Add support file search path through AcadDoc.lsp
Prashanthr
Prashanthr
Hello Everyone,
I am looking to add the support file search path through acaddoc.lsp. I am thinking of using the Leemac's function to do this. Apologies, as I am new to lisp programming.
;; Add Support File Search Paths  -  Lee Mac
;; Adds a list of Support File Search Paths, excluding duplicates and invalid paths.
;; lst - [lst] list of paths to add, e.g. '("C:\\Folder1" "C:\\Folder2" ... )
;; Returns: [str] "ACAD" Environment String following modification
(defun LM:sfsp+ ( lst )
    (   (lambda ( str lst )
            (if (setq lst
                    (vl-remove-if
                       '(lambda ( x )
                            (or (vl-string-search (strcase x) (strcase str))
                                (not (findfile x))
                        lst
                (setenv "ACAD" (strcat str ";" (apply 'strcat (mapcar '(lambda ( x ) (strcat x ";")) lst))))
        (vl-string-right-trim ";" (getenv "ACAD"))
        (mapcar '(lambda ( x ) (vl-string-right-trim "\\" (vl-string-translate "/" "\\" x))) lst)
How can I add the userprofile and combine it with the file location? The below code is not working.
(LM:sfsp+ '("(strcat (getenv "userprofile") "\\xxx\\xxxx\\xxxx")))
Also, when I add the below code in the acaddoc.lsp it shows the command in the command history when a new drawing is opened. How can I avoid this?
(Command "FILETAB")
You help is highly appreciated and thanks in advance.
ВeekeeCZ
It needs to be evaluated
(LM:sfsp+ (list (strcat (getenv "userprofile") "\\xxx\\xxxx\\xxxx")))
(setvar 'cmdecho 0)
(command "_.filetab")
(setvar 'cmdecho 1)
Prashanthr
Hello @ВeekeeCZ
Sweet! Thank you so much. That works. Anyway to make the added path to move to the top of the list in the search path?
ВeekeeCZ
Probably just swap str with that (apply ...) expression.
and remove ";"
Prashanthr
Sorry, can you please tell me how to do that?
Do I need to replace the ";" with the link?
(LM:sfsp+ (list (strcat str "(getenv "userprofile")" (apply 'strcat (mapcar '(lambda ( x ) (strcat x "\\xxx\\xxx")) lst)))))
