Accessing then setting attributes in a block
squire3364
squire3364
HI all,
I've just started working with LISP within the last week or two so excuse my possibly simple question.
I am working on creating a tool that takes the Area of a hatch, converts it from mm2 to m2 then inserts it into a block's attribute with two clicks.
I've gotten as far as getting a value for the area and converting it to m2 however i can't for the life of me figure out how to access a blocks attributes to import the value into it.
I've attached both a my lisp function and a snip of the what i'm getting to. It seems like i need to get into the attributes section, but i'm unsure how
Any insight into what i might need to do?
Sea-Haven
Look into nentsel this allows you to pick an attribute directly in a block.
ВeekeeCZ
The simplest is to use (setpropertyvalue e "tag" "value") e is ename of block
pbejse
@squire3364 wrote:
HI all,
(defun C:hatcharea (/ ss atb nobj Tarea eo aream)
  (if (and
	(setq  ss (ssget '((0 . "hatch"))))
	(setq  atb (entsel "\nSELECT ROOM TAG"))
	(setq nobj (car (nentselp (cadr atb))))
	(eq "ATTRIB" (cdr (assoc 0 (setq A_ent (entget nobj)))))
    (progn
      (setq Tarea 0.0)
	(repeat (sslength ss)
	  (setq eo (ssname ss 0))
	  (setq area (vlax-get (vlax-ename->vla-object eo) 'Area))
	  (setq area (if (eq (rtos (* area 1e-006) 2 2) "0.00")
		   area
		   (* area 1e-006)
	  (setq Tarea (+ area  Tarea))
	  (ssdel  eo ss)
  (setq aream (rtos tarea 2 1))
  (setpropertyvalue (Car atb) (Cdr (assoc 2 A_ent)) aream)
  (print aream)
  (princ)
HTH
