Add pause to the lisp
Prashanthr
Message 1 of 18
Prashanthr
Hello Everyone,
I am still learning lisp and thought of creating a lisp to attach pdf to the drawing as using the command "PDFATTACH" takes time to load a pdf with more than 100 pages and scrolling down the list to select the pages is time consuming.
(defun c:PFF()
(command "-PDFATTACH" "C:\XXX\XXX" "\\" "\\" "954" "0")
(princ)
When I run this lisp it says "C:XXX‚XXX not found. Can anyone help me out?
I want the lisp to pause for user input for "page number" and "scale". I even tried adding PAUSE instead of "\\", but still it didn't work.
Thanks in advance.
Replies (17)
Message 2 of 18
ВeekeeCZ
Post real file name.
Message 3 of 18
Kent1Cooper
Try it with either double back-slashes or single forward-slashes as separators in the file path.
Kent Cooper, AIA
Message 4 of 18
pbejse
Here you go.
Message 5 of 18
Prashanthr
Hi @ВeekeeCZ
Here is the file name: 11_STATE___GD11___PERMIT_FOR_ISSUE_DRAWING.pdf
Message 6 of 18
Prashanthr
Hi @Kent1Cooper
I tried to double backslash and forward slash as well, but doing so is making autocad go crazy. I am able see loading icon constantly rotating and pressing ESC does not  me Exit out of this command. I had to force close AutoCAD.
Message 7 of 18
Prashanthr
@pbejse  oh man!! This is working so awesome 😂😂🤣
Message 8 of 18
Sea-Haven
maybe this
(command "-PDFATTACH" "d:/acadtemp/vba-tutorial.pdf" (getint "\nEnter page number ") (getstring "\nenter insertion point x,y  ") 954 0)
Message 9 of 18
Prashanthr
Hi @Sea-Haven
I tried this, but its not working, I get the prompt to enter the "page number" but the command history shows the pdf is not found.
Message 10 of 18
ВeekeeCZ
Ok, I did it in a more complex way because... if I did it the simplest way I know it was crushing my acad.
(defun c:PFF ( / g p s)
  (if (and (setq g (cond ((getint "\nPage <1>: ")) (1)))
	   (setq p (getpoint "\nPoint: "))
	   (setq s (cond ((getreal "\nScale <1>: ")) (1)))
    (command "-PDFATTACH" "c:\\Users\\USer\\Dropbox\\nome_xco_me_startlist.pdf" g "_non" p s 0))
  (princ)
Message 11 of 18
Prashanthr
Hi @ВeekeeCZ
Thank you. This lisp also is not working. Not sure why its working. I assumed creating a lisp for this task to be very easy to deal with but its not 😅
Here is the screenshot of the command history.
Message 12 of 18
ВeekeeCZ
The screenshot shows that it does not find the file. So the part marked with red lines by you is the one, where the issue is.
Message 13 of 18
hmsilva
@Prashanthr try this slightly modified code from @ВeekeeCZ
(defun c:PFF ( / f g p s)
	   (setq f (getfiled "Select a PDF File" "" "pdf" 0))
    (progn
      (command "-PDFATTACH" f g "_non" p s 0)
      (print f)
  (princ)
will ask you to select the pdf file.
ex:
Command: PFF
Page <1>:
Point:
Scale <1>: -PDFATTACH Path to PDF file to attach: C:\Users\Test\Documents\water-controls.pdf Enter page number or [?] <1>: 1
Specify insertion point: _non
Base image size: Width: 8.2677, Height: 11.6929, Undefined
Specify scale factor or [Unit] <1.0000>: 1
Specify rotation <90.0000>: 0
Command:
"C:\\Users\\Test\\Documents\\water-controls.pdf"  <- copy and paste this line into the original code, it's the correct path...
Command:
Hope this helps,
Henrique
Message 14 of 18
Prashanthr
Hi @ВeekeeCZ
I tried a different pdf file in different location and the lisp works perfect 😊 Thank you 🤗
Message 15 of 18
Prashanthr
Hi @hmsilva
This lisp works great! But one problem is that every time I need to browse the location of the folder and it doesn't remember the earlier used locations 😅 This can be overcome by adding the location in the lisp, but it would be more awesome if it would remember the location last used 😄
Message 16 of 18
pendean
Community Legend
Community Legend
Message 17 of 18
hmsilva
@Prashanthr wrote:
Hi @hmsilva
@Prashanthr
getfiled function don't remember last file location, but we can hardcode a path...
the code line
 don't have a location to start the file selection, but changing the "" to a valid path, it will start there the
ex:
(setq f (getfiled "Select a PDF File" "H:\\Test\\" "pdf" 0))
will start the selection in "H:\\Test\\" folder...
Hope this helps,
Henrique
Message 18 of 18
ВeekeeCZ
Just out of today's misery here's a bit enhanced update.
(defun c:PFF ( / f p)
(vl-load-com)
  (or *pff-h* (setq *pff-h* "c:\\Users\\user\\Dropbox")) ; defaults
  (or *pff-g* (setq *pff-g* 1))
  (or *pff-s* (setq *pff-s* 1))
  (if (and (setq f (getfiled "Select a PDF File" (strcat *pff-path* "\\") "pdf" 0))
	   (setq *pff-g* (cond ((getint (strcat "\nPage <" (itoa *pff-g*) ">: "))) (*pff-g*)))
	   (setq *pff-s* (cond ((getint (strcat "\nScale <" (itoa *pff-s*) ">: "))) (*pff-s*)))
	   (setq *pff-h* (vl-filename-directory f))
    (progn
      (command "-PDFATTACH" f *pff-g* "_non" p *pff-s* 0)
      (print f)
  (princ)
