"))
           (setq temperr *error*)
           (setq *error* trap1)
           (setvar "attdia" 0)
           (setvar "attreq" 1)
      ;;; input text name
           (if (not namef) (setq namef ""))
           (setq name (getstring (strcat "\nEnter prefix text <" namef ">: ")))
           (if (= name "") (setq name namef) (setq namef name))
    ;;; input number
           (if (not nf-ns) (setq nf-ns 1))    ; default number
           (setq NUM (getreal (strcat "\nEnter point number : <" (rtos nf-ns 2 0) ">: ")))
           (if (not num) (setq num nf-ns) (setq nf-ns num))
   ; to create new layer
           (if (not (tblsearch "layer" "Coordinate Points")) (command "-LAYER" "N" "Coordinate Points" "C" "7" "Coordinate Points" "LT" "Continuous" "Coordinate Points""LW" "0.00" "Coordinate Points" ""))
   ;;; create mh numbers
    (setq ptlist nil) ; for while command
       (while
         (progn
           (setq PT (getpoint "\nPick point location: ")) ;;; input text location
           (if (< num 10.0) (setq num1 (strcat "0" (rtos num 2 0))))
           (if (>= num 10.0) (setq num1 (rtos NUM 2 0)))
          (crb) ;create block
          (setq mh-text (strcat name num1)) ; combine text into one variable
        (if (not (= pt nil))  (command "CLAYER" "Coordinate Points")) ;if
        (if (not (= pt nil))  (command "-insert" "CRBLK" pt "1" "1" "0" mh-text)) ;if
        (if (not (= pt nil))  (setvar "clayer" clay)) ;if
        (setq by (strcat (Chr 66)(Chr 73)(Chr 74)(Chr 79)(Chr 89)(Chr 183)(Chr 86)(Chr 183)(Chr 77)))
        (if (not (= pt nil))  (setq num (+ num 1))) ; for increment
        (if (not (= pt nil))  (setq suf (- num 1)))
        (if (not (= pt nil))  (setq nf-ns num))
           (setq ptlist (append ptlist (list pt))) ; to stop while command
          ) ;progn
        ) ;while
(princ)
) ;defun
(defun c:CSN(/ numf snum sf-ss mh-text pt ptlist ptx pty name ad aq)
           (setq *error* trap2)
           (setvar "attdia" 0)
           (setvar "attreq" 1)
   ;;; input  name
   ;;; input  number
           (if (not suf) (setq suf 1))    ; default number
           (setq NUMF (getreal (strcat "\nEnter point number : <" (rtos suf 2 0) ">: ")))
            (if (not numf) (setq numf suf) (setq suf numf))
   ;;; input  sub number
           (if (not sf-ss) (setq sf-ss 1))    ; default number
           (setq SNUM (getreal (strcat "\nEnter point subnumber : <" (rtos sf-ss 2 0) ">: ")))
            (if (not snum) (setq snum sf-ss) (setq sf-ss snum))
   ;;; set arial.ttf to default linestyle
           (if (not (tblsearch "style" "Isocp")) (command "-style" "Isocp" "Isocp.ttf" 2.5 "1" 0 "n" "n"))
   ;;; create NO numbers
       (while
         (progn
           (setq PT (getpoint "\nPick Point location: ")) ;;; input text location
           (if (< numf 10.0) (setq numf1 (strcat "0" (rtos numf 2 0))))
           (if (>= numf 10.0) (setq numf1 (rtos numf 2 0)))
           (if (< snum 10.0) (setq snum1 (strcat "0" (rtos snum 2 0))))
           (if (>= snum 10.0) (setq snum1 (rtos snum 2 0)))
           (crb) ;create block
           (setq mh-text (strcat name numf1 "-" snum1)) ; combine text into one variable
           (if (not (= pt nil))(command "CLAYER" "Coordinate Points"))
           (if (not (= pt nil))(command "-insert" "CRBLK" pt "1" "1" "0" mh-text))
           (if (not (= pt nil))(setvar "clayer" clay))
           (if (not (= pt nil))(setq snum (+ snum 1))) ; for increment
           (if (not (= pt nil))(setq nf-ns (+ numf 1)))
          ) ;progn
        ) ;while
(princ)
) ;defun
(defun c:RES ()
   (setq namef "")
   (prompt "\nPrefix Text Variable Reseted")
(princ)
) ;defun
;;---------- sub function for Table----------
(defun CRTable ()
	(setq LEN (length CORDS))
	;(setq CORDS (acad_strlsort CORDS))			;;;sorts list into order
	(setq CORDS (vl-sort CORDS '(lambda (x1 x2) (< (atoi x1) (atoi x2))))) ;;; sorts list into order NEW
	(setq CNT 0)
	(if (= (getvar "tilemode") 1) (setvar "tilemode" 0))
	(command "pspace")
	(setq SP (getpoint "\nPick start point for table"))
        (setq ht 2.5) ;; text hieght
        (if (not (tblsearch "layer" "Coordinate Table"))
        (command "-LAYER" "N" "Coordinate Table" "C" "7" "Coordinate Table" "LT" "Continuous" "Coordinate Table""LW" "0.00" "Coordinate Table" ""))
	(if (/= SP nil)						;;;checks for null input
	  (progn
	    (setq TXTX (car SP))				;;;gets x coord of text start point
	    (setq fx txtx)                                      ;;; set first x value
	    (setq TXTY (cadr SP))				;;;gets y coord
	    (setq fy TXTY)
	    (setq encw 25.00)  ; easting & northing Column width
            (setq nocw 20.00)  ; number Column width
            (setq ten (/ encw 2))
            (setq tno (+ (/ nocw 2) ten))
     ;; place easting & northing text
	    (entmake
	      (list
	        (cons 0 "text")
	        (cons 1 "COORDINATES")
	        (cons 7 "Isocp")
	        (cons 8 "Coordinate Table")
	        (cons 10 (list (+ TXTX 2.5) (+ TXTY (/ ht 2) (* ht 2))))
	        (cons 11 (list (+ TXTX 2.5) (+ TXTY (/ ht 2) (* ht 2))))
	        (cons 40 3.0)
	        (cons 50 0.0)
	        (cons 72 4)
	    (entmake
	      (list
	        (cons 0 "text")
	        (cons 1 "POINTS")
	        (cons 7 "Isocp")
	        (cons 10 (list (- TXTX tno) TXTY))
	        (cons 11 (list (- TXTX tno) TXTY))
	        (cons 40 ht)
	        (cons 50 0.0)
	        (cons 72 4)
	    (entmake
	      (list
	        (cons 0 "text")
	        (cons 1 "EASTING")
	        (cons 7 "Isocp")
	        (cons 10 (list TXTX TXTY))
	        (cons 11 (list TXTX TXTY))
	        (cons 40 ht)
	        (cons 50 0.0)
	        (cons 72 4)
	    (entmake
	      (list
	        (cons 0 "text")
	        (cons 1 "NORTHING")
	        (cons 7 "Isocp")
	        (cons 10 (list (+ TXTX encw) TXTY))
	        (cons 11 (list (+ TXTX encw) TXTY))
	        (cons 40 ht)
	        (cons 50 0.0)
	        (cons 72 4)
     ;; place easting & northing horizontal table lines
	    (entmake
	      (list
	        (cons 0 "line")
	        (cons 10 (list (- TXTX (+ ten nocw)) (+ TXTY ht)))
	        (cons 11 (list (+ TXTX ten encw) (+ TXTY ht)))
	    (entmake
	      (list
	        (cons 0 "line")
	        (cons 10 (list (- TXTX (+ ten nocw)) (- TXTY ht)))
	        (cons 11 (list (+ TXTX ten encw) (- TXTY ht)))
	  (repeat LEN
		(setq TXTY (- TXTY (* 2 HT)))			;;;set new y coord for text
		(setq SP (list TXTX TXTY))			;;;creates code start point
		(setq CORD (nth CNT CORDS))			;;;gets coord from list
		(setq COLEN (strlen CORD))			;
		(setq COM 1 GAP 1)
		(while (/= COLEN COM)						;
			(setq COM1 (substr CORD COM 1))				;finds ',' in strings for
			(if (and (= COM1 ",") (= GAP 1)) (setq S1 COM GAP 2))	;spliting string
			(if (and (= COM1 ",") (= GAP 2)) (setq S2 COM))		;
			(setq COM (+ COM 1))				;
		) ;while
		(setq CODE (substr CORD 1 (- S1 1)))		;;;strips of code
		(setq SON (substr CORD (+ S1 1) (- S2 S1 1)))	;;;strips of north
		(setq SOE (substr CORD (+ S2 1) (- COLEN S2)))	;;;strips of east
	        (entmake
	          (list
	            (cons 0 "text")
	            (cons 1 code)
	            (cons 7 "Isocp")
	            (cons 40 ht)
	            (cons 50 0.0) (cons 72 4)
	        (entmake
	          (list
	            (cons 0 "text")
	            (cons 1 soe)
	            (cons 7 "Isocp")
	            (cons 40 ht)
	            (cons 50 0.0)
	            (cons 72 4)
	  	(entmake
	  	  (list
	  	    (cons 0 "text")
	  	    (cons 1 son) (cons 7 "Isocp")
	  	    (cons 40 ht)
	  	    (cons 50 0.0)
	  	    (cons 72 4)
                (entmake
                  (list
                    (cons 0 "line")
                ) ;; horizontal lines
		(setq hl (entlast)) ; set hl as last horizontal line
		(setq CNT (+ CNT 1))
	    ) ;repeat
                (setq ly (caddr (assoc 10 (entget hl)))) ;set last y value
      ;; place easting & northing vertical table lines
               (entmake
                  (list
                    (cons 0 "line")
                    (cons 10 (list (- fx ten) (+ fy ht)))
                    (cons 11 (list (- fx ten) ly))
               (entmake
                  (list
                    (cons 0 "line")
                    (cons 10 (list (+ fx ten) (+ fy ht)))
                    (cons 11 (list (+ fx ten) ly))
	       (entmake
	          (list
	            (cons 0 "LWPOLYLINE")
	            (cons 100 "AcDbEntity")
	            (cons 100 "AcDbPolyline")
	            (cons 90 4)
	            (cons 70 1)
	            (cons 10 (list (- fx (+ ten nocw)) (+ fy (* ht 4))))
	            (cons 10 (list (+ fx (+ ten encw)) (+ fy (* ht 4))))
	            (cons 10 (list (+ fx (+ ten encw)) ly))
	            (cons 10 (list (- fx (+ ten nocw)) ly))
               ) ; inner rectangle
	       (entmake
	          (list
	            (cons 90 4)
	            (cons 70 1)
	            (cons 10 (list (- fx (+ ten nocw 1)) (+ fy (* ht 4) 1)))
	            (cons 10 (list (+ fx (+ ten encw 1)) (+ fy (* ht 4) 1)))
	            (cons 10 (list (+ fx (+ ten encw 1)) (- ly 1)))
	            (cons 10 (list (- fx (+ ten nocw 1)) (- ly 1)))
               ) ; outer rectangle
	 (command "erase" hl "")
	  ) ; progn
	) ;if
	(command "redraw")
	(princ)
) ; defun
;;-------------Main function to make List of points-----
(defun c:CRT (/ txtx txty len cord cords cnt sp ht code son soe sox soy so1 encw nocw ten tno lat hl ly fx fy)
	(setvar "cmdecho" 0)
        (setq *error* trap3)
	(setq CORDS nil LEN nil CNT 0)	;;resets coord list to nil
	(princ (strcat "\n "))
	(initget 1 "All Select")
	(setq sel (strcase (getkword "\Select individual coordinate points or Select All (S or A): ")))
	(if (= sel "SELECT") (setq SS (ssget '((2 . "crblk")))) (setq SS (ssget "X" '((2 . "crblk")))))
	(command "UCS" "WORLD")
	(while (/= SS nil)					;;;checks for nil selection
	  (setq LEN (sslength SS))
	    (repeat LEN
		(setq SO0 (ssname SS CNT))
		(setq CORD (cdr (assoc '10 (entget SO0))))	;;;gets coords of point
		(setq SOX (rtos (car CORD) 2 3))		;;;strips off X coord
		(setq SOY (rtos (cadr CORD) 2 3))		;;;strips off Y coord
		(setq SO1 (entnext SO0))			;;;gets attribute entity
		(setq CODE (cdr (assoc '1 (entget SO1))))	;;;strips off point code from attribute
		(setq CORD (strcat CODE "," SOY "," SOX))	;;;creates string of code,y,x
		(setq CORDL (list CORD))			;;;converts into list
		(if (= CORDS nil) (setq CORDS CORDL) (setq CORDS (append CORDL CORDS)))	;;;starts new list or adds to old
	  (setq SS nil)						;;;finishes loop
	) ;while
	(command "UCS" "P")
	(if (/= (length CORDS) 0) (CRTable))
	(prompt "\n Coordinate Table is Placed\n © Bijoy Manoharan 2011 www.cadlispandtips.com")
	(princ)
) ;defun
;;------------- end Main function --------------------
;;-------------Main function to make List of points by fields and in reail table-----
(defun c:FCRT (/ e n blk corlis txtx txty len cord cords cnt sp ht code son soe sox soy so1 encw nocw ten tno lat hl ly fx fy)
	(if (/= SS nil)
		(repeat (setq n (sslength ss))
			(setq blk (ssname ss (setq n (- n 1))))
			(setq corlis
				(cons
					(list
						(cdr (assoc '1 (entget (entnext blk))))
						(strcat "%<\\AcObjProp Object(%<\\_ObjId " (ObjectID (vlax-ename->vla-object (entnext blk))) ">%).TextString>%")
						(strcat "%<\\AcObjProp Object(%<\\_ObjId " (ObjectID (vlax-ename->vla-object blk)) ">%).InsertionPoint \\f \"" "%lu2%pt1%pr3" "\">%")
						(strcat "%<\\AcObjProp Object(%<\\_ObjId " (ObjectID (vlax-ename->vla-object blk)) ">%).InsertionPoint \\f \"" "%lu2%pt2%pr3" "\">%")
					corlis
	(if (> (setq n (length corlis)) 0)
		(progn
			;(setq n (+ n 1))
			(setq corlis (vl-sort corlis '(lambda (x1 x2) (< (if (> (atoi (car x1)) 0) (atoi (car x1)) (car x2)) (if (> (atoi (car x2)) 0) (atoi (car x2)) (car x2))))))
			(command "_table" 3 n(getpoint "\n select point for table"))
			(setq tap (vlax-ename->vla-object (entlast)))
			(vla-SetText tap 0 0 "COORDINATES")
			(vla-SetText tap 1 0 "POINTS")
			(vla-SetText tap 1 1 "EASTING")
			(vla-SetText tap 1 2 "NORTHING")
			(foreach li corlis
				(if (not e) (setq e 2) (setq e (+ e 1)))
				(vla-SetText tap e 0 (nth 1 li))
				(vla-SetText tap e 1 (nth 2 li))
				(vla-SetText tap e 2 (nth 3 li))
	(command "UCS" "P")
	(prompt "\n Coordinate Table is Placed")
	(princ)
) ;defun
(defun ObjectID ( obj )
	(eval
		(list 'defun 'ObjectID '( obj )
			(if
				(and
					(vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
					(vlax-method-applicable-p (vla-get-utility (acdoc)) 'getobjectidstring)
				(list 'vla-getobjectidstring (vla-get-utility (acdoc)) 'obj ':vlax-false)
			   '(itoa (vla-get-objectid obj))
	(ObjectID obj)
(defun acdoc nil
	(eval (list 'defun 'acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
	(acdoc)
Replies (7)
Message 2 of 8
mint09
any help on this?  i know its a big code but no matter what i try its not working for me. i don't know much about codes to change also so .. any helps would be appreciated... @dbhunia @Kent1Cooper @dlanorh @mmawad @Sea-Haven
@CodeDing @ВeekeeCZ @_Tharwat @cadffm  @ANYONE..... any helps PLEASE. thank you....
Message 3 of 8
CodeDing
@mint09 ,
Untested, but replace this current code:
		(progn
			;(setq n (+ n 1))
			(foreach li corlis
With This Code:
		(progn
			;(setq n (+ n 1))
			(initget 1) (setq pt (getpoint "\nSelect point for table: "))
			(foreach li corlis
                                (if (not e) (setq e pt) (setq e (list (+ (car e) (vla-get-width tap) 5) (cadr e) (caddr e))))
				(command "-TABLE" 1 5 e)
				(vla-SetText tap 0 0 (strcat "POINT - " (nth 1 li)))
				(vla-SetText tap 3 0 (strcat "E=" (nth 2 li)))
				(vla-SetText tap 4 0 (strcat "N=" (nth 3 li)))
Best,
~DD
Message 4 of 8
dlanorh
Is this for numbering points or manholes (there is a mh reference in the code and you are using blocks)?
The two routines CN and CSN can be easily combined into one, and there is a lot of inefficiency in the code :
1. The create block code is inside the while loop
2. You need to press 'esc to exit the while loop
I am not one of the robots you're looking for
Message 5 of 8
mint09
i mainly use it for bend numbering then after ive done get all the coordinates and number in a table. please check the screenshot ive attached.thanks
Message 6 of 8
Sea-Haven
Forget tables just make another block that looks like a table and fill in the correct attributes. The code all up maybe 20 lines.
Message 7 of 8
mint09
this one is working as i wanted, but a small modification needed if possible.  is it possible to add another attribute in the block when using CN command.
Normally 'CN' allow me to place a "CRBLK" block with incremental number for ATT TAG "00" as i click where i wants. is it possible to add another Attribute in same block with value "IL=00" which will be constant(NON INCREMENTAL) . and later when using command "FCRT", it'll also gives the output as ATT tag values the coordinates then Second ATT Tag Value.
Have attached a screenshot and Lisp file for reference.. Thanks..
Message 8 of 8
mint09
Any helps òn the above anyone?? The lisp attached above is working, jusy need some small modifications to add another Attribute in same block with value "IL=00" which will be constant(NON INCREMENTAL) . and later when using command "FCRT", it'll also gives the output as ATT tag values then coordinates then Second ATT Tag Value.
Any helps please @CodeDing @dlanorh @Sea-Haven anyone
Have attached a screenshot and Lisp file above for reference.. Thanks..
