add a note to lots of drawing
islerahmet06
islerahmet06
Hi all
We have 1600 different drawings, we must add a same note to all of them
is there any easy way to do that? I dont want to do that one by one 😞
Thanks in advance
devitg
 A note: a text, a attribute. ??
Please clear , and upload a sample.dwg
It can be do.
pbejse
I think it will be easy
I'm sure there would be a lot of issues and conditions, Please explain a bit more islerahmet06.
islerahmet06
Hi
I added a sample dwg, there is before and after
I would like to add that tables to my drawings
there are around 1600 dwg like this one
but scale or paper size might different
the place we will put this tables might be different, because there will be no space to put at same place, I think this wont be that easy
Thanks in advance!
@islerahmet06  I have no idea how to render a .lsp into multiple files (I do not know if it's possible)
A suggestion, because you do not create a block with your table and with a .scr file.
here is an example that may be helpful.
devitg
Please , as you draw all at model space , give us the all normalized  sheet size you use,
I had seen a text down left the title that state
if such text  is always in the form "SIZE : AX+" ?
And  there is a polyline, the outermost,  at layer SUR-20  that represent  the sheet .
Are all dwg done in the same way.?
The fact is to try to get a standard or rule to do the LISP , and if possible to set the table at the best  place.
I guess that the table will be set at the  dwg bottom side.
Sea-Haven
Like Devitg you can get the limits of the dwg area and put the table just next to what is drawn.
How are you going to get the list of dwgs ? Are they all in one directory / or sub directories if so you can get a list pretty easy. www.lee-mac.com has a OBDX routine so can run without actually opening each dwg.
