Aceessing Attributes without open the drawing
Dear all,
 Is there any way to access the attribute text string in a drawing without open
the drawing? I have tried like this.
(setq dDbx (vla-getinterfaceobject (vlax-get-acad-object) "ObjectDBX.AxDbDocument.18"))
(setq cFile (getfiled "Select *.dwg file" "t:\\" "dwg" 4))
(vlax-invoke-method dDBX 'Open cFile)
(vla-get-textstring (vla-item (vla-item (vla-get-blocks dDBx) 5) 70))
But it returns the default value of attribute definition. Please help in this.
Thanks in advance
STM
_Tharwat
That is because you are getting the value from the Block table and not from the space where the block is located ( insereted ) .
Thanks _Tharwat. Now it is solved. STM
_Tharwat
You are most welcome anytime Smiley Happy
