Adding Units and Tagged Rows to the Table
k005
Advisor Advisor
Message 1 of 9
k005
Hello friends.
I have a painting. (before) length and area units are missing from this table. Also the field and length line/label is missing.
How can we add these?
* desired (after)
Thanks in advance to the helpful friend.
Replies (8)
Message 2 of 9
Sea-Haven
The best solution for this is to create the table correctly not edit it, so provide a true sample dwg and code matching your desired table result can be provided. Need what are Bolge_1 objects ?
Message 3 of 9
k005
No, I just want to add Unit labels and rows. So, as it appears in the after part...
* Table row heights may be the same... or the new row to be added may be slightly higher than the others...
Message 4 of 9
komondormrex
hey you there,
check the code below
(defun c:correct_table (/ table_object rows_number columns_number add_columns add_units color row column)
	(setq table_object (vlax-ename->vla-object (car (entsel "\nPick a table to correct: ")))
		  rows_number (vla-get-rows table_object)
		  columns_number (vla-get-rows table_object)
		  add_columns '("KISIM" "ALAN" "UZUNLUK")
		  add_units '("" "m\\U+00B2" "m")
		  color (vla-getcellgridcolor table_object 0 1 actopmask)
		  row 1
		  column -1
	(vla-put-regeneratetablesuppressed table_object :vlax-true)
	(vla-insertrows table_object 1 19 1)
	(vla-setcolumnwidth table_object 2 45)
	(repeat 3
		(vla-setcellgridcolor table_object row (setq column (1+ column)) actopmask color)
		(vla-setcellgridcolor table_object row column acleftmask color)
		(vla-setcellgridcolor table_object row column acbottommask color)
		(vla-setcellgridcolor table_object row column acrightmask color)
		(vla-setcellvalue table_object row column (nth column add_columns))
		(vla-setcelltextheight table_object row column 6)
		(vla-setcontentcolor2 table_object row column 0 (vla-getcontentcolor2 table_object 0 0 0))
		(vla-setcellalignment table_object row column acmiddlecenter)
	(repeat (1- rows_number)
		(setq column 0)
		(setq row (1+ row))
		(repeat 2
			(vla-setcellvalue table_object row (setq column (1+ column))
							 (strcat (vlax-variant-value (vla-getcellvalue table_object row column)) " " (nth column add_units))
	(vla-put-regeneratetablesuppressed table_object :vlax-false)
	(princ)
Message 5 of 9
k005
Thank you very much. Ok. Thank you.
* Can we also have a small division operation done? If it's not too difficult...
In the Total section divide Total area 10000 by Total length 100.
* Or we can collect directly from the Table. In order for the fraction to be the same...
I am adding a sample dwg.
Message 6 of 9
Sea-Haven
Again why fix table provide a dwg that has Bolge objects and make a table correct 1st go. Including /1000 & /100
Message 7 of 9
k005
The first time it was actually supposed to be 1000 and 100 episodes. I missed this point... sorry...
Message 8 of 9
komondormrex
sure,
		  row 1
		  column -1
	(repeat 3
		(setq column 0)
		(setq row (1+ row))
		(repeat 2
	(if (= "TOTAL:" (vlax-variant-value (vla-getcellvalue table_object row 0)))
		(progn
			(vla-setcellvalue table_object row 1 (strcat (rtos (* (atof (vlax-variant-value (vla-getcellvalue table_object row 1))) 1e-4) 2 2) " m\\U+00B2"))
			(vla-setcellvalue table_object row 2 (strcat (rtos (* (atof (vlax-variant-value (vla-getcellvalue table_object row 2))) 1e-2) 2 2) " m"))
	(princ)
Message 9 of 9
k005
It's just perfect !. Thank you very much. 🤗
