After nentsel check if the object is part of a block or not
eakos1
Message 1 of 12
eakos1
I want to let select polylines inside a block or not inside a block. So I need an if function to decide if it is inside or not because I will be needed run different codes.
How can I do it? Can someone help me ?
Replies (11)
Message 2 of 12
ВeekeeCZ
Just check the length of returning list. Whether it's 2 (single entity) or 4 (nested entity)
It's too easy...
(defun c:test ()
  (if (setq s (nentsel))
    (if (= 4 (length s))
      "nested"
      "main"))
Message 3 of 12
komondormrex
won't work with block's attribute.
Message 4 of 12
komondormrex
with any of block's nested entity
(if (= "AcDbBlockReference"
       (vla-get-objectname
	 (vla-objectidtoobject
	   (vla-get-activedocument (vlax-get-acad-object))
	   (vla-get-ownerid (vlax-ename->vla-object (car (nentsel "\nPick ename to check nestedness: "))))
    (princ "\nBlock Nested")
    (princ "\nRaw")
Message 5 of 12
eakos1
Sorry, but this works not.
I've just made a simple POLYLINE, put it in a BLOCK and always shows as result: nRaw
In your program is "AcDbBlockReference" as criteria, but in reality it gives as result for me: "AcDbBlockTableRecord"
And if I have an "heavy" POLYLINE in a block than your code gives as result: "AcDb2dPolyline"
So this is code is not reliable.
Message 6 of 12
eakos1
nentsel is somehow tricky, if I check the type with this way (cdr (assoc 0 (entget (car a)))),
light POLYLINE: "LWPOLYLINE"
heavy POLILINE: "VERTEX
however with entsel selection:
heavy POLILINE: "POLYLINE
I don't know why it is so.
Message 7 of 12
Sea-Haven
Just a thought (ssget pt) the pt is the (cadr of the (nentsel the returned ssget should be 1 item and object type should be a "INSERT". have used this often to get an attribute and then the block as 1 pick.
Message 8 of 12
eakos1
Thanks, it works 🙂
Even by blocks with attributes
(if (= "INSERT"
       (cdr
	 (assoc	0
		(entget
		  (ssname (ssget (cadr (setq a (nentsel "\n Select the object which can be inside of a BLOCK too"))))
			  0
		  ) ;_ ssname
		) ;_ entget
	 ) ;_ assoc
       ) ;_ cdr
    ) ;_ =
  (princ "\nRaw")
Message 9 of 12
komondormrex
well, sadly yes.
another one to check nestedness to a certain block, modelspace and paperspace included.
(defun c:check_nestedness (/ block_group nename)
	(if (setq block_group (assoc 2 (entget (cdr (assoc 330 (setq nename (entget (car (nentsel)))))))))
	  	(princ (strcat "\n \"" (cdr (assoc 0 nename)) "\" nested in block \"" (cdr block_group) "\""))
	  	(if (setq block_group (assoc 2 (setq nename (entget (cdr (assoc 330 nename))))))
		  (if (setq block_group (assoc 2 (entget (cdr (assoc 330 nename)))))
		    (princ "\nRaw")
  	(princ)
Message 10 of 12
eakos1
I think it work not well.
If I select a simple LINE not in BLOCK I get this result:
"LINE" nested in block "*MODEL_SPACE"
"\n \"LINE\" nested in block \"*MODEL_SPACE\""
It is good that shows where the LINE is located, but it is not a BLOCK. The result should  be "Raw", am I right? I newer get "Raw" result.
In case of BLOCK selection it works fine.
Message 11 of 12
ВeekeeCZ
The relation VERTEX to POLYLINE is the same as ATTRIB to INSERT.
Read more HERE about heavy polylines.
Message 12 of 12
komondormrex
that is because every entity belongs to a certain block. if an entity not belongs to a custom block it should belong to the model space or paper space block, because as a matter of fact they're blocks. if you want to exclude spaces from result you may try the code following.
	  	(setq nename (cdr (assoc 0 nename)))
		    (princ "\nRaw")
	(if (or (= "*Model_Space" (cdr block_group)) (= "*Paper_Space" (cdr block_group)))
		(princ (strcat "\n \"" nename "\" is raw"))
		(princ (strcat "\n \"" nename "\" nested in block \"" (cdr block_group) "\""))
  	(princ)
