Add attribute if not exist in a particular block and make it invisible
j.balasubramaniyam
Message 1 of 19
j.balasubramaniyam
Hi, I wanted to add an attribute PRICE in all my blocks in a drawing but also wanted to check if that attribute already exists so that it can skip that task for that particular block. I tried to modify this code found on cadtutor forum but not working. Also if someone can make that added attribute invisible it would be better help for me.
defun c:add$ ( / ss i blk blks def AttObj) (and (setq ss (ssget '((0 . "INSERT")))) (setq i (sslength ss)) (while (> i 0) (setq blk (cdr (assoc 2 (entget (ssname ss (setq i (1- i))))))) (if (not (vl-position blk blks))(setq blks (cons blk blks))) ) ) (foreach blk blks (setq def (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk)) (if (/= "" (attributeTag-p (car (entsel)) "SHIPLOOSE"))
(prince)
(setq AttObj (vla-addattribute def 8 acattributemodelockposition "Enter Item #" (vlax-3D-point 72 84) "PRICE\U+0020" "100" ) ) (vlax-put AttObj 'Alignment acAlignmentmiddle) ;; 4 (command "_.attsync" "_N" blk) ) (princ) ) (vl-load-com) (princ)
Replies (18)
Message 2 of 19
pbejse
@j.balasubramaniyam wrote:
    (foreach blk blks
(prince); <----
This prince ?
Message 3 of 19
j.balasubramaniyam
Apologies. that is typo error
Message 4 of 19
pbejse
I know, I'm just messing with you.  😊
(defun c:add$ ( / ss i blk blks def AttObj prince)
  (and
       (while (> i 0)
          (setq blk (GetPropertyValue  (ssname ss (setq i (1- i))) "BlockTableRecord/Name" ))
	 blks
       (foreach blk blks
	(and
	  (Vlax-for obj (setq def (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk))
		 (setq prince
			  (and
			    (eq (vla-get-ObjectName obj) "AcDbAttributeDefinition")
			    (eq (vla-get-tagstring obj) "PRICE ")
	     (null prince)
	      "100"
        (null (vlax-put AttObj 'Alignment acAlignmentmiddle))
(princ)
HTH
Message 5 of 19
j.balasubramaniyam
Yes I am prince only waiting for Princess. Regarding the LISP, it does not ask to select objects in the original version but the LISP you modified asking to select the Objects. Can you please look at it? Also please make that particular attribute invisible. I am having difficult time to find a solution.
Message 6 of 19
pbejse
.... Also please make that particular attribute invisible.
Wrong! your posts shows this as the original
You can however change it to
(setq ss (ssget  "X" '((0 . "INSERT"))))
And this
	      "100"
to this for "invisible"
(setq AttObj (vla-addattribute def  8  acAttributeModeInvisible
	      "100"
Message 7 of 19
j.balasubramaniyam
Hi, your code is working well interms of Making the attribute invisible. But still it add the attribute eventhough it exists already. could you please help me once again? thanks for the support you provided till now
Message 8 of 19
pbejse
If there's anything else after this you need to post a sample drawing
This
To
(wcmatch (vla-get-tagstring obj) "PRICE*")
Or better yet, go to where you copied the code at post #1 and request it there.
Message 9 of 19
j.balasubramaniyam
Hi, code looks perfect for me if null prince () called it has to skip the remaining steps and has to run null (vlax-put AttObj 'Alignment acAlignmentmiddle). But not happening I believe. Someminor changes to be done somewhere. I will post the dwg if possible as I am autocad only in my office laptop. Thank you so much for your support
Message 10 of 19
pbejse
Q: But why male models?
A: Are you serious? I just.. I just told you that a moment ago.
Message 11 of 19
j.balasubramaniyam
🤣🤣🤣...  Did you get a chance to look at this? You can try this code for a block in any of your drawing and help me out right? I am just trying every option in the code but nothing working
Message 12 of 19
pbejse
Asked and answered
Message 13 of 19
j.balasubramaniyam
Yes you are answered it is working fine except it still adding the attribute to every block even if it exists. I could not able to find a solution.
Message 14 of 19
j.balasubramaniyam
Message 15 of 19
pbejse
Message 16 of 19
j.balasubramaniyam
Hi pbejse,  Today i checked in my personal PC & the same code which was not working in my official PC works very well and adding only attribues if not exists. I am really wondering how it is possible. Attaching the dwg & code used for your reference.  Thank you so much for your help. If possible could you please brainstorm & tell why the issue happened in my official PC only?
I am accepting your solution anyway.
Thanks & Regards,
Bala
Message 17 of 19
pbejse
.... tell why the issue happened in my official PC only?
If you are wondering why it works on some but not all, its because of the  tag name:
- If the block already have a "PRICE" tag, and not as the result the program
  the TAG name will probably just "PRICE" and not equal to "PRICE " < take note of the space as the program creates
When you encounter this problem, please Check the existing TAG name.
For clarity:
"PRICE\U+0020" <-- IF you dont have a any reason for adding the extra space might as well use "PRICE" on the code
		      "Enter Item #" (vlax-3D-point 72 84) "PRICE"
		      "100"
Below is the code modified so not to confused you with statement can understand it better.
  (if
    	(and
	       (while (> i 0)
		 blks
       (foreach blk blks
	    ;;;	If this is not null that means "PRICE" tag already exist	    ;;
		 (setq prince
			(and
			    (eq (vla-get-tagstring obj) "PRICE")
	 (if (=  prince nil) ; <-- Confirms the current block has no attribute definitions named "PRICE"
	   (progn
		(setq AttObj (vla-addattribute def  8 acAttributeModeInvisible	;<-- Add attribute definition
		      "Enter Item #" (vlax-3D-point 72 84) "PRICE"		;<-- Enter Item # as prompt
		      "100"							;<-- "100" as default value
(princ)
HTH
Message 18 of 19
j.balasubramaniyam
You are absolutely correct. Though I found this issue before reading the thread, your explanation & knowledge on LISP is awesome. Thank you so much for the help
Message 19 of 19
john.uhden
@j.balasubramaniyam
You are quite fortunate that @pbejse took you under his wing.  He is one of the best around here, plus his sense of humor is thoroughly enjoyable, not to mention his patience. (I'm still laughing about Prince).
John F. Uhden
