AcadLWPolyline and AcDbPolyline
Delforge
Message 1 of 10
Delforge
I have a problem with AcadLWPolyline and AcDbPolyline.
I create a lightweight polyline in model space, then i want to work with this polyline.
It's work if i work dirrectly with this polyline but it doesn't work if i recovers this polyline.
This following code work but not if i change 'plineObj = oEntite in plineObj = oEntite
I have the impression that AcadLWPolyline and AcDbPolyline is not the same thing for autocad but it is the same polyline !
What to do ?
Thanks for your help.
Quentin
Sub Example_GetBulge()
    ' This example creates a lightweight polyline in model space.
    ' It then finds and changes the bulge for a given segment.
    Dim plineObj As AcadLWPolyline
    Dim points(0 To 11) As Double
    Dim i As Integer
    ' Define the 2D polyline points
    points(0) = 0: points(1) = 1
    points(2) = 1: points(3) = 2
    points(4) = 2: points(5) = 1
    points(6) = 3: points(7) = 2
    points(8) = 4: points(9) = 3
    points(10) = 2: points(11) = 6
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    ZoomAll
    ' Change the bulge of the third segment
    plineObj.SetBulge 3, 0.5
    plineObj.Update
For Each oEntite In ThisDrawing.ModelSpace 'on parcourt tous les éléments dans le dessin (hors xref)
    If oEntite.ObjectName = "AcDbPolyline" And oEntite.Layer = "0" Then
    'plineObj = oEntite
    longeur_poly = Round(UBound(plineObj.Coordinates) / 2, 0) - 1
    i = 0
    P1 = plineObj.Coordinate(0)
    While i < longeur_poly
        rayon = Sqr((CenterPt(plineObj, i)(0) - plineObj.Coordinate(i)(0)) ^ 2 + (CenterPt(plineObj, i)(1) - plineObj.Coordinate(i)(1)) ^ 2)
        MsgBox (rayon)
        i = i + 1
    Wend
Next
End Sub
Public Function CenterPt(PolyLin As AcadLWPolyline, Optional Vertex As Integer) As Variant
Dim PolyPts As Variant
Dim PolySp(0 To 2) As Double
Dim PolyEp(0 To 2) As Double
Dim Lin1 As AcadLine
Dim Ang As Double
Dim IsoAng As Double
Dim Radius As Double
Dim ClockWise As Boolean
Dim RadAng As Double
Dim Bulg As Double
If Vertex = Empty Then Vertex = 0
Bulg = PolyLin.GetBulge(Vertex)
PolyPts = PolyLin.Coordinates
PolySp(0) = PolyPts(Vertex * 2 + 0): PolySp(1) = PolyPts(Vertex * 2 + 1)
PolyEp(0) = PolyPts(Vertex * 2 + 2): PolyEp(1) = PolyPts(Vertex * 2 + 3)
Set Lin1 = ThisDrawing.ModelSpace.AddLine(PolySp, PolyEp)
Ang = Atn(Bulg) * 4
IsoAng = Ang / 3.141592654 * 180
If IsoAng < 0 Then
IsoAng = (IsoAng + 180) / 2
ClockWise = True
Else
IsoAng = (180 - IsoAng) / 2
IsoAng = IsoAng / 180 * 3.141592654
If ClockWise Then
RadAng = Lin1.Angle + IsoAng + 3.141592654
Else
RadAng = Lin1.Angle - IsoAng + 3.141592654
Radius = (Lin1.Length / 2) / Cos(IsoAng)
CenterPt = ThisDrawing.Utility.PolarPoint(PolyEp, RadAng, Radius)
Lin1.Delete
End Function
Replies (9)
Message 2 of 10
-didier-
Coucou Hello
I think you should look at the value of the plinetype variable, it should be 2
Amicalement Friendly
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 10
cadffm
Plinetype? Plinetype is for PLINE command, nothing more, or?
But Polyline and LwPolyline are two diffwrent objecttype like circle and line,
differenz properties/ property names and available settings.
Sebastian
Message 4 of 10
_gile
hi,
First, you should have posted in the VB forum (or in the french AutoCAD forum).
Why do you iterate the whole model space to search the entity you created in the same Sub instead of just using the plineObj variable?
Anyway, AcDbPolyline is the ObjectARX class name (ObjectName  COM property) for the COM AcadLWPolyline COM type.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 10
-didier-
Coucou Hello
Plinetype is really about the polyline...
extract from the help :
PLINETYPE controls both the creation of new polylines with the PLINE command and the conversion of existing polylines in drawings from previous releases.
Amicalement friendly
DA
Message 6 of 10
cadffm
@-didier-
Sure, i never said other things, but this is for native 'Autocad commands', nothing to do with programming via API, instead you are using simple (send)command Functions to controle 'native AutoCAD commands', OR?
Sebastian
Message 7 of 10
Delforge
plinetype variable, is 2 but no difference with 0 or 1.
The problem can come only from
or
If oEntite.ObjectName = "AcDbPolyline".
I have try with AcadPolyline but no succes
Message 8 of 10
SeeMSixty7
There is a significant difference between an LWPolyline and a Polyline.
The lightweight Poly has a different structure in than AutoCAD Database than the Polyline
The traditional polyline has a head entity and then followed by a sequence of additional vertex entities. Visual LISP  object access seems transparent on accessing the two ent types the same, I assume VB does as well, but the reality is there are separate entities on an actual polyline type, that would have to be considered if you are trying to actually step down into the sub entities and manipulate them.
Since you are creating as a LWpoly then stick with that and avoid the polyline type all together.
PLINETYPE controls what method autocad creates plines as using the pline command. 3DPOLY always creates a Polyline entity as the LW can't handle 3D points.
Hope that helps in some way.
Message 9 of 10
_gile
or
Nope, the ObjectName property returns the ObjectARX class name.
And the ObjectARX class name for the AcadLWPolyline COM is "AcDbPolyline".
I'm not very cumfortable with VB(A) but it seems to me you can simply use the 'oEntite' variable:
    Dim i As Integer
    ZoomAll
    plineObj.Update
	longeur_poly = Round(UBound(oEntite.Coordinates) / 2, 0) - 1
	i = 0
	P1 = oEntite.Coordinate(0)
	    rayon = Sqr((CenterPt(oEntite, i)(0) - oEntite.Coordinate(i)(0)) ^ 2 + (CenterPt(oEntite, i)(1) - oEntite.Coordinate(i)(1)) ^ 2)
	    MsgBox (rayon)
	    i = i + 1
	Wend
Next
End Sub
Gilles Chanteau
GileCAD
GitHub
Message 10 of 10
Delforge
Thanks, it was the solution !!!
