Adjust the code
Adjust the code
adaptacad
Message 1 of 8
Adjust the code
adaptacad
How to adjust the code to work on multiple polylines:
(defun ERR (s)
  (if (/= s "Function cancelled\n")
    (if	(= s "quit / exit abort")
      (princ)
      (alert (strcat "    >> No Polyline Selected << \n"))
  (setq *error* olderr)
  (princ)
(defun c:vert ()
  (setq	olderr	*error*
	*error*	err
  (setq pl (entget (car (entsel "Select polyline :"))))
  ;;To get the vertax numbers :
  (if (setq vert (cdr (assoc 90 pl)))
    (progn
      (princ "\nNumbers of Vertices : ")
      (princ vert)
    (princ "\nThis is not a Polyline")
  (princ)
(princ "\nType VERT to run lisp")
Replies (7)
Message 2 of 8
Kent1Cooper
Not difficult [and it can be rather simpler than that], but:
How would you want them reported?  Do you want to pick them one at a time, but as many as you want in one running of the command?  Or if you want to select a bunch at once, do you want just a series of reports at the Command line that all say "Number of Vertices: XX" separately for each, with no differentiation?  Or does each number need to be related to its Polyline somehow [such as listing entity names along with numbers, or a number in Text at each one, or something]?  Or ... ?
Kent Cooper, AIA
Message 3 of 8
adaptacad
@Kent1Cooper
Simply select multiple polylines and 3d polylines and this will return the "Number of Vertices: XX" of all.
Message 4 of 8
doaiena
Test this code and tell me, if it's what you are looking for, or it's something else that you want.
(defun c:test ( / ss ctr obj verts)
(if (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE"))))
(progn
(setq ctr 0
verts 0
(repeat (sslength ss)
(setq obj (vlax-ename->vla-object (ssname ss ctr)))
(if (equal (vla-get-objectName obj) "AcDbPolyline")
(setq verts (+ verts (/ (length (vlax-safearray->list (variant-value (vla-get-coordinates obj)))) 2)))
(setq verts (+ verts (/ (length (vlax-safearray->list (variant-value (vla-get-coordinates obj)))) 3)))
);if 2dpoly
(setq ctr (1+ ctr))
);repeat
(princ (strcat "The number of vertices for all objects is: " (rtos verts 2 0)))
));if ss
(princ)
);defun
 PS: Sorry i made a mistake in the code. Make sure you copy this code. I  have edited my post because i had forgotten to increment the counter. It's fixed now.
Message 5 of 8
adaptacad
@doaienaalmost
works great if you select only one object.
but I would like the result to be the sum of all.
Message 6 of 8
doaiena
Try the code from my previous post now. I had a mistake, but it's fixed now and should work as intended.
Message 7 of 8
Kent1Cooper
One  grand total, then....  Here's a slightly shorter way, using an approach that doesn't need to distinguish between "lightweight" and "heavy" Polylines:
(vl-load-com); if needed
(defun C:PLVQ (/ ss v n pl); = PolyLine Vertices Quantity (if (setq ss (ssget '((0 . "*POLYLINE")))) (progn ; then (setq v 0) (repeat (setq n (sslength ss)) (setq verts (+ v (fix (vlax-curve-getEndParam (setq pl (ssname ss (setq n (1- n)))))) (if (vlax-curve-isClosed pl) 0 1) ); + ); setq ); repeat (prompt (strcat "\nTotal vertices in all Polylines = " (itoa verts) ".")) ); progn ); if (princ) ); defun
Kent Cooper, AIA
Message 8 of 8
adaptacad
@doaiena@Kent1CooperExactly!!
thank you so much!!
