add (0. "mtext") but doesn't work
nychoe1
nychoe1
I added it a verse ((-4 . "<or")(0 . "TEXT")(0 . "MTEXT")(-4 . "or>"))))
but mtext is not working
please let me know what I should do.... thank you all.
(defun c:wd ()
 (setq ss (ssget '((-4 . "<or")(0 . "TEXT")(0 . "MTEXT")(-4 . "or>"))))
 (setq n (sslength ss))
 (setq wid (getreal "\ninput width :"))
 (setq k 0)
 (repeat n
 (setq var (entget (ssname ss k)))
 (setq old (assoc 41 var))
 (setq new (cons 41 wid))
 (setq cht (subst new old var))
 (entmod cht)
 (setq k (1+ k))
(princ)
marko_ribar
ssget function is expecting not literal filter... Try replacing your filter with this :
(setq ss (ssget "_:L" '((0 . "*TEXT"))))
or if you really want only TEXT and MTEXT, then :
(setq ss (ssget "_:L" (list '(-4 . "<or") '(0 . "TEXT") '(0 . "MTEXT") '(-4 . "or>"))))
Note - I've put "_:L" mode to be sure selected entities are on unlocked layer and ready for editing/modifications...
Marko Ribar, d.i.a. (graduated engineer of architecture)
I usually just use:
(setq ss (ssget "_:L" '((0 . "MTEXT,TEXT"))))
Which selects only MTEXT & Text entities & is much the same as Marko's second option
There's a good tutorial on Selection Sets here & a full explination of ssget on Lee Macs website here
nychoe1
oh, thank you
but
when I selected texts and mtexts all together the same time, texts are  working but mtexts are not working.Smiley Happy
Hi nychoe1
Your problem lies in the assoc 41 group code, it is different in MTEXT - TEXT. See DXF Group Codes here
If you're trying to change the width factor of TEXT items at the same time as the Reference rectangle width of MTEXT items - two very different things.
What are you trying to achieve?
