I have several dynamic key note blocks in different shapes (circle, hexagon, rectangle, etc.) that I combined into a single main dynamic block. You select which shape, then explode the block to use. I added an attribute on our No-print layer in the main block to give instructions on how to use the block. The "problem" is that when you explode the main block, you have to delete this attribute. Is there a way to add notes without using an attribute? Or is there a way for the attribute to be deleted when the block is exploded?
Thanks for any help.
Jared - Sr. CAD Technician
Words to live by: If it ain't broke, you're not trying hard enough.
