Align Blocks to line - lisp
pukkalapoom
Message 1 of 11
pukkalapoom
Hi
I searched lot for this activity but could not find. please do the needful
I placed several blocks in the drawing. But the problem is that these blocks are scattered around.
I want to have a lisp that will align these blocks so that they line up at the line.
Please see the attached picture. I have shown my current condition and how I want the results.
Thank you very much.
Replies (10)
Message 2 of 11
Kent1Cooper
You should be able to use something like >this<.  It puts them in a horizontal row, but could be adjusted for a vertical column.  See also Messages 19 and 24 in the same Topic, for different methods of selection.
Another possibility is BlockChart.lsp, >here<.
Kent Cooper, AIA
Message 3 of 11
Kent1Cooper
I found what could be a better one to use as a basis -- BlockChartInternal.lsp, >here<.  It's about Blocks in the drawing, not drawing files in a folder.  It also puts one of every Block defined into its chart, not based on User selection of existing objects, but its positioning aspect should be translatable easily enough.
Kent Cooper, AIA
Message 4 of 11
Sea-Haven
Maybe another, no error checks etc just Inserts at moment. Based on Insert point. As per image depends on location of insert point.
(defun c:wow ( / obj obj2 pt1 pt2)
(setq obj (vlax-ename->vla-object (car (entsel "\nSelect a object "))))
(setq ss (ssget '((0 . "Insert"))))
(if (= ss nil)
(alert "Incorrect objects selected")
(progn
(repeat (setq x (sslength ss))
(setq obj2 (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq pt1 (vlax-get obj2 'Insertionpoint))
(setq pt2 (vlax-curve-getclosestpointto obj pt1))
(vlax-put obj2 'Insertionpoint pt2)
(princ)
Message 5 of 11
pukkalapoom
received with many thank. I will test and let you know for the feedback.
Message 6 of 11
pukkalapoom
Want to be able to set line spacing.
Message 7 of 11
pbejse
From what point will the offset originate? from the lowest or topmost ?
Message 8 of 11
Sea-Haven
Dont forget the angle answer, can see 2 variations at least horizontal and vertical.
Message 9 of 11
pukkalapoom
topmost
Message 10 of 11
pbejse
@pukkalapoom wrote:
topmost
In reference to @Sea-Haven's post about variations
Can you confirm for us if that variations exist? if Yes, what is the origin point for horizontal? Left most?
Message 11 of 11
Sea-Haven
I was thinking pick top of line then go down form 1st perp point, or for horizontal left or right end controls, then use angle of line for direction with Polar for points. Just busy at moment.
