Adding attribute value column into block data export csv through lisp
abdul.raufJJ89F
Message 1 of 23
abdul.raufJJ89F
Hi all,
I have a lisp that export block data (block name, Rotation, Layer and co-ordinates) to CSV into the same location as of dwg. It has two options -either for all blocks or layer-wise.
So I need to add one more column for an attribute value in the CSV. The blocks will always have a single attribute tag (although block name and tag name will vary from case to case).
Please find the attached sample Image (additional column required highlighted by yellow) showing the desired result required with sample dwg.
Also, please find the attached lisp file.
Replies (22)
Message 2 of 23
dlanorh
If you post a drawing saved as AutoCAD 2010 or earlier, I can update my lisp.
I am not one of the robots you're looking for
Message 3 of 23
abdul.raufJJ89F
@dlanorh  Please find the attached dwg in the 2010 version.
Message 4 of 23
dlanorh
One question, does this require sorting on the contents (textstring) of the attribute? I will be busy for the next couple of hours but after that it shouldn't take more than an hour.
Message 5 of 23
abdul.raufJJ89F
Yes I want them sorted in order from lowest to highest value
Message 6 of 23
dlanorh
Attached is adapted lisp. Please check that this is to requirements, and if not let me know what need altering.
The current sort is by attribute string, block then layer.
Message 7 of 23
abdul.raufJJ89F
@dlanorh
Thanks but it seems there is an issue with sorting. Here I am attaching the sample drawing in 2010 format and snap of output CSV. It sorts as T-1, T-10,T-11 rather than as T-1, T-2, T-3 etc.
Please have a look
Message 8 of 23
dlanorh
It's not an issue, I am sorting the text as text, not number and this usually happens when you do that. That was my oversight.
I think I have something somewhere, or can find something on the forums to sort this out.
Message 9 of 23
abdul.raufJJ89F
@dlanorh
I would like to mention that attribute value will be of either a prefix (letter) - number or simply number for all the cases.
Message 10 of 23
dlanorh
OK. Attached is the revised lisp. This should sort properly. I have tested it in your supplied drawing by copying and adjusting the attribute text.
Message 11 of 23
dlanorh
@abdul.raufJJ89F wrote:
@dlanorh
Is this a mix and match? If so does the prefix need to be taken into account in the sort?
Message 12 of 23
Sea-Haven
The simplest way to fix the sort problem is t-1,t-10,t-11 etc use t-01,t-02 etc
I am pretty sure like you that this sort problem has been solved tried to find for something else I think it was one of Lee-mac's brilliant Lambda's. looks at ascii codes for numbers.
Message 13 of 23
abdul.raufJJ89F
@dlanorh
There will be no mix cases. It will be either of two types-
       a. The attribute will be of the format prefix (letter)-number
            Eg- T-1, T-2,T-3,...........
                   AB-10, AB-20,AB-30,.............
       b.The attribute will be simply a number or with a numeric prefix
          Eg- 1,2,3,.........
                  501,502,503,..............
                   4-1, 4-2,4-3,................
Message 14 of 23
dlanorh
Try the attached.
Message 15 of 23
abdul.raufJJ89F
@dlanorh  Much thanks..It is working fine!
Message 16 of 23
dlanorh
Excellent.😁
Message 17 of 23
abdul.raufJJ89F
@dlanorh
I hope you are doing well!
I need your additional help with this case where the block will have two attributes. I want only the second attribute value in the excel as a column (and not the first one) in this case.
Note that the second attribute has the property set as "Invisible" and here I don't require attribute data to be sorted in any specific order.
I am attaching the sample dwg (2010 version), your original blkdata lisp and the desired result image.
Message 18 of 23
dlanorh
Attached is modified lisp. I have renamed it CP_ID and this is also the command to run it. Also attached is produced csv file. This has also been renamed to *- CP_ID Block Data". If you want something else you can change it in the lisp.
Message 19 of 23
abdul.raufJJ89F
@dlanorh
You are amazing. Thanks for your help.
I would like to mention that the tag name will not be constant (CP_ID) for various cases but it will be always invisible for all cases.
Just for depicting my case to you, I have randomly put "CP_ID" in the CSV column heading which I can change along with output CSV filename later on. in the lisp, as you mentioned above.
I just want to ensure that your lisp runs for any tag name.
In addition to the above-
Just one more thing I would like to ask, in future I may need to get both attributes values in the excel column.- Sequence (same as per the above sorting logic done by you) and CP_ID.I am attaching an Image depicting the format of the desired output.
You can use the above dwg attached for this one.
Thanks for the consideration!!
Message 20 of 23
dlanorh
Will try to sort it out later this afternoon.
