Add Attribute blocks to every polyline corners
E.S.7.9
E.S.7.9
hi
I have 3 different lisp to use them for what I want to do , I tried to combine them as a one lisp  but I am not a good programmer and that is why it has been unsuccessfully attempt
So , if can any body help me , here is what process that I need in lisp routine ;
I attached image file , as you can see  what I need to do is inserting attribute block to every corner of my multiple corners polyline …
this can work for me but it would be much better if routine could boost +1 to corner numbers in "Corner.No" tags and put the distance between 2 points length value to "Distance Value" tag
thank you for your help
ВeekeeCZ
How about post the drawing and sample block? /next time/
Try this code... change the name of the block, you may add the file path as you like.
Spoiler
(vl-load-com)
(defun c:CornerLabel ( / *error* nVAR oVAR adoc :AddLeadingZeros ss en n m pt ds pt)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (mapcar 'setvar nVAR oVAR)
    (vla-endundomark adoc)
    (princ))
  (defun :AddLeadingZeros (a d / b) ;add zeros to 'd' many digits  ;a string
    (strcat (substr "000000000" 1 (if (>= d (setq b (strlen (itoa (fix (atof a)))))) (- d b) 0)) a))
  (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
  (setq oVAR (mapcar 'getvar (setq nVAR '(ATTREQ ATTDIA))))
  (mapcar 'setvar nVAR 			'(1	 0))
  (if (setq ss (ssget  "_+.:E:S" '((0 . "LWPOLYLINE"))))
    (repeat (setq i (sslength ss))
      (setq en (ssname ss (setq i (1- i)))
	    n -1
	    m (vlax-curve-getEndParam en))
      (while (<= (setq n (1+ n)) m)
	(setq pt (vlax-curve-getPointAtParam en n)
	      ds (vlax-curve-getDistAtParam en n))
	(vl-cmdf "_.INSERT" "CORNER" "_S" 1 "_R" 0  		; change NAME, may add the path. don't forget use /
		 "_none" pt
		 (strcat "CN-" (:AddLeadingZeros (itoa n) 2))
		 (strcat (rtos ds 2 0) " mm")
  (*error* "end")
E.S.7.9
bingo ... Thank you so much
pbejse
Try this
(defun c:demo ( / s e p l i bl)
(setq spc (vlax-get (vla-get-ActiveLayout
'Block))
(if (setq s (ssget "_:S" '((0 . "LWPOLYLINE"))))
(progn
(setq i 0 e (ssname s 0))
(setq p (vlax-curve-getEndParam e))
(repeat (setq p (1+ (fix p)))
(setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l)))
(setq dist (mapcar '(lambda (j)(vlax-curve-getDistAtPoint e j)) l))
(mapcar '(lambda (a b) (setq bl (vlax-invoke spc 'InsertBlock a "Corner.No" 1 1 1 0))
(mapcar '(lambda ( c d )
(vla-put-textstring c d))
(vlax-invoke bl 'GetAttributes)
(list (strcat "CN-" (if (< (setq i (1+ i)) 10) "0" "") (itoa i))
(strcat (rtos b 2 2) " mm"))
l (cons 0.0 (mapcar '(lambda ( n m ) (- n m)) (cdr dist) dist ))
(princ)
pbejse
BeekeeCZ
It appears that the code you posted shows not the distance between points but of distance at that point, not sure though but that is what i understand from the image from the OP
 Theres something weird happening with my browser, cant even see the code tags
what gives?
ВeekeeCZ
@pbejse wrote:
BeekeeCZ
Ohh, you're right. Simple to fix. Thanks for the heads up!
Spoiler
(vl-load-com)
    (princ))
	    n -1
	      ds (- (vlax-curve-getDistAtParam en n)
		    (vlax-curve-getDistAtParam en (max (1- n) 0))))
		 "_none" pt
  (*error* "end")
pbejse
Wish there was a way to modify previous post to fix the format or "update" a code tags [Wish List]
Anyways....  modified to remove decimal points, also  print Individual and Total distance on command prompt
(defun c:demo (/ r s e p l i bl dist)
		  'Block
    (progn
      (setq i 0  e (ssname s 0) )
      (setq dist (mapcar '(lambda (j) (vlax-curve-getDistAtPoint e j)) l)
		 (setq  bl (vlax-invoke spc 'InsertBlock a "kokoy" 1 1 1 0))
		 (setq r (cons (list (strcat "CN-"
				       (if (< (setq i (1+ i)) 10) "0" "" )
				       (itoa i)
			       (strcat (rtos b 2 0) " mm")
			 )	r	))
		 (mapcar '(lambda (c d)
			 (car r)
	      l
	      (cons 0.0 (mapcar '(lambda (n m) (- n m)) (cdr dist) dist))
      (princ (apply 'strcat
		      (Mapcar '(lambda (x)
				 (Strcat (car x) " | " (cadr x) "\n")
			      (reverse (cons  (list "Total" (strcat  (rtos (last dist) 2 0) " mm")) r))
  (princ)
Command: DEMO
Select objects:
CN-01 | 0 mm
CN-02 | 1500 mm
CN-03 | 7500 mm
CN-04 | 1000 mm
CN-25 | 1250 mm
Total | 25500 mm
HTH
