-AECOBJEXPLODE help
-AECOBJEXPLODE help
gccdaemon
Message 1 of 15
-AECOBJEXPLODE help
gccdaemon
Due to export to AutoCAD failing to create a file when attached x-refs have the same data referenced surface in it, I've decided to create an export routine for sending clients our files. The problem I run into is that I want to use "-aecobjexplode" in the routine, but I've noticed that it has a variant (Guessing it's multiple view related?). I need help trying to create an (if statement that determines what the variant is and chooses between the following options:
(Command "-aecobjexplode" "Y" "Y" "Y" "Y" "N" "Y")
(Command "-aecobjexplode" "Y" "A" "N" "Y" "Y" "Y" "N" "Y")
I believe that the one with the "A" shows in files that contain multiple views.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Replies (14)
Message 2 of 15
CodeDing
@gccdaemon ,
Maybe this?
(command "-AECOBJEXPLODE" "Y") (command)
(if (wcmatch (strcase (getvar 'LASTPROMPT)) "*EXPLODE TO ANONYMOUS BLOCKS*")
  (command "-AECOBJEXPLODE" "Y" "Y" "Y" "Y" "N" "Y")
  (command "-AECOBJEXPLODE" "Y" "A" "N" "Y" "Y" "Y" "N" "Y")
);if
Message 3 of 15
gccdaemon
It's working for the "A" option, but not the the other. I modified it to just "*anonymous*" in case it was case sensitive, and it still didn't work. I don't think it's catching the previous prompt correctly.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 4 of 15
CodeDing
It is case sensitive, which is why I included the strcase function.
Can you post the command history when you manually run both versions of the command? That should help us greatly.
Message 5 of 15
gccdaemon
Command: -AECOBJEXPLODE
Explode AEC objects to primitive graphics? [Yes/No] <Yes>: Y
Explode to anonymous blocks? [Yes/No] <Yes>: A
Invalid option keyword.
; error: Function cancelled
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 6 of 15
CodeDing
@gccdaemon ,
I have no problems running the code I provided. It appears to be working correctly.
How are you testing the code? Are you pasting it EXACTLY as-is into the command line (that would be incorrect)? Or are you running it inside of a function perhaps?
The snippet of command history that you provided tells me that ONLY the 'else' portion of the If statement is being ran.. It does not show the first line of my code being executed. If that's the case, then I am inclined to believe that one of 2 things happened:
- The code was ran incorrectly.
- The code was altered before being ran.
I do not say these things to try to pick on you, but merely to be very precise since we cannot get such an easy piece of code to execute. Can you share with me your EXACT process of running the code I provided?
Best,
~DD
Message 7 of 15
gccdaemon
After testing the code, yes I looked it up and started playing with it to see if I could get it to hold the anything other than a "False" flag.
Here is the full command line:
Command: (command "-AECOBJEXPLODE" "Y") Loading AEC Object Explode...
nil
Explode to anonymous blocks? [Yes/No] <Yes>: (command)
nil
Command: (if (wcmatch (strcase (getvar 'LASTPROMPT)) "*EXPLODE TO ANONYMOUS BLOCKS*")
(_> (command "-AECOBJEXPLODE" "Y" "Y" "Y" "Y" "N" "Y")
(_> (command "-AECOBJEXPLODE" "Y" "A" "N" "Y" "Y" "Y" "N" "Y")
(_> )
Explode to anonymous blocks? [Yes/No] <Yes>: *Cancel*
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 8 of 15
CodeDing
It does not appear you are calling these from within a function. You are pasting them into the command line correct?
If you are testing them that way, then I would wrap them inside a (progn ... )..
BUT, try placing my code into a function first. Here, try this TEST command:
(defun c:TEST ( / )
);if
(prompt "\nTEST Complete.")
(princ)
);defun
Let me know if that works.
Best,
~DD
Message 9 of 15
gccdaemon
I went further than that. Sorry I misunderstood your question. Yes I've tested it in a routine. Also I've tested it with:
- cmdecho on and off
- removed the "(Command)" line
- assigned "(strcase (getvar 'LASTPROMPT))" to a node and moved it all around, etc.
All with the same result.
(DEFUN C:DWGEXPORT (/ QAF CMDE LP)
	(vl-load-com)
;	(setq	CMDE (getvar "CMDECHO")
;		QAF (getvar 'QAFLAGS))
;	(setvar "cmdecho" 0)
	(Command	"_MODEL"
			"-VPORTS" "SI"
			"-XREF" "D" "*"
			"_UCS" "W"
			"_PLAN" "C"
			"_SNAPANG" "0")
;	(setvar "cmdecho" 1)
	(Command "-AECOBJEXPLODE" "Y")
	(Command)
		(Command "-AECOBJEXPLODE" "Y" "Y" "Y" "Y" "N" "Y")
		(Command "-AECOBJEXPLODE" "Y" "A" "N" "Y" "Y" "Y" "N" "Y"))
;	(IF	(setq ss (ssget "_X" '((0 . "INSERT") (2 . "`*U*"))))
;		(PROGN	(setvar 'QAFLAGS 5)
;			(Command "_.explode" ss "")
;			(setvar 'QAFLAGS QAF)))
	(Command "_AecExportToAutoCAD2010")
;	(setvar "cmdecho" CMDE)
	(Command "_CLOSE" "Y")
	(princ)
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 10 of 15
CodeDing
@gccdaemon ,
Ok thanks for clarifying!
Hmmm.. This worked for me, does it work for you? (I have used alert yes / no to notify us)
If not, can you post an example dwg please. Probably should have started with that.
	(vl-load-com)
;	(Command	"_MODEL"
;			"-VPORTS" "SI"
;			"-XREF" "D" "*"
;			"_UCS" "W"
;			"_PLAN" "C"
;			"_SNAPANG" "0")
	(Command)
		(alert "yes");(Command "-AECOBJEXPLODE" "Y" "Y" "Y" "Y" "N" "Y")
		(alert "no"));(Command "-AECOBJEXPLODE" "Y" "A" "N" "Y" "Y" "Y" "N" "Y"))
;	(Command "_AecExportToAutoCAD2010")
;	(Command "_CLOSE" "Y")
	(princ)
Message 11 of 15
gccdaemon
Tested and both show "no". I can't upload the drawings because it's a high profile project, but I am using a storm file with pipes, surfaces and a profile and it doesn't trigger the "Views to explode [Current/All]:" option.
The other file has a road corridor, surfaces profile, and section views and DOES trigger the "Views" option.
I think that the trigger might be section views or even sample lines.
Is there a way to test for section views in a drawing?
Edit: it's not section views, could be corridor.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 12 of 15
CodeDing
My mind hurts trying to narrow this down lol. Thank you for telling me what's in the drawings though. I'll try to put some of those in and see what I come up with.
Message 13 of 15
Sea-Haven
Try this in your dwg (setq blk (tblnext "View" 1)) ; Gets the first view entry.
It returns nil for no views.
Message 14 of 15
CodeDing
@gccdaemon ,
I created a dwg with each one of these items (minus the intersection) and could not find a way to get the command to prompt a second question with "A" as an option. I'm not sure how to duplicate the prompt or your workflow.
@Sea-Haven ,
Searching the "VIEW" table was a good option, but does not trigger this prompt.
Message 15 of 15
gccdaemon
OK, so I don't know anything about VL, but I was thinking, would you be able to use vl-catch-all-error-p to catch an error for one of the strings? or is it too limited to catch a command based string?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
