ACADE scratch database in lisp
gcsjlewis
gcsjlewis
I am working on looking at my scratch database and then inserting blocks into my layout based on what it finds.  These are the steps that i have taken so far:
(setq fnam (c:wd_mdb_get_proj_scratch_dbnam nil))
(setq hdl (wd_mdb_GetHandle 1))
(wd_mdb_Open hdl fnam)
(setq lst (wd_mdb_GetRecs hdl "COMP" "TAGNAME,MFG,CAT,RATING1" "" "TAGNAME"))
At this point i get a list of lists of in this format:
(("TAGNAME" . "SU1005") ("MFG" . "PHOENIX CONTACT") ("CAT" . "2856812")  ("RATING1" . "")))
Knowing this information i can go to our access database to get the block information using this API command
(setq filename (c:ace_get_footprint_fnam (list "MFG" "CAT" "ASSYCODE" "FLAG")))
And then insert the part using this API command
(c:wd_insymp filename (list 0.0 0.0) 0.0 1.0 nil)
Everything works. . . sort of.  The part is inserted, it has the proper information attached to it.  But when i run a bom report, it won't link to the right description found in our parts database. So it's not linking right.  I see in the access database it carries a RECNUM for every part.  Is there a way to attach that number so it carries through?
gcsjlewis
I figured it out by adding xdata to the blocks dxf codes.  I still have to tweek it a little based on what type of block, but if anybody wants to see what i did let me know.
yan_ken
Hi Jason, I was hoping if you could share this LISP file of yours. I am trying to insert blocks based on a exported BOM in xls with CATALOG and MFG columns, then automatically insert the blocks through the footprint database and simply skip the ones without it.
I had a post here but then I found your thread here that might able to help me.
https://forums.autodesk.com/t5/autocad-electrical-forum/a-way-to-skip-panel-component-dialog-box-whe...
Thanks very much!
Sea-Haven
"I am trying to insert blocks based on a exported BOM in xls" You can read a Excel from CAD directly, so if you could provide more information a dwg and a sample Excel may be able to do something.
gcsjlewis
yan_ken,
I cannot post the lisp, but I can help walk you through it.  I just need to know a few things:
1.  Can you communicate with Excel currently to pull-in information.
2.  If I list the visual lisp & API commands I use, can you adjust them to work with your BOM.
Basically how much help do you need.  As I stated, I can walk you through it, but you would have to do the "leg work" to pull it all together.
