Adding a command at AutoCAD Startup
awadsworth8Q4WM
awadsworth8Q4WM
I want to add a simple command at AutoCAD 2021 startup.  The command is (setvar "osnapz" 1).  Everything I read says to add the command to acaddoc.lsp but I cannot find this file in AutoCAD 2021.
Any Ideas,
Allen
dlanorh
If you can't find it you can create it. Open notepad type in (setvar "osnapz" 1) then save as acaddoc.lsp, ensuring the file is in a directory in the autocad support path.
I am not one of the robots you're looking for
O_Eckmann
In my french version it is stored here : C:\Program Files\Autodesk\AutoCAD 2021\Support\fr-fr
and it's name is ACAD2021DOC.LSP
Olivier
Olivier Eckmann
cadffm
This is another file (check the filename) and not for personal use.
Acad.lsp for program start and acaddoc.lsp for (every) document start are not part of the install package, the user can create these files.
Inside a supportpath, acad will load them.
For OSNAPZ is acad.lsp the right place,
but also acaddoc.lsp works.
Sebastian
Sea-Haven
You can load your custom lisp on startup also using Appload and save in Start up Suite. We used this method for years rather than acad.lsp or acaddoc.lsp. The custom lisp can have lots of stuff in it.
