Add element to list of lists
Browning_Zed
Message 1 of 16
Browning_Zed
Dear sirs, help me solve the following problem.
I need a function that would add an item to a list with nested lists.
The original list might look like this:
'((1 3 5) (1 3 5) (1 3 5))
after that I need to insert at position: (nth 1) element "2", and at position: (nth 2) element 4. Then the transformed list will look like this:
'((1 "2" 3 4 5) (1 "2" 3 4 5) (1 "2" 3 4 5))
The very execution of the function in this case may look like this:
(somefunction '((1 "2") (2 4)))
The first item is a position on the list, starting from zero.
The second item is the value of the added element.
Theoretically, there can be an unlimited number of added elements, but there should be no more than the length of the original list.
Thanks in advance.
Accepted solutions (3)
Replies (15)
Message 2 of 16
marko_ribar
(defun foo ( addlist reflist / n v r k )
  (setq n (mapcar 'car addlist))
  (setq v (mapcar 'cadr addlist))
  (setq r (mapcar '(lambda ( a ) (setq k -1) (apply 'append (mapcar '(lambda ( b ) (setq k (1+ k)) (if (vl-position k n) (list (nth (vl-position k n) v) b) (list b))) a))) reflist))
  r
;;; (foo '((1 "2") (2 4)) '((1 3 5) (1 3 5) (1 3 5))) => ((1 "2" 3 4 5) (1 "2" 3 4 5) (1 "2" 3 4 5))
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 16
Browning_Zed
Thanks for your help.
Message 4 of 16
Browning_Zed
Again I ask you for help. Is it possible to modify the function to be able to add a nil value?
For example:
;;; (foo '((1 nil))' ((1 3 5) (1 3 5) (1 3 5))) => ((1 nil 3 5) (1 nil 3 5) (1 nil 3 5))
Message 5 of 16
pbejse
The target order is based on the orignal order YES?  to clarify, what would be value if you target the two
'((0 "2") (1 4))
'((0 "2") (3 4))
if the list'((1 3 5) (1 3 5) (1 3 5))
BTW: where did you come with al this conditions?
Message 6 of 16
Browning_Zed
Right. The target order is based on the orignal order.
'((0 "2") (1 4))
=>> '(("2" 1 4 3 5) ("2" 1 4 3 5) ("2" 1 4 3 5))
'((0 "2") (3 4))
=>> '(("2" 1 3 5) ("2" 1 3 5) ("2" 1 3 5))
'((0 "2") (3 3))
=>> '(("2" 1 3 5 3) ("2" 1 3 5 3) ("2" 1 3 5 3))
Well, I need to redirect lists to specific functions that expect a specific number of items. And in my case, the best way is to transform the list.😏
Message 7 of 16
pbejse
That does not answer my question @Browning_Zed.
I need you to confirm what is the correct value of the list if your input is '((0 "2") (1 4))
is it  (("2" 4 1 3 5) ("2" 4 1 3 5) ("2" 4 1 3 5))  at position 0 and 1 ?
Based on your edited post
Where is 4 in this result?
'((0 "2") (3 4))
Are you sure THAT is the correct value?
Message 8 of 16
Browning_Zed
Sorry, I was wrong. It should be like this:
'((0 "2") (3 4))
= >> '(("2" 1 3 5 4) ("2" 1 3 5 4) ("2" 1 3 5 4))
'((0 "2") (4 4))
= >> '(("2" 1 3 5) ("2" 1 3 5) ("2" 1 3 5))
Message 9 of 16
ВeekeeCZ
Try this generic one.
 ; order list rules: index starts from 1. Negative from add list, positive from sub-lst
(defun add2lst (add lst ord)
  (mapcar '(lambda (sub) (mapcar '(lambda (o) (nth (1- (abs o)) (if (minusp o) add sub))) ord)) lst))
(add2lst
  '("2" 4)
  '(1 -1 2 -2 3)
Message 10 of 16
pbejse
'((0 "2") (3 4))
Are you sure this time?
The post you mark as "Solution" shows another result otherwise
(FOO '((0 "2") (3 4)) '((1 3 5) (1 3 5) (1 3 5)))
'((0 "2") (4 4))
Again, Are you sure about that?
Message 11 of 16
Browning_Zed
(( "0 position" 1 "1 position" 3 "2 position"  5 "3 position"))
Message 12 of 16
pbejse
((1 3 5))
The reason why i'm asking is the results i'm getting from following the original logic is inconsistent from your answer.
I just need you to be sure.
There's nothing more frustating to realize at the end the result is not what it's supposed to be.
Happy coding
Message 13 of 16
Browning_Zed
Is it possible to modify your function by adding the remove item as well?
Message 14 of 16
ВeekeeCZ
Why, the current one is good enough.
(add2lst
nil
'((1 2 3 4) (1 2 3 4) (1 2 3 4))
'(1 4)
Message 15 of 16
pbejse
'((0 "2") (1 4))
'((0 "2") (3 4))
=>> '(("2" 1 3 5 4) ("2" 1 3 5 4) ("2" 1 3 5 4))
'((0 "2") (3 3))
Following the same logic
(defun _InsertnAt ( al lst / ord )
(setq ord al)
	(mapcar '(lambda (v / nl)
		(repeat (setq n (length v))
		  	(if (setq f (assoc (setq n (1- n)) al))
			  	(setq nl (cons (nth n v) nl)
				      nl (cons (cadr f) nl) al (vl-remove f al))
			  	(setq nl (cons (nth n v) nl))
		   (cond
		     ((null al) (setq al ord)  nl)
		     ((setq nl (append nl (mapcar 'cadr al)) al ord) nl))
		lst)
(setq lst '((1 3 5) (1 3 5 6 7 8 9) ("A" "B")))
(_InsertnAt '((1 "2") (2 4)) lst) =>> ((1 "2" 3 4 5) (1 "2" 3 4 5 6 7 8 9) ("A" "2" "B" 4)) (_InsertnAt '((0 "2") (1 4)) lst) =>> (("2" 1 4 3 5) ("2" 1 4 3 5 6 7 8 9) ("2" "A" 4 "B")) (_InsertnAt '((0 "2") (3 4)) lst) =>> (("2" 1 3 5 4) ("2" 1 3 5 4 6 7 8 9) ("2" "A" "B" 4)) (_InsertnAt '((0 "2") (3 3)) lst) =>> (("2" 1 3 5 3) ("2" 1 3 5 3 6 7 8 9) ("2" "A" "B" 3)) (_InsertnAt '((0 "2") (3 3)(4 "Uppity)) lst) =>> (("2" 1 3 5 3 "Uppity) ("2" 1 3 5 3 6 "Uppity" 7 8 9) ("2" "A" "B" 3 "Uppity))
-------------------------------------------------------------------------------------------- (_InsertnAt '((0 "2") (3 "LSP")(4 "pBe")) '((1 3 5) (1 3 5 6 7 8 9) ("A" "B" "C" "D"))) =>> (("2" 1 3 5 "LSP" "pBe") ("2" 1 3 5 "LSP" 6 "pBe" 7 8 9) ("2" "A" "B" "C" "LSP" "D" "pBe"))
(1 3 5) <-- beyond number of items ("2" 1 3 5 "LSP" "pBe")
(1 3 5 6 7 8 9) <-- enough to cover additional items <-- ("2" 1 3 5 "LSP" 6 "pBe" 7 8 9)
("A" "B")<-- enough to cover additional items ("2" "A" "B" "C" "LSP" "D" "pBe"))
Message 16 of 16
pbejse
If you  want to exclude the items out of range of the target list
(defun _InsertnAtnil ( al lst )
				      nl (cons (cadr f) nl))
		lst)
(_InsertnAtnil '((0 "2") (3 "LSP")(4 "pBe")) '((1 3 5) (1 3 5 6 7 8 9) ("A" "B" "C" "D")))
(("2" 1 3 5) ("2" 1 3 5 "LSP" 6 "pBe" 7 8 9) ("2" "A" "B" "C" "LSP" "D"))
