Align attribute to 3Dpolylind - LISP modification
yu85.info
Message 1 of 8
yu85.info
I have this lisp written kindly by @marko_ribar.
It aligns attribute to 3Dpolyline.
It is grate. But in the DWG file attached the 3D polyline and the blocks where inserted separately so I think there is a small  gap  of 0.000... between the insertion point of the block and the vertex of the 3D polyline so for some reason the lisp does not work.
If someone could help me modify it I will really appreciate the help.
This is the lisp:
(defun c:aliblopols ( / LM:MakeReadable s i pol ss loop n lstpar blo p dir lstpar )
(defun LM:MakeReadable ( a )
;; © Lee Mac 2010
(lambda ( a )
(cond
( (and (> a (/ pi 2)) (<= a pi))
(- a pi)
( (and (> a pi) (<= a (/ (* 3 pi) 2)))
(+ a pi)
( t a )
(rem a (* 2 pi))
(prompt "\nSelect polyline entities on which you want to make block alignments readable...")
(setq s (ssget (list (cons 0 "*POLYLINE"))))
(repeat (setq i (sslength s))
(setq pol (ssname s (setq i (1- i))))
(setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 "M1502_P"))))
(if (= (logand 1 (cdr (assoc 70 (entget pol)))) 1)
(setq loop (fix (vlax-curve-getEndParam pol)))
(setq loop (1+ (fix (vlax-curve-getEndParam pol))))
(setq n -1)
(repeat loop
(setq lstpar (cons (vlax-curve-getpointatparam pol (setq n (1+ n))) lstpar))
(setq n -1)
(repeat (sslength ss)
(setq blo (ssname ss (setq n (1+ n))))
(setq p (cdr (assoc 10 (entget blo))))
(if (member p lstpar)
(progn
(setq dir (LM:MakeReadable (angle (list 0.0 0.0) (vlax-curve-getFirstDeriv pol (vlax-curve-getparamatpoint pol p)))))
(vlax-put (vlax-ename->vla-object blo) (quote rotation) dir)
(setq lstpar nil)
(princ)
(prompt "\nType ALIBLOPOLS to run the topo point alignment command on a polyline(s)\n")
(princ)
Replies (7)
Message 2 of 8
ronjonp
@yu85.info Give this a try, the comparison needed a 'fuzz' value using the function 'EQUAL' to compare the points:
(defun c:aliblopols (/ lm:makereadable blo dir i loop lstpar n p pol s ss)
  (defun lm:makereadable (a)
    ;; © Lee Mac 2010
    ((lambda (a)
       (cond ((and (> a (/ pi 2)) (<= a pi)) (- a pi))
	     ((and (> a pi) (<= a (/ (* 3 pi) 2))) (+ a pi))
	     (t a)
      (rem a (* 2 pi))
  ;; RJP » Check that block definition exists
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 "M1502_P"))))
	(setq loop (fix (vlax-curve-getendparam pol)))
	(setq loop (1+ (fix (vlax-curve-getendparam pol))))
      (setq n -1)
      (repeat loop (setq lstpar (cons (vlax-curve-getpointatparam pol (setq n (1+ n))) lstpar)))
      (setq n -1)
	(if ;; RJP » 2025-01-08 Need to use a fuzz value, this is typical for comparing any reals
	    (vl-some '(lambda (x) (and (equal p x 1e-2) (setq p x))) lstpar)
	  ;; (member p lstpar)
	  (progn (setq dir (lm:makereadable
				    ;; RJP » Use 'equal' point from polyline list to get param
				    (vlax-curve-getfirstderiv pol (vlax-curve-getparamatpoint pol p))
		 ;; RJP » Cleanup, move block to 'equal' point
		 (vlax-put (vlax-ename->vla-object blo) 'insertionpoint p)
		 ;; RJP » Remove point from list so it does not get processed twice
		 (setq lstpar (vl-remove p lstpar))
      (setq lstpar nil)
    (print "Need block definition 'M1502_P' for this to work...")
  (princ)
(princ)
Message 3 of 8
yu85.info
Thank you sir for helping me.
It is greate!
Message 4 of 8
ronjonp
Glad to help 🙂
Message 5 of 8
yu85.info
Sorry to disturb you again @ronjonp but can you think it could be modified to work on every block and not just M1502_P?
Like the DWG2 I attached where there are many blocks
Thanks in advance
Message 6 of 8
ronjonp
Thanks in advance
@yu85.info Take this out of the filter to get all blocks:
(cons 2 "M1502_P")
Message 7 of 8
yu85.info
Thank you very much sir!
Message 8 of 8
ronjonp
Glad to help 🙂
