Align blocks center
Align blocks center
StanThe
Message 1 of 9
Align blocks center
StanThe
I got a lisp routine from this forum that will align a multitude of blocks down the left side
without regard to any text. I need it to align down the center of the blocks like the picture i've included.
I've manipulated the lisp to only do this vertically and i don't remember who gave this to me to
begin with but thank you!!!
SH
Replies (8)
Message 2 of 9
dlanorh
The lisp is by pBe. What decides the vertical alignment x coord?
I am not one of the robots you're looking for
Message 3 of 9
StanThe
When i dug into this lisp and wrote the notes about what each part does i could've told you about the "x" but it's been too long.
I don't understand the lambda and that's probably the part that needs changed.
SH
Message 4 of 9
StanThe
If anyone has a different way to align the polyline part of the blocks down the center that would be great too!
SH
Message 5 of 9
ВeekeeCZ
We could kindly ask the author himself @pbejse if he has some time to make the adjustment.
Message 6 of 9
StanThe
Thank you! Message sent!
SH
Message 7 of 9
Kent1Cooper
@StanThe wrote:
.... I've manipulated the lisp to only do this vertically ....
Without having studied the whole thing in detail, I did notice something that could give you trouble:
I expect this [in the "VERTICAL OR HORIZONTAL" area]:
  (setq opt V)
should really be setting it as a text string:
  (setq opt "V")
Kent Cooper, AIA
Message 8 of 9
StanThe
If someone could explain the "lambda" parts to me or direct me where to look (Lambda for Dummies???  lol) i can figure this out. Please!
SH
Message 9 of 9
Kent1Cooper
[This shouldn't have been in reply to me, but in any case....]
Admittedly Help about the (lambda) function is perhaps too terse, but as it says there, it's a way to define a function right where it is to be used, without having to give it a name as you would with (defun).  It takes some getting used to, but I'll try to explain one of its uses in that code, namely:
(setq
  points (mapcar '(lambda (n) (list (car n) (cadr n) 0.0)) points)
This takes a list of points [here in the 'points' variable] and converts it to a list in which all the points have the same X and Y coordinates they started with, but all have Z=0.0.  Broken out:
(mapcar  ;; apply following function across all items in list argument after function definition
  '(lambda  ;; open function definition
    (n)  ;; argument: stand-in within function for item from source list
    (list  ;; make a [in this case, point-coordinates] list of:
      (car n)  ;; X coordinate pulled from source item's point list
      (cadr n)  ;; Y coordinate pulled from source item's point list
      0.0  ;; Z coordinate the same for all, regardless of source's Z coordinate
    ); list
  ); lambda  ;; end function definition
  points  ;; list to apply function across
); mapcar
This (mapcar) function employing that (lambda) function returns the converted list of points, with all points forced into the drawing plane at Z=0 [in this case replacing  the original list, since the surrounding (setq) function uses the same variable name for the replacement as for the original].
Kent Cooper, AIA
