Accessing lisp from tool palette repeats last command
brettS6K2S
brettS6K2S
I'm using C3D 2022 1.2, ACAD 2022 1.1, Map 3D 2022 0.1
I've recently noticed that when loading a custom lisp file from a custom tool palette, my last command is repeated.
It's requiring me to press the ESC key in order to bypass this.
Note that I have the typical ^C^C at the beginning of the command string, which should already take care of this.
For example:
There is a lisp routine that we have in a tool palette for converting mtext to MLeader
I've drawn a circle, then notice I have some mtext that would like to be a MLeader instead.
I should be able to select my lisp in the tool palette and proceed as normally prompted to select mtext.
Instead, when I first select the lisp in the tool palette, I get my last command instead...in this example, the circle command is initiated rather than the lisp.
When I manually press ESC key before initiating the lisp from the tool palette, everything works as it should. No repeat of last command.
john.uhden
@brettS6K2S
It's been years since I've messed with tool palettes and macros, but off the top of my empty head maybe try a few different things...
a)  Try dropping the two ^C^Cs
b)  Try adding a 3rd ^C
c)  Try adding the harmless REDRAW command before the call to your program.
OR
Might there be something in your code that is invoking the previous command?
Is there a semicolon right after the ^C^Cs?  Or a space?
John F. Uhden
brettS6K2S
Thank you John!
I missed that there was a space right after the ^C^C's. I removed the space and success.
Sometimes the littlest thing can cause a big disruption.
