AcadCore printing and loading arg
lisaj98052
lisaj98052
I think someone helped me with this but for some reason this does not run, not sure why.
also can you run a lisp in acadCore?
echo off
"C:\Program Files\AutoCAD 2000\acad.exe" /p "K:\AutoCad\Support_Client_Files\kingCounty\Profile\KingCountyC3d 2018.arg
:: Path to AutoCAD core console
set accoreexe=""C:\Program Files\Autodesk\AutoCAD 2018\accoreconsole.exe"
:: Path the directory to process
set "source=C:\CADDLib\pw\lijohnson\west\d0108928\"
:: Path to the script to run
set script="C:\CADDLib\AutoCAD\Projects\68448_ERC\SCRIPT\printsheet.scr"
FOR /f "delims=" %%f IN ('dir /b "%source%\4.01*.dwg"') DO %accoreexe% /i "%source%\%%f" /s %script%
:: comment the following to automatically close the console when batch ends
Sea-Haven
A few mistakes look at " for a start end.
You will open acad with your arg not sure how that effects aecorconsole
A script supports lisp code within it. No user input. You may get away with a (load "mylisp") mylisp, in your script.
martti.halminen
I hope the AutoCAD 2000 in the path is a typo...
I'm not sure about the scripts, but at least for .lsp files AcCoreConsole only loads them if they are on the trusted path, otherwise it ignores them quietly.
lisaj98052
Wish I was better at programing, but I'm not.  I may have to just run this in in scriptpro which would be slower but get the job done. Does anyone have a similar lisp that does not use active x?,
It's seems like an easy task for some of you very skilled programmers, but I could be very mistaken.
It seems like it would be so handy to update attribute in files not just title block data but say match lines, etc. form a csv file just before as plotting and in the acad core environment.
Thank for all your help and explanations of why the list would not run in this environment.
lisaj98052
Thank you this work well.
