ADD MLEADERLINE Y+200 FROM (VLAX-INVOKE Oml 'GetLeaderLineVertices 0)
diegolopezsilanes
diegolopezsilanes
Hello, Im triyng to add 1 MLEADERLINE  to a set  of mleaders
i'm tring this way
(vl-load-com)
(defun c:t3 () (c:ADD_MLeaderLine3))
(defun c:ADD_MLeaderLine3()
    (setq acadObj (vlax-get-acad-object))
    (setq doc (vla-get-ActiveDocument acadObj))
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(1 1 0
                                  4 4 0
    (setq i 0)
    (setq modelSpace (vla-get-ModelSpace doc))
	  (if (setq i -1
	    s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (sslength s)
      (setq e (ssname s (setq i (1+ i))))
	  (setq oml (vlax-Ename->Vla-Object e))
	  (setq vrt (VLAX-INVOKE Oml 'GetLeaderLineVertices 0)) ;---------------
	  ; (setq vrt2 (list (nth 0 vrt)(nth 1 vrt)(nth 2 vrt)))
	  ; (princ vrt)
	  ; (princ vrt2)
	  ; (setq vrt2 (v+ vrt2 '(0 200 0)))
	  ; (princ vrt2)
	      (setq points2 (vlax-make-safearray vlax-vbDouble '(0 . 2)))
			  (setq points2 (vlax-make-array-type
			  (list (cons 0 (nth 0 vrt)) (cons 1 (+ 200 (nth 1 vrt)))
			  (cons 2 (nth 2 vrt))
			  vlax-vbDouble))
    (setq r (vla-AddLeader oML))
    (vla-AddLeaderLine oML r points2)
(defun v+ (v1 v2)(mapcar '+ v1 v2))
; https://www.theswamp.org/index.php?topic=7063.0
(defun vlax-make-array-type  (lst atype)
      atype
      (cons 0 (1- (length lst))))
    lst))
; example
; $ (vlax-make-array-type
      ; (list 1001 1000 1002 1070 1000 1070 1070 1002)
      ; vlax-vbinteger)
; #<safearray...>
 and I get an error about
Comando: T3
Designe objetos: Designe esquina opuesta: 1 encontrados
Designe objetos: ; error: Fallo en vlax-safearray-fill. Lista de inicialización no válida. #<safearray...> ((0 . 29.456) (1 . 1613.46) (2 . 0.0))
Comando:
these are the sentences where im having problems:
vlax-vbDouble))
-and these one:
i dont manage so well with safearrays so any help will be great
thanks
ronjonp
Give this a try .. it will add 200 to the first x value. If you use vlax-invoke, there is no need to supply safe-arrays.
(vl-load-com)
(defun c:t3 nil (c:add_mleaderline3))
(defun c:add_mleaderline3 (/ i o oml s vrt)
  (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength s))
      (setq oml (vlax-ename->vla-object (ssname s (setq i (1- i)))))
      (setq vrt (vlax-invoke oml 'getleaderlinevertices 0))
      (vlax-invoke oml 'addleaderline 0 (mapcar '+ vrt '(200 0 0 0 0 0 0)))
  (princ)
